coal SurfaceReactionModel
Like Tree3Likes
  • 2 Post By lliyuu
  • 1 Post By Felicity_NWU
Old   July 3, 2023, 00:21
Default coal SurfaceReactionModel
xinyu
lliyuu is on a distinguished road
Hello Foam users,
I am simulating coal combustion in a rich fuel atmosphere, and the SurfaceReactionModel in Openfoam only has C (s)+O2=CO2. I need a multi-step surface reaction, and I have modified the COxidationKineticDiffusionLimitedRate, but warning has occurred. I don't know where the problem lies? Does anyone know where my mistake lies?
C (s)+O2=CO
C (s)+CO2=CO
C (s)+H2O=CO+H2
lnInclude/COxidationKineticDiffusionLimitedRate2.H:145:58: required from here
lnInclude/COxidationKineticDiffusionLimitedRate2.H:100:19: warning: ‘Foam::COxidationKineticDiffusionLimitedRate2<Foam ::ReactingMultiphaseCloud<Foam::ReactingCloud<Foam ::ThermoCloud<Foam::MomentumCloud<Foam::ParcelClou dBase<Foam::ReactingMultiphaseParcel<Foam::Reactin gParcel<Foam::ThermoParcel<Foam::MomentumParcel<Fo am:article> > > > > > > > > >::CO2GlobalId_’ will be initialized after [-Wreorder]
100 | label CO2GlobalId_;
lnInclude/COxidationKineticDiffusionLimitedRate2.H:94:19: warning: ‘Foam::label Foam::COxidationKineticDiffusionLimitedRate2<Foam: :ReactingMultiphaseCloud<Foam::ReactingCloud<Foam: :ThermoCloud<Foam::MomentumCloud<Foam::ParcelCloud Base<Foam::ReactingMultiphaseParcel<Foam::Reacting Parcel<Foam::ThermoParcel<Foam::MomentumParcel<Foa m:article> > > > > > > > > >::COGlobalId_’ [-Wreorder]
94 | label COGlobalId_;
In file included from lnInclude/COxidationKineticDiffusionLimitedRate2.H:191,
from lnInclude/makeReactingMultiphaseParcelSurfaceReactionModels. H:39,
from parcels/derived/reactingMultiphaseParcel/makeReactingMultiphaseParcelSubmodels.C:47:
lnInclude/COxidationKineticDiffusionLimitedRate2.C:89:1: warning: when initialized here [-Wreorder]
89 | Foam::COxidationKineticDiffusionLimitedRate2<Cloud Type>::
In file included from lnInclude/makeReactingMultiphaseParcelSurfaceReactionModels. H:39,
lnInclude/COxidationKineticDiffusionLimitedRate2.H:98:19: warning: ‘Foam::COxidationKineticDiffusionLimitedRate2<Foam ::ReactingMultiphaseCloud<Foam::ReactingCloud<Foam ::ThermoCloud<Foam::MomentumCloud<Foam::ParcelClou dBase<Foam::ReactingMultiphaseParcel<Foam::Reactin gParcel<Foam::ThermoParcel<Foam::MomentumParcel<Fo am:article> > > > > > > > > >::H2OGlobalId_’ will be initialized after [-Wreorder]
98 | label H2OGlobalId_;
lnInclude/COxidationKineticDiffusionLimitedRate2.H:96:19: warning: ‘Foam::label Foam::COxidationKineticDiffusionLimitedRate2<Foam: :ReactingMultiphaseCloud<Foam::ReactingCloud<Foam: :ThermoCloud<Foam::MomentumCloud<Foam::ParcelCloud Base<Foam::ReactingMultiphaseParcel<Foam::Reacting Parcel<Foam::ThermoParcel<Foam::MomentumParcel<Foa m:article> > > > > > > > > >::H2GlobalId_’ [-Wreorder]
96 | label H2GlobalId_;
lliyuu is offline   Reply With Quote
Old   July 5, 2023, 22:43
Default Sequence problem
xinyu
I solved it, it's just a matter of order.
There was no problem running the new surfacereactionmodel, but the result was incorrect. The combustion temperature was very low at only 1000k, and the CO+O2=CO2 in constant/reactions did not actually occur, which means there was no CO2 generation.
Nitesh_Sahu and Felicity_NWU like this.
Old   August 10, 2023, 07:54
Felicity Nthatisi
Felicity_NWU is on a distinguished road
Did you manage to get a model running with acceptable results? I am busy with coal combustion and I am struggling. If you can help please.
Nitesh_Sahu likes this.
Felicity_NWU is offline   Reply With Quote
Old   August 10, 2023, 08:46
Domenico Lahaye
dlahaye is on a distinguished road
Greetings.
Where exactly are you stuck?
dlahaye is offline   Reply With Quote
coal SurfaceReactionModel lliyuu OpenFOAM Running, Solving & CFD 2 May 31, 2023 04:17
Coal combustion injection properties semo FLUENT 12 May 16, 2017 20:40
Non premixed- Coal combustion praveen2011 FLUENT 3 November 1, 2016 09:57
Fixed Bed Coal gasification nabeelicet FLUENT 0 February 2, 2014 07:36
Clean Coal Projects Clean Coal Projects Main CFD Forum 0 March 2, 2009 04:57
