Debian 12 and GCC 12
Like Tree1Likes
  • 1 Post By pipedream
Old   August 8, 2023, 19:54
Default Debian 12 and GCC 12
Jan Groenewald
pipedream is on a distinguished road
On Debian 12, GCC 12.2.0 is the default compiler.
Compiling OpenFOAM 2012 (I was using this version for solids4foam) fails with gcc 12 as attached.
Compilation succeeds with gcc 11.
It might have to do with the header dependencies as mentioned here:
https://gcc.gnu.org/gcc-12/porting_to.html
I.e. a missing #include <array> somewhere?
pipedream is offline   Reply With Quote
Old   August 11, 2023, 06:12
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
I don't quite understand what is going on here. I assume that you already checked the issue tracker (https://develop.openfoam.com/Development/openfoam) but didn't see
https://develop.openfoam.com/Develop.../-/issues/2714
This has been patched on various maintenance branches, and there are even newer code packs on https://dl.openfoam.com/source if you aren't using git. So I don't understand what is going wrong.
In any case, there will not be that many internal changes to OpenFOAM to prevent you from using more recent versions (Eg, OpenFOAM-v2306) with solids4foam.
EDIT: the include for std::array was patched even well before that (the OpenFOAM-v2012_210414 code pack, which means it was patched and re-released more than two years ago).
olesen is offline   Reply With Quote
Old   August 12, 2023, 01:32
Jan Groenewald
v2306 compiled but solids4foam failed as attached
Old   August 16, 2023, 12:27
Mark Olesen
I have a pull-request added for that now - if you wanted to try from there.
https://github.com/solids4foam/solids4foam/pull/60
Old   August 16, 2023, 14:19
Default Success
Jan Groenewald
git fetch origin pull/60/head:development
git checkout development
Summary statistics
    Number of cases where a run was attempted: 48
    Number of cases where the solver failed: 0
    Number of cases where another command failed: 0
All tests passed: enjoy solids4foam.
olesen likes this.
