how to do calculation for a variable when solver runs in parallel
Like Tree1Likes
  • 1 Post By Lorenzo210
Old   May 9, 2022, 15:51
Arrow how to do calculation for a variable when solver runs in parallel
Ujjwal Chetan
lightMyCandle is on a distinguished road
Hello Foamers,
I wanted to get the volume integral of y-component of vorticity and print it on the terminal at run time. The code for the same is as follows;
//vorticity calculation ----------------------------------------------------
volVectorField omega = fvc::curl(U);
// volume integrals calculation ---------------------------------------
scalar vort_volume_integral = 0;
forAll(omega, cellI)
vort_volume_integral += omega[cellI][1]*mesh.V()[cellI];
// printing data to the terminal at runtime -------------------------
Info<< "\nvorticity_y_component_volume_integral = " << vort_volume_integral << nl << endl;
When I do this calculation on single core for icoFoam solver, it accurately prints the vorticity-volume integral. But when I run the same in parallel (more than one cores at a time), I get the wrong output. I got the reason after comparing the calculation in paraview that it is calculating the variable only in certain regions of the domain as the domain is divided among multiple processors.
So, my question is, how to reassemble vorticity-volume-integral data from all the processors and add it up to print in the terminal.
Thanks
lightMyCandle is offline   Reply With Quote
Old   May 10, 2022, 05:52
Lorenzo
Lorenzo210 is on a distinguished road
You should add a code that collects the variable calculated by every single processor and sum it.
In fact,
this will make every processor do a certain operation on "vort_volume_integral" inside every part of the domain, but this variable is not communicated among the processors. So, it is actually normal that it works only in serial.
There are many snippets that you can find in your OpenFOAM directory regarding coding for simulations in parallel, for example in v2112 you can find them in "applications/test", just look for parallel, parallel communicators etc.
In order to collect the overall vorticity, you should add something like:
reduce(vort_volume_integral, sumOp<scalar>());
This will sum every vort_volume_integral.
Hope this helps.
Regards,
Lorenzo
francescomarra likes this.
Lorenzo210 is offline   Reply With Quote
collect data, parallel calculation
A function can only be used in serial calculation not parallel calculation chenghui62000 OpenFOAM Programming & Development 1 January 7, 2020 13:18
Error in gradient calculation only while parallel processing Pavithra OpenFOAM Running, Solving & CFD 0 December 23, 2019 05:32
Explicitly filtered LES saeedi Main CFD Forum 16 October 14, 2015 12:58
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 01:01
