How to add a new multiphase solver for multiphaseEulerFoam? error
Like Tree1Likes
  • 1 Post By gu1
Old   June 24, 2023, 12:49
Default How to add a new multiphase solver for multiphaseEulerFoam? error
gu1
Guilherme
gu1 is on a distinguished road
I'm having difficulties implementing a new turbulence model in OpenFOAM 9. I want to solve a study of the injection of air bubbles in water columns (bubbleColumn tutorial) using the multiphaseEulerFoam solver.
error:
wmake libso .
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file phaseDESCompressibleMomentumTransportModels.C
g++ -std=c++14 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3  -DNoRepository -ftemplate-depth-100 -I/opt/openfoam9/src/MomentumTransportModels/momentumTransportModels/lnInclude -I/opt/openfoam9/src/MomentumTransportModels/phaseCompressible/lnInclude -I/opt/openfoam9/src/MomentumTransportModels/compressible/lnInclude -I/opt/openfoam9/src/transportModels/lnInclude -I/opt/openfoam9/src/finiteVolume/lnInclude -I/opt/openfoam9/src/meshTools/lnInclude -I/opt/openfoam9/src/thermophysicalModels/basic/lnInclude -I/opt/openfoam9/src/../applications/solvers/multiphase/multiphaseEulerFoam/phaseSystems/lnInclude -I/opt/openfoam9/src/../applications/solvers/multiphase/multiphaseEulerFoam/interfacialModels/lnInclude -IlnInclude -I. -I/opt/openfoam9/src/OpenFOAM/lnInclude -I/opt/openfoam9/src/OSspecific/POSIX/lnInclude   -fPIC -c phaseDESCompressibleMomentumTransportModels.C -o Make/linux64GccDPInt32Opt/phaseDESCompressibleMomentumTransportModels.o
phaseDESCompressibleMomentumTransportModels.C:31:1: error: expected constructor, destructor, or type conversion before ‘(’ token
   31 | (
In file included from phaseDESCompressibleMomentumTransportModels.C:43:
continuousGasKEDES.H:78:20: error: expected template-name before ‘<’ token
   78 |     public kEpsilon<BasicMomentumTransportModel>
continuousGasKEDES.H:78:20: error: expected ‘{’ before ‘<’ token
In file included from continuousGasKEDES.H:171,
continuousGasKEDES.C:45:11: error: ‘alphaField’ does not name a type; did you mean ‘addField’?
   45 |     const alphaField& alpha,
      |           addField
continuousGasKEDES.C:46:11: error: ‘rhoField’ does not name a type
   46 |     const rhoField& rho,
continuousGasKEDES.C:50:11: error: ‘transportModel’ does not name a type
   50 |     const transportModel& transport,
continuousGasKEDES.C:52:1: error: invalid use of incomplete type ‘class Foam::LESModels::continuousGasKEDES<BasicMomentumTransportModel>’
   52 | )
continuousGasKEDES.H:76:7: note: declaration of ‘class Foam::LESModels::continuousGasKEDES<BasicMomentumTransportModel>’
   76 | class continuousGasKEDES
continuousGasKEDES.C:100:60: error: invalid use of incomplete type ‘class Foam::LESModels::continuousGasKEDES<BasicMomentumTransportModel>’
  100 | bool continuousGasKEDES<BasicMomentumTransportModel>::read()
continuousGasKEDES.C:116:66: error: invalid use of incomplete type ‘class Foam::LESModels::continuousGasKEDES<BasicMomentumTransportModel>’
  116 | void continuousGasKEDES<BasicMomentumTransportModel>::correctNut()
continuousGasKEDES.C:152:69: error: invalid use of incomplete type ‘class Foam::LESModels::continuousGasKEDES<BasicMomentumTransportModel>’
  152 | continuousGasKEDES<BasicMomentumTransportModel>::liquidTurbulence() const
continuousGasKEDES.C:179:58: error: invalid use of incomplete type ‘class Foam::LESModels::continuousGasKEDES<BasicMomentumTransportModel>’
  179 | continuousGasKEDES<BasicMomentumTransportModel>::nuEff() const
continuousGasKEDES.C:206:59: error: invalid use of incomplete type ‘class Foam::LESModels::continuousGasKEDES<BasicMomentumTransportModel>’
  206 | continuousGasKEDES<BasicMomentumTransportModel>::rhoEff() const
continuousGasKEDES.C:225:71: error: invalid use of incomplete type ‘class Foam::LESModels::continuousGasKEDES<BasicMomentumTransportModel>’
  225 | continuousGasKEDES<BasicMomentumTransportModel>::phaseTransferCoeff() const
continuousGasKEDES.C:248:60: error: invalid use of incomplete type ‘class Foam::LESModels::continuousGasKEDES<BasicMomentumTransportModel>’
  248 | continuousGasKEDES<BasicMomentumTransportModel>::kSource() const
continuousGasKEDES.C:261:66: error: invalid use of incomplete type ‘class Foam::LESModels::continuousGasKEDES<BasicMomentumTransportModel>’
  261 | continuousGasKEDES<BasicMomentumTransportModel>::epsilonSource() const
continuousGasKEDES.C:274:58: error: invalid use of incomplete type ‘class Foam::LESModels::continuousGasKEDES<BasicMomentumTransportModel>’
  274 | continuousGasKEDES<BasicMomentumTransportModel>::sigma() const
phaseDESCompressibleMomentumTransportModels.C:44:13: error: expected constructor, destructor, or type conversion before ‘(’ token
   44 | makeLESModel(continuousGasKEDES);
make: *** [/opt/openfoam9/wmake/rules/General/transform:26: Make/linux64GccDPInt32Opt/phaseDESCompressibleMomentumTransportModels.o] Erro 1
I have attached the files I am trying to compile.
options file:
EXE_INC = \
    -I$(LIB_SRC)/MomentumTransportModels/momentumTransportModels/lnInclude \
    -I$(LIB_SRC)/MomentumTransportModels/phaseCompressible/lnInclude \
    -I$(LIB_SRC)/MomentumTransportModels/compressible/lnInclude \
    -I$(LIB_SRC)/transportModels/lnInclude \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I$(LIB_SRC)/meshTools/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/basic/lnInclude \
    -I$(LIB_SRC)/../applications/solvers/multiphase/multiphaseEulerFoam/phaseSystems/lnInclude \
    -I$(LIB_SRC)/../applications/solvers/multiphase/multiphaseEulerFoam/interfacialModels/lnInclude
LIB_LIBS = \
    -libphaseSystem \
    -leulerianInterfacialCompositionModels \
    -lfluidThermophysicalModels \
    -ltransportModels \
    -lfiniteVolume \
    -lmeshTools
files file:
LIB = $(FOAM_USER_LIBBIN)/libphaseDESCompressibleMomentumTransportModels
If anyone can help I would be very grateful.
THANKS!
File Type: c phaseDESCompressibleMomentumTransportModels.C (1.8 KB, 4 views)
gu1 is offline   Reply With Quote
Old   June 26, 2023, 14:19
gu1
Guilherme
Can someone help me? Please
Old   July 13, 2023, 08:28
gu1
Guilherme
I couldn't progress in my studies, can someone help me?
Old   July 15, 2023, 07:19
Tobermory will become famous soon enough
Guilherme - you didn't include the PhaseCompressibleMomentumTransportModel.H file ... check that you're not missing a brace or semicolon at the end of this file ... or that you don't have too may braces. That will sometimes make the compiler throw a fit about the following text.
Tobermory is offline   Reply With Quote
Old   September 23, 2023, 16:15
gu1
Guilherme
Thanks for your reply.
I managed to improve with your advice, but I still can't compile the turbulence model.
$ wmake
wmakeLnIncludeAll: running wmakeLnInclude on dependent libraries:
    wmakeLnInclude error: base directory ../momentumTransportModels/ does not exist
    wmakeLnInclude error: base directory ../compressible/ does not exist
Making dependency list for source file phaseDESMomentumTransportModel.C
g++ -std=c++14 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3  -DNoRepository -ftemplate-depth-100 -I../momentumTransportModels/lnInclude -I../compressible/lnInclude -I/opt/openfoam9/src/transportModels/lnInclude -I/opt/openfoam9/src/finiteVolume/lnInclude -I/opt/openfoam9/src/meshTools/lnInclude -I/opt/openfoam9/src/MomentumTransportModels/phaseCompressible/lnInclude -I/opt/openfoam9/src/MomentumTransportModels/momentumTransportModels/lnInclude -I/opt/openfoam9/src/MomentumTransportModels/compressible/lnInclude -I/opt/openfoam9/applications/solvers/multiphase/multiphaseEulerFoam/phaseSystems/lnInclude -I/opt/openfoam9/src/thermophysicalModels/basic/lnInclude -I/opt/openfoam9/applications/solvers/multiphase/multiphaseEulerFoam/interfacialModels/lnInclude -IlnInclude -I. -I/opt/openfoam9/src/OpenFOAM/lnInclude -I/opt/openfoam9/src/OSspecific/POSIX/lnInclude   -fPIC -c phaseDESMomentumTransportModel.C -o Make/linux64GccDPInt32Opt/phaseDESMomentumTransportModel.o
g++ -std=c++14 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3  -DNoRepository -ftemplate-depth-100 -I../momentumTransportModels/lnInclude -I../compressible/lnInclude -I/opt/openfoam9/src/transportModels/lnInclude -I/opt/openfoam9/src/finiteVolume/lnInclude -I/opt/openfoam9/src/meshTools/lnInclude -I/opt/openfoam9/src/MomentumTransportModels/phaseCompressible/lnInclude -I/opt/openfoam9/src/MomentumTransportModels/momentumTransportModels/lnInclude -I/opt/openfoam9/src/MomentumTransportModels/compressible/lnInclude -I/opt/openfoam9/applications/solvers/multiphase/multiphaseEulerFoam/phaseSystems/lnInclude -I/opt/openfoam9/src/thermophysicalModels/basic/lnInclude -I/opt/openfoam9/applications/solvers/multiphase/multiphaseEulerFoam/interfacialModels/lnInclude -IlnInclude -I. -I/opt/openfoam9/src/OpenFOAM/lnInclude -I/opt/openfoam9/src/OSspecific/POSIX/lnInclude   -fPIC -fuse-ld=bfd -shared -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/phaseDESMomentumTransportModel.o -L/opt/openfoam9/platforms/linux64GccDPInt32Opt/lib \
    -ltransportModels -lfiniteVolume -lmeshTools -libphaseCompressibleMomentumTransportModels -libmomentumTransportModels -libcompressibleMomentumTransportModels -libphaseSystem -libfluidThermophysicalModels -libeulerianInterfacialModels  -o /home/assis/OpenFOAM/assis-9/platforms/linux64GccDPInt32Opt/lib/libhaseDESMomentumTransportModel.so
/usr/bin/ld.bfd: cannot find -libphaseCompressibleMomentumTransportModels
/usr/bin/ld.bfd: cannot find -libmomentumTransportModels
/usr/bin/ld.bfd: cannot find -libcompressibleMomentumTransportModels
/usr/bin/ld.bfd: cannot find -libphaseSystem
/usr/bin/ld.bfd: cannot find -libfluidThermophysicalModels
/usr/bin/ld.bfd: cannot find -libeulerianInterfacialModels
collect2: error: ld returned 1 exit status
make: *** [/opt/openfoam9/wmake/makefiles/general:181: /home/assis/OpenFOAM/assis-9/platforms/linux64GccDPInt32Opt/lib/libhaseDESMomentumTransportModel.so] Erro 1
OpenFOAM didn't explain what the error was and curiously, it doesn't make sense that it couldn't find the files. I made the correct reference.
EXE_INC = \
    -I../momentumTransportModels/lnInclude \
    -I../compressible/lnInclude \
    -I$(FOAM_APP)/solvers/multiphase/multiphaseEulerFoam/phaseSystems/lnInclude \
    -I$(FOAM_APP)/solvers/multiphase/multiphaseEulerFoam/interfacialModels/lnInclude
LIB_LIBS = \
    -ltransportModels \
    -lfiniteVolume \
    -lmeshTools \
    -libphaseCompressibleMomentumTransportModels \
    -libmomentumTransportModels \
    -libcompressibleMomentumTransportModels \
    -libphaseSystem \
    -libfluidThermophysicalModels \
Would you mind helping me?
Old   September 23, 2023, 19:04
gu1
Guilherme
Problem solved.
All you had to do was change from "lib..." to "l..."
LIB_LIBS = \
    -ltransportModels \
    -lfiniteVolume \
    -lmeshTools \
    -lphaseCompressibleMomentumTransportModels \
    -lmomentumTransportModels \
    -lcompressibleMomentumTransportModels \
    -lphaseSystem \
    -leulerianInterfacialModels
Tobermory likes this.
multiphase, multiphaseeulerfoam, openfoam9, programming
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 08:43
Mesquite - Adaptive mesh refinement / coarsening? philippose OpenFOAM Running, Solving & CFD 94 January 27, 2016 10:40
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x Saxwax OpenFOAM Installation 25 November 29, 2013 06:34
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 06:07
