Error: no matching function for call ... rho
Like Tree1Likes
  • 1 Post By quarkz
Old   April 19, 2022, 23:09
Default Error: no matching function for call ... rho
TWB
quarkz is on a distinguished road
I'm trying to compile a code from another author (https://github.com/krajit/sixDoFDynamicMotion). It is a code which allows the use of 6dof in solidBodyMotionFunction.
It works for OF1812 but not later versions. I'm trying to use it on v1912 and v2112.
The error line is :
rhoName_(SBMFCoeffs.lookupOrDefault<word>("rho", "rho"))
and the compiling error is:
sixDoFDynamicMotion.C: In constructor ‘Foam::solidBodyMotionFunctions::sixDoFDynamicMotion::sixDoFDynamicMotion(const Foam::dictionary&, const Foam::Time&)’:
sixDoFDynamicMotion.C:72:66: error: no matching function for call to ‘Foam::sixDoFRigidBodyMotion::sixDoFRigidBodyMotion(const Foam::dictionary&, const Foam::dictionary&)’
   72 |           rhoName_(SBMFCoeffs.lookupOrDefault<word>("rho", "rho"))
In file included from sixDoFDynamicMotion.H:47,
                 from sixDoFDynamicMotion.C:31:
/usr/lib/openfoam/openfoam2112/src/sixDoFRigidBodyMotion/lnInclude/sixDoFRigidBodyMotion.H:225:9: note: candidate: ‘Foam::sixDoFRigidBodyMotion::sixDoFRigidBodyMotion(const Foam::sixDoFRigidBodyMotion&)’
  225 |         sixDoFRigidBodyMotion(const sixDoFRigidBodyMotion&);
/usr/lib/openfoam/openfoam2112/src/sixDoFRigidBodyMotion/lnInclude/sixDoFRigidBodyMotion.H:225:9: note:   candidate expects 1 argument, 2 provided
/usr/lib/openfoam/openfoam2112/src/sixDoFRigidBodyMotion/lnInclude/sixDoFRigidBodyMotion.H:217:9: note: candidate: ‘Foam::sixDoFRigidBodyMotion::sixDoFRigidBodyMotion(const Foam::dictionary&, const Foam::dictionary&, const Foam::Time&)’
  217 |         sixDoFRigidBodyMotion
/usr/lib/openfoam/openfoam2112/src/sixDoFRigidBodyMotion/lnInclude/sixDoFRigidBodyMotion.H:217:9: note:   candidate expects 3 arguments, 2 provided
/usr/lib/openfoam/openfoam2112/src/sixDoFRigidBodyMotion/lnInclude/sixDoFRigidBodyMotion.H:214:9: note: candidate: ‘Foam::sixDoFRigidBodyMotion::sixDoFRigidBodyMotion(const Foam::Time&)’
  214 |         sixDoFRigidBodyMotion(const Time&);
/usr/lib/openfoam/openfoam2112/src/sixDoFRigidBodyMotion/lnInclude/sixDoFRigidBodyMotion.H:214:9: note:   candidate expects 1 argument, 2 provided
make: *** [/usr/lib/openfoam/openfoam2112/wmake/rules/General/transform:35: Make/linux64GccDPInt32Opt/sixDoFDynamicMotion.o] Error 1
Can someone help? My C++ knowledge is rather poor and I tried to subsitute rho in different ways but it just won't work.
quarkz is offline   Reply With Quote
Old   April 28, 2022, 02:57
TWB
I tried to compare sixDoFRigidBodyMotion.H between v1812 and v2112.
One key difference is:
v2112
// Constructors
        //- Construct null
        //- Construct from constant and state dictionaries
            const dictionary& dict,
            const dictionary& stateDict,
            const Time& time
        //- Construct as copy
and
v1812
// Constructors
        //- Construct null
        sixDoFRigidBodyMotion();
So how must I modify my code to accomodate this change?
Thanks
Old   April 28, 2022, 06:24
TWB
After some trial and error, and some luck, I think I finally got it working
motion_(SBMFCoeffs,SBMFCoeffs),
should be changed to:
motion_(SBMFCoeffs,SBMFCoeffs,time_.time()),
Guess I was looking at the wrong error too!
isulovsky likes this.
[mesh manipulation] RefineMesh Error and Foam warning jiahui_93 OpenFOAM Meshing & Mesh Conversion 4 March 3, 2018 12:32
[mesh manipulation] refineMesh Error mohsen.boojari OpenFOAM Meshing & Mesh Conversion 3 March 1, 2018 23:07
Warning message C4133 while compiling Arminius Fluent UDF and Scheme Programming 0 October 2, 2017 12:44
compressible flow in turbocharger riesotto OpenFOAM 50 May 26, 2014 02:47
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 13:21
