Flux at processor boundary
Like Tree1Likes
  • 1 Post By mykkujinu2201
Old   July 18, 2021, 22:49
Default Flux at processor boundary
Jun
mykkujinu2201 is on a distinguished road
Dear Forums,
Currently, I am making a hybrid version of interface capturing method (interFoam) and interface tracking method with references.
Based on interFoam, iso-contour of interface is reconstructed, and capillary force is calculated on the reconstructed interface.
After that flux due to capillary force is calculated based on fixed grid (interFoam).
I tested the code on serial and it works fine.
However, the problem occurs when I run the code in parallel.
Because I considered parallel run, the interface is well reconstructed.
Even so, flow field shows me wrong result.
Because the interface information is correct, I suspect the term related to modifying the flux due to capillary force.
Capillary force is interpolated to fixed grid as surfaceVectorField.
Doing operation of dot product with above and the interface normal vector on the grid, grad(alpha)/mag(grad(alpha)), and rAUf, the flux is calculated.
I additionally considered faces at processor boundary patch.
However, it shows weird result especially when the processor boundary has corner points.
Do you have any opinion about this?
It would be helpful if you give me any advice.
Thank you.
Best,
Jun
mykkujinu2201 is offline   Reply With Quote
Old   July 19, 2021, 02:13
Default strange result report
Jun
Dear Forums,
I set surfaceVector value on processor patch as zero vector and compared the results
I found that the result is exactly same, which means that the flux I applied at surfaceVectorField on processor boundary patch does not work at all.
forAll(mFaceID,loopi)
    label facei = mFaceID[loopi];
    if (mesh.isInternalFace(facei))
        FCapf[facei]=capForce[loopi];
    else
        label pLabel=mesh.boundaryMesh().whichPatch(facei);
        label pFace=facei-mesh.boundaryMesh()[pLabel].start();
        FCapf.boundaryFieldRef()[pLabel][pFace]=capForce[loopi];
I am sorry.
This one is wrong result.
However, still I got the processor boundary issue.
Best,
Jun
Old   July 19, 2021, 12:58
Default more information to explain the situation
Jun
Dear Forums,
I add more to explain my situation.
I am currently trying to solve two-phase flow and I really needed to reconstruct the interface to calculate capillary force directly in order to reduce spurious velocity.
Based on the calculated capillary force, capillary force flux is calculated.
This will be added in pressure equation as below.
    surfaceScalarField phig
          - ghf*fvc::snGrad(rho)
         )*rAUf*mesh.magSf()
        +(FCapf&(fvc::interpolate(fvc::grad(alphaS)/(mag(fvc::grad(alphaS))+VSMALL/dimLength))))*fvc::snGrad(alphaC)*rAUf
When I tested with a serial run, it works fine.
When I tested with parallel run with no processor boundary face having capillary force flux (where processor boundary is orthogonal to the interface), it also works fine.
When I tested with parallel with processor boundary face having capillary force flux (where some faces of processor boundary are not orthogonal to the interface), the solution gets messed.
In addition, the reconstructed interface is well made even the solution gets messed with any parallel run.
Capillary force is directly calculated using the geometry information of the reconstructed interface so capillary force seems to be correct.
Consequently, I suspect the capillary force flux term at processor boundary faces or other reasons.
Do you have any comments?
Thank you.
Best,
Jun
Old   July 20, 2021, 03:26
Default Possible reason?
Jun
Dear Forums,
I found that decomposePar change the surface normal vector direction of processor boundaries.
Would it be the reason?
If so, is there a way for me to correct?
Best,
Jun
Old   July 21, 2021, 11:45
Default Problem solved
Jun
Dear all,
I solved the issue.
It was not the problem due to the flux at processor boundaries.
It was due to other procedures related to parallel computing prior to pressure equation.
Please ignore this thread.
Thank you.
Best,
Jun
Sayyari likes this.
Old   October 24, 2023, 09:58
Mohammed Sayyari
Sayyari is on a distinguished road
I am actually interested to know what were the problems with the other procedures. I am writing a solver with a moving calculated field. I observe some non-physical artifacts at the processor boundary, and cannot fix. I tried so many different calculations and it still produced the same problem.
Sayyari is offline   Reply With Quote
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 02:44
How to use "translation" in solidBodyMotionFunction in OpenFOAM rupesh_w OpenFOAM Running, Solving & CFD 5 August 16, 2016 05:27
Udf for moving heat flux in 2D cylindrical geometry devia21 Fluent UDF and Scheme Programming 0 April 20, 2015 01:27
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
