Solving convection-diffusion problems in spherical coordinates |
March 24, 2023, 04:18 |
Rep Power: 3 |
Hello to all,
I would like to solve a convection-diffusion scalar transport equation on the surface of a sphere (2D problem). The problem should have symmetry with respect to the main meridian. Are OpenFOAM fvm and fvc operators able to work with spherical coordinates? If so, how can this be achieved? |
March 28, 2023, 09:52 |
Rep Power: 4 |
I dont think so. Since the operators are different in spherical coordinates it is (I dont know for sure, I just assume that by my knowledge) the implementation has to be different. But you can try to transform your equations into cartesian coordiantes and try it that way. Depending on your time its probably worth it.
March 30, 2023, 04:29 |
Sergey Lesnik
Rep Power: 11 |
You may also be interested in Finite Area Method for this task, e.g. available in foam-extend.
conjugate heat transfer in OpenFOAM | skuznet | OpenFOAM Running, Solving & CFD | 99 | March 16, 2017 05:07 |
HeatSource BC to the whole region in chtMultiRegionHeater | xsa | OpenFOAM Running, Solving & CFD | 3 | November 7, 2016 05:07 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
