Conjugate heat exchange
Like Tree2Likes
  • 1 Post By Bloerb
  • 1 Post By clapointe
Old   September 17, 2021, 09:27
Default Conjugate heat exchange
Alain Wokusch
alain.wokusch is on a distinguished road
I have been told that conjugate heat transfer in OpenFOAM is not very performant. But there is a workaround or a more advanced solution available that is supposed to perform better.
Unfortunately, I can't figure out what exactly the problem is and what the proposed solution would be. Does anyone know more?
alain.wokusch is offline   Reply With Quote
Old   September 18, 2021, 09:15
Bloerb will become famous soon enough
This is not true. It's quite powerful, but there are some limitations. If those apply depends on your problem however. The main limitation is that the regions are not implicitly coupled. There is such a solver in foamExtend. This is however often not a problem. Another one might be speed in transient simulations where either the flow or solid domain are limiting you with their diffusion or courant number. OpenFOAM couples the regions in every time step. And solves each region in every time step. If for example your flow is solved on a 1e-6 time step due the velocities and your temperature does not change on such small scales but rather in a minute like fashion, you might face extremly long computation times without tweaks.
alain.wokusch likes this.
Bloerb is offline   Reply With Quote
Old   September 18, 2021, 13:45
clapointe is on a distinguished road
A quick note -- it looks like there's an (semi)implicit coupling option available through the dev branch (and slated for v2112 release) now too: link. I've not tested it yet, but it could be worth looking into!
Caelan
Public git repository : https://github.com/clapointe2011/public
clapointe is offline   Reply With Quote
Conjugate Heat transfer- Heat generating cylinder & natural convection sandymech OpenFOAM Running, Solving & CFD 6 July 3, 2018 14:40
conjugate heat transfer in OpenFOAM skuznet OpenFOAM Running, Solving & CFD 99 March 16, 2017 06:07
heat flux BC in conjugate heat transfere skuznet OpenFOAM Pre-Processing 8 June 24, 2014 07:00
heat flux on solid surface in conjugate heat transfer skuznet OpenFOAM Pre-Processing 0 December 10, 2013 01:36
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
