Adding evaporation source terms + interMixingFoam
Like Tree1Likes
  • 1 Post By Pavithra
Old   February 2, 2022, 07:30
Default Adding evaporation source terms + interMixingFoam
Pavithra is on a distinguished road
Hello Everyone,
I am trying to model evaporation of a water droplet in open air. I am considering vapour and air diffusion.
Hence, I chose interMixingFoam as my base solver, as it can handle three fluids out of which two are miscible with each other.
I have added the temperature equation to it and have calculated the evaporation mass transfer rate (mDot).
I need add the density weighted source terms to the alpha equations.
        // Solve for alpha1
        solve
        fvm::ddt(alpha1)
        + fvc::div(alphaPhi1)
        + mDot/rho1
        // Solve for alpha2
        fvScalarMatrix alpha2Eqn
            fvm::ddt(alpha2)
          + fvc::div(alphaPhi2)
          - fvm::laplacian(Dc23 + Dc32, alpha2)
          - mDot/rho2
        alpha2Eqn.solve();
This compiles very well. But, it diverges immediately once I run the simulation. I understand that the source terms have to be added using Su Sp in MULES.
I read previous posts that directed to look for interCondensatingEvaporatingFoam. But, interCondensatingEvaporatingFoam has only one alphaEqn and hence it just defines one Su and Sp terms. However, in my case I have two source terms mDot/rho1 and mDot/rho2.
Some one kindly please guide how to proceed with this problem.
Thank You.
Pavithra is offline   Reply With Quote
Old   April 19, 2022, 10:36
Vitor Monteiro
Vitor Monteiro is on a distinguished road
Instead of using inter, wouldn't it be better to use multiphaseEulerFoam? It has the interfaceCompositionPhaseChangeMultiphaseSystem model that could help you. See the tutorial bubbleColumnEvaporating to check how it is implemented.
Vitor Monteiro is offline   Reply With Quote
Old   May 9, 2022, 01:19
First of all, sorry for the late reply.
Thanks for the suggestion.
However, I see that the multiphaseEulerFoam does not consider phase change. (https://www.openfoam.com/documentati...EulerFoam.html).
Likewise, the bubble column tutorial in multiphaseEulerFoam folder also does not consider phase change.
Please correct me, if I am wrong.
Thank You.
liguobing00 likes this.
Old   May 9, 2022, 13:55
Al
aliyah. is on a distinguished road
I believe icoReactingMultiphaseInterFoam can be used. For your particular case, you should use water for the soluble fraction and air and vapor for the gas part. Then choose liquid to vapor for the phase change. The* pooleEvaporation tutorial is*a good example of this. Actually, it's the example you're looking for, and just modifying the boundary conditions and geometry will result in the problem you mentioned in your question.
You can find it in the following address in openfoam.
openfoam2006/tutorials/multiphase/icoReactingMultiPhaseInterFoam/poolEvaporation
aliyah. is offline   Reply With Quote
Old   May 9, 2022, 19:50
Vitor Monteiro
Thank You.
Actually, I thing there is a interface change modeling for evaporation. See this please (https://openfoam.org/release/8/).
In that context, what does the bubbleColumnEVAPORATING tutorial in multiphaseEulerFoam do if there's not evaporation?
Sorry, correct me if I'm wrong.
Old   May 11, 2022, 22:26
Hi, Thanks for the suggestion. I am aware about the icoReactingMultiPhaseInterFoam. But, the phase change physics in icoReactingMultiPhaseInterFoam is based on emprirical models like Lee Model or the Schrage model. But, I am trying to implement an P_sat and T_sat dependent model. Implementation of this new model is very complex and tedious in the framework of icoReactingMultiphaseInterFoam. Hence, I intend to use the framework of interMixingFoam. interMixingFoam already can handle two miscible and one immiscible fluids. I am trying to implement the mass transfer model into this framework.
Thank You.
Old   May 11, 2022, 22:31
Sorry, I am working on ESI version of openFOAM. You were talking about the foundation version.
The ESI version does not have bubble column evaporating tutorial.
I will install the foundation version of OpenFOAM and check the phase change models in multiPhaseEulerFoam.
Thanks a lot for the suggestion.
My main requirement is that I want to implement a new phase change model. It requires the inclusion of source term as described in my first post.
Thank You.
Old   May 12, 2022, 15:19
Vitor Monteiro
Thank You.
That's all right. I recommend take a look on that. You mentioned implementing P_sat and T_sat dependent model, and that is exactly why I suggested interPhaseChangeModel.
Take a look on that and tell us if it was worthy.
Old   April 14, 2023, 10:48
Graciella
Graciella is on a distinguished road
Hello Everyone,
        // Solve for alpha1
        solve
        fvm::ddt(alpha1)
        + mDot/rho1
        // Solve for alpha2
            fvm::ddt(alpha2)
          - mDot/rho2
        alpha2Eqn.solve();
Thank You.
Hi Pavithra,
I hope you are good. I have the same challenge right now. Did you get to solve this issue?
Also, how did you calculate the evaporation mass transfer rate (mDot)? Did you need to have a separate file for this source code?
Graciella is offline   Reply With Quote
Old   June 23, 2023, 19:30
zaki
zikou55 is on a distinguished road
Thank You.
Dear Pavithra,
Please I have a question regarding your solver meltingFoam. Did you resolve the parallelization problem, because I am facing it, any advice and thank you
zikou55 is offline   Reply With Quote
evaporation, intermixingfoam, mass transfer coefficient
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 09:06
multiRegionHeater error ordinary OpenFOAM Running, Solving & CFD 2 June 9, 2020 18:43
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 19:13
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 10:07
[Other] How to use finite area method in official OpenFOAM 2.2.0? Detian Liu OpenFOAM Meshing & Mesh Conversion 4 November 3, 2015 04:04
