Modification of chtMultiRegionFoam solver to compute p instead of p_rgh |
March 29, 2023, 05:01 |
Rachele Zamboni
Rep Power: 3 |
Hello everyone,
I have modified the chtMultiRegionFoam solver in particular the pEq to compute p instead of p_rgh in fluid regions. I have used the pEq of pimpleSolver. The solver compile with no errors but testing with a modified version of shell and tube heat exchange tutorial I get the following error: --> FOAM FATAL ERROR: LHS and RHS of - have different dimensions dimensions : [1 0 -1 0 0 0 0] - [0 3 -1 0 0 0 0] I think it is a problem of not consistent unit of measure in the pEq file but I dont understated where or how to fix it. |
March 29, 2023, 14:14 |
Pls. elaborate on what you are trying to accomplish.
p_rgh and p have different physical dimension. How do you intend to solve for thermodynamics of heat transfer by only solving for p_rgh? |
May 1, 2023, 14:41 |
Paulin FERRO
Rep Power: 5 |
Rachele wants to solve p (the pressure) instead of p_rgh (the piezzometric pressure) in the solver. The problem is that you can't use the pEqn of pimpleFoam because there is no gravity in pimpleFoam. In chtMultiRegionFoam the fluid is compressible and "buoyant". A very long time ago the solver was implemented with p and not p_rgh (OpenFOAM 1.6). |
May 1, 2023, 16:29 |
I fear that I still do not understand the question. chtMultiRegionFoam solves for the pressure (in N/m^2 = kg (1/m) (1/s^2) in the fluid domain as checking the dimensions for any of the tutorial examples (e.g. 0/p in the reverseBurner tutorials) shows. I clearly oversee something here. |
May 2, 2023, 02:19 |
#5 | |
Paul Palladium
Rep Power: 10 |
no chtMultiRegionFoam solves the piezzometric pressure p_rgh. p is not solved but explicitly calculated from p_rgh.
May 2, 2023, 02:59 |
#6 | |
Sincere thx for pointing out my mistake.
See e.g. line L82 of https://develop.openfoam.com/Develop...m/fluid/pEqn.H The question raised by Rachele does remain. If Quote:
May 2, 2023, 14:28 |
Paulin FERRO
Rep Power: 5 |
incompressible solvers in OpenFOAM solve p/rho and not p.
July 9, 2024, 17:29 |
Harsh Anand
Rep Power: 2 |
Hey there,
Could you let me know if you have successfully compiled the solver? I am working on a similar issue and need to get rid of 'p_rgh' as it is creating quite a bit of nuisance in the simulation... |
chtmultiregionfoam, solver development, solver error |
Error SIGSEGV using VOF and UDF | JERC_UTFSM | Fluent UDF and Scheme Programming | 14 | November 7, 2021 23:17 |
Fail to converge when solving with a fabricated solution | zizhou | FLUENT | 0 | March 22, 2021 06:33 |
customProperties dictionary for CHTMultiRegionFoam solver | PositronCascade | OpenFOAM Programming & Development | 0 | July 20, 2019 11:51 |
[swak4Foam] Efficient run-time postprocessing: combination of swak4foam and solver modification? | letzel | OpenFOAM Community Contributions | 3 | October 22, 2013 10:06 |
wallHeatFlux utility and chtMultiRegionFoam solver | Lada | OpenFOAM Post-Processing | 4 | June 7, 2012 09:46 |
