MemberFunction and Private Member Function
Like Tree2Likes
  • 1 Post By Tobermory
  • 1 Post By amirhosseintaran
Old   March 15, 2023, 09:21
Default MemberFunction and Private Member Function
Amirhossein Taran
amirhosseintaran is on a distinguished road
Dear Foamers,
If you navigate through a class like sixDofRigidBodyMotion, you can see that in the sixDoFRigidBodyMotionI.H there is a private member function for body velocity and it is declared as:
inline const Foam::vector& Foam::sixDoFRigidBodyMotionNew::v() const
    return motionState_.v();
in the member function section, there is also a member function for angular velocity called omega() and it declared as:
inline Foam::vector Foam::sixDoFRigidBodyMotionNew::omega() const
    return  Q() & (inv(momentOfInertia_) & pi());
Now the question is, If I want to have access to the object's velocity, how should I get that?
the same procedure for the angular velocity is easy as calling the member function object.omega().
Generally, when should we declare sth like velocity as a private member function and not member function?
Bests,
Amirhossein.
amirhosseintaran is offline   Reply With Quote
Old   March 16, 2023, 07:49
Tobermory will become famous soon enough
If you read the header file for sixDofRigidBodyMotion carefully, you will see that there are in fact two versions of member function v() - a private version that returns a non-const reference to the vector, and a public one that returns a const reference. These are implemented in the inline header file (https://cpp.openfoam.org/v8/sixDoFRi...8H_source.html). Can you now see why?
The public one is an access function, and is meant to allow other classes to just read the value (hence const). The private one is for use within the class, and is therefore not const.
To answer your wider question - this seems like a pretty good approach to me. Allow for const member access functions where useful, and keep the non-const version private.
amirhosseintaran likes this.
Tobermory is offline   Reply With Quote
Old   March 16, 2023, 09:06
Amirhossein Taran
Thanks, Tobermory for the reply,
yeah the fact you are saying is true, anyway in foam-extend there is no other version for v so I had to create a member function that just returns v!
And thanks for the explanation, I got my answer.
Bests,
Amirhossein
Tobermory likes this.
Old   November 8, 2024, 00:33
panda007 is on a distinguished road
Hi Taran,
I'm working on a FSI problem and wanted to access the omega() value under the sixDoFRigidBodyMotion class. I'm struggling how to get the value, do you have any suggestion?
I want to write the #codestream to customize a damping value based on the transient omega(). But so far has no success. TIA
panda007 is offline   Reply With Quote
Old   November 8, 2024, 07:19
Amirhossein Taran
Originally Posted by panda007 View Post
Hi Taran,
Hi Panda,
Although I havent tried it, but something like this might help, Could you try please and let me know ?
myDampingFactor
#codeStream
    codeInclude
        #include "sixDoFRigidBodyMotion.H"
    code
        // Retrieve the pointer to the sixDoFRigidBodyMotion object
        const auto& sixDoFModel = mesh.lookupObject<sixDoFRigidBodyMotion>("<motionObjectName>");
        // Access the angular velocity, Omega
        const vector omega = sixDoFModel.Omega();
        // Calculate a custom damping factor based on omega
        scalar dampingFactor = <your_custom_function>(mag(omega));
        // Output the calculated damping factor
        os << dampingFactor;
Old   November 8, 2024, 10:40
Originally Posted by amirhosseintaran View Post
Hi Panda,
myDampingFactor
#codeStream
    codeInclude
    code
Hi Taran,
Thanks for the quick response!!
I added the codeOptions and codeLibs to include the library, and just tried. It gave me an error, mesh is not declared in this scope. See screenshot.
Old   November 8, 2024, 10:44
Here is the code I put in, I have tested the rest of the code without the retrieving value, just assign omega as a constant value, it ran without problem. The problem is retrieving syntax.
damping #codeStream
                codeInclude
                    // #include "sixDoFRigidBodyMotionI.H"
                    // #include "sixDoFRigidBodyMotionState.H"
                codeOptions
                    -I$(WM_PROJECT_DIR)/src/sixDoFRigidBodyMotion/lnInclude \
                codeLibs
                    -lsixDoFRigidBodyMotion
                code
                    Foam::scalar omegaMag = mag(omega);
                    Foam::scalar dampingValue;
                    if (omegaMag >= 0.01)
                        dampingValue = 10.24 / omegaMag;
                    else
                        dampingValue = 1024 * omegaMag;
                    os << dampingValue;
                os << damping;
I tried to include fvCFD.H and the corresponding library and options, it still gave me the same error, mesh was not declared in this scope.
foam-extend 4.1, member function, openfoam programming, private member function
