Nonlinear Equation
Like Tree1Likes
  • 1 Post By dlahaye
Old   February 18, 2022, 07:22
Default Nonlinear Equation
Max
Maxxxx is on a distinguished road
Hey,
I´m new to OpenFoam and would like to implement a nonlinear equation to my solver.
Target Equation: C1 * (C2 + C3 * (C4 * |X0-X|)^0.1) * (X-X0) = 0
Where C1,C2,C3 are constant dimensionedScalars,
X0 is my fixed reference volVectorField and
X is the volVectorField I would like to calculate for each cell
As you can see, I do not have any derivative to use fvm namespace or something else.
Hence, following code does obviously not work:
fvVectorMatrix XEqn
XEqn.solve();
Now my question: How can I solve equations like this with no derivative for each single cell. Is this possible? If yes are there multiple methods?
Help is appreciated
Max
Maxxxx is offline   Reply With Quote
Old   February 18, 2022, 07:30
Domenico Lahaye
dlahaye is on a distinguished road
How is X coupled accross various cells?
Does a loop over cells and a Newton-type iteration in each cell suffice?
dlahaye is offline   Reply With Quote
Old   February 18, 2022, 07:49
Max
Hey,
and thank you for the answer.
My X0 is coupled over the whole mesh. What I would like to do is calculating my X without any coupling meaning I can also calculate it for each cell with a loop as you said, but how?
Tanks you
Max
Old   February 18, 2022, 11:21
Domenico Lahaye
You can put a root finding algorithm inside a loop over cells.
To implement loop over cells, see e.g.
https://github.com/UnnamedMoose/Basi...mmingTutorials
A root finding algorithm can be found inside the boost libraries, see e.g. https://www.boost.org/doc/libs/1_64_...kit/roots.html. OpenFoam builds upon boost. Possible you can try to develop a boost solver outside of OpenFoam.
alundilong likes this.
Old   August 21, 2023, 03:07
Default nonlinear spring stiffness
@ss
shristi
@ss is on a distinguished road
I want to use non-linear spring stiffness to solve motion equations in openFoam. can anyone tell me how I can do that?
@ss is offline   Reply With Quote
Old   August 21, 2023, 06:50
yijin Mao
alundilong is on a distinguished road
please elaborate your question,
provide background and formula of interest would definitely help.
alundilong is offline   Reply With Quote
Old   August 21, 2023, 06:52
yijin Mao
Old   August 21, 2023, 07:25
Default non- linear equation
@ss
shristi
First of all, Thank you sir for your response.....
sir, I am working on energy harvesting from vortex-induced vibration in which I use non-linear spring stiffness instead of linear stiffness in the spring mass damper system using OpenFOAM software.
my ̈ + Cy ̇ + ky +by^3= Fy
I am not able to introduce nonlinearity in the motion equation in openFoam and also I am not able to find any video or tutorials related to this.
I have done simulations with linear systems for isolated and multi-body but have not been able to do with non-linear systems.
Old   August 22, 2023, 01:28
yijin Mao
You might borrow the ODEsystem and ODESolver to find solution of this second order ODE. Please see the attached file to further explanation.
nonlinear equation
How can temperature e treated as a passive scalar be used in transport equation? granzer OpenFOAM Running, Solving & CFD 3 June 6, 2021 17:35
Derivation of the Temperature Equation Tobi OpenFOAM Programming & Development 21 April 10, 2018 23:15
How to solve nonlinear equation. BoredKoala OpenFOAM Programming & Development 14 October 3, 2016 13:19
How to? Extra term in k-e equation. Implicit-Explicit be_inspired OpenFOAM Programming & Development 1 March 19, 2013 11:50
Diffusion Equation izardy amiruddin Main CFD Forum 2 July 4, 2002 09:14
