Regarding the energy equation(Internal energy equation) in the sonicFoam solver.
Like Tree2Likes
  • 1 Post By dlahaye
  • 1 Post By dlahaye
Old   May 15, 2023, 23:26
Post Regarding the energy equation(Internal energy equation) in the sonicFoam solver.
applekiller is on a distinguished road
Hello,every Foamer, This is my first time posting a question in this community, and I am looking forward to everyone's answers.
I have a question about solving the energy equation (internal energy equation) in sonicFoam.
In EEqn.H of sonicFoam(I added some comments )
HTML Code:
    fvScalarMatrix EEqn
        fvm::ddt(rho, e) + fvm::div(phi, e)
      + fvc::ddt(rho, K) + fvc::div(phi, K)
      + fvc::div(fvc::absolute(phi/fvc::interpolate(rho), U), p, "div(phiv,p)") // fvc::absolute does nothing for static mesh
      - fvm::laplacian(turbulence->alphaEff(), e)   // turbulence->alphaEff() returns lambda/c_p or lambda/c_v depending on the solution variable e or h
        fvOptions(rho, e)
The equation represented by this code seems to be
\frac{\partial \rho e}{\partial t} + \frac{1}{2}\frac{\partial \rho\pmb{u}^2}{\partial t} + \nabla\cdot(\rho e\pmb{u})+\frac{1}{2}\nabla\cdot(\rho \pmb{u}\pmb{u^2}) + \nabla\cdot(\pmb{u}p) + \nabla\cdot\pmb{q} = 0
In above equation
\pmb{u}^2 = \pmb{u}\cdot\pmb{u}
\pmb{q} = -\lambda\nabla T
e = C_v T
But if the total energy equation
\frac{\partial \rho E}{\partial t} + \nabla\cdot(\pmb{u}(\rho E+p)) - \nabla\cdot(\pmb{\tau}\cdot\pmb{u}) + \nabla\cdot \pmb{q} = 0
is expanded into the form of an internal energy equation, then the internal energy equation is like this.
\frac{\partial \rho e}{\partial t} + \frac{1}{2}\frac{\partial \rho\pmb{u}^2}{\partial t} + \nabla\cdot(\rho e\pmb{u})+\frac{1}{2}\nabla\cdot(\rho \pmb{u}\pmb{u^2}) + \nabla\cdot(\pmb{u}p) - \underline{\nabla\cdot(\pmb{\tau}\cdot\pmb{u})}+ \nabla\cdot\pmb{q} = 0
By comparing the internal energy equation represented in the code in OpenFOAM with the internal energy equation we derived, it can be seen that the internal energy equation solved in OpenFOAM lacks the viscous term-\nabla\cdot(\pmb{\tau\cdot\pmb{u}}).
So my question is,
1) Why does OpenFOAM omit the viscous term in solving the internal energy equation?
2) Does this handling have a significant impact on the results? (After all, the viscous term is missing from the internal energy equation)
I am looking forward to everyone's answer to this question and best wishes for everyone.
applekiller is offline   Reply With Quote
Old   May 16, 2023, 04:11
Domenico Lahaye
dlahaye is on a distinguished road
The default OpenFoam implementation assumes that the effect of viscous dissipation is small. The additional computational cost to compute the viscous dissipation is thrown overboard. OpenFoam assumes this assumption to be satisfied in situations in which the solver is applied. OpenFoam assumes the user of the solver to verify the hypothesis or to at least raise healthy questions as you are doing.
2) Does this handling have a significant impact on the results? (After all, the viscous term is missing from the internal energy equation).
Again, the hypothesis is that the effect of viscous dissipation is small. In situations in which viscous dissipation is important, it could be added using the fvOptions(rho,e) term.
Tobermory likes this.
dlahaye is offline   Reply With Quote
Old   May 16, 2023, 05:53
thanks for your timely reply!
Is this solver mainly used for supersonic flow? (So OpenFOAM defaults to a relatively low viscosity dissipation).
Old   May 16, 2023, 09:55
Domenico Lahaye
Yes and no.
Yes, sonicFoam is intended mainly for supersonic flows (hence the name).
No, however, rhoS/PimpleFoam also excluded viscous dissipation by default.
applekiller likes this.
Old   May 16, 2023, 10:52
Yes and no.
Can this be understood as OpenFOAM's default expectation for users to decide how to handle viscous term(for example, as you mentioned, add it to the fvOptions term)?
I have seen some OpenFOAM code where solvers sometimes lack some terms in discrete equations, which has been bothering me for a while.
Thank you very much for your answer !!!
How is strength value used in the Energy Equation of XiFoam solver? Manideep304 OpenFOAM Running, Solving & CFD 3 August 30, 2022 03:20
foam-extend-4.1 release hjasak OpenFOAM Announcements from Other Sources 19 July 16, 2021 06:02
Fail to converge when solving with a fabricated solution zizhou FLUENT 0 March 22, 2021 07:33
modify a solver to account for energy equation. Yanci OpenFOAM Running, Solving & CFD 0 November 11, 2014 10:23
Why FVM for high-Re flows? Zhong Lei Main CFD Forum 23 May 14, 1999 14:22
