Saving data from codedMixed BC
Like Tree3Likes
  • 1 Post By rol97
  • 1 Post By crubio.abujas
  • 1 Post By trailer
Old   July 17, 2021, 07:38
Default Saving data from codedMixed BC
Raoul
rol97 is on a distinguished road
Hi everyone,
I am dealing with codedMixed BC and I need to check the value of the variables that are used within the calculation. I wanted to save the values to post-process them and check if the bc are calculated in the correct way. I do not care how they are saved, as long as I am able to access them.
However I am not managing to store such information, I have tried with ofstream inside the bc code, to save the variables as a CSV, but it does not work.
Any advice?
trailer likes this.
rol97 is offline   Reply With Quote
Old   July 19, 2021, 16:30
Carlos Rubio Abujas
crubio.abujas is on a distinguished road
I think that the problem may be that you're executing the code when correcting the boundary condition insted of when you're writting. It would be interesting to see the code though.
If you want to have better control to when is the information written you may try a codedFunctionObject instead.
coded
    libs            ("libutilityFunctionObjects.so");
    type            coded;
    name            codedFunction;
    codeWrite
        word timeName(mesh().time().timeName());
        fileName outputFile (timeName/"mimimi");
        OFstream os(outputFile);
        const scalarField& V = mesh().V();
        const volVectorField& C = mesh().C();
        label patchID = mesh().boundaryMesh().findPatchID("outlet");
        const volVectorField& U = mesh().lookupObject<volVectorField>("U");
        const vectorField& patch = C.boundaryField()[patchID];
        const vectorField& Upatch = U.boundaryField()[patchID];
        os  << "# This is the header of the CSV" << nl
            << "# X , Y, Z, UX, UY, UZ" << nl;
        forAll(patch, facei)
            os << patch[facei].x() << ","
               << patch[facei].y() << ","
               << patch[facei].z() << ","
               << Upatch[facei][0] << ","
               << Upatch[facei][1] << ","
               << Upatch[facei][2] << nl ;
        os << endl;
I've tried this function on OF7 and worked fine. There you can identify the field/patch of interest and write the information.
An alternative may be to write a custom boundary condition and modify the write() method in there.
Give it a try and let's hope it works for you as well.
rol97 likes this.
crubio.abujas is offline   Reply With Quote
Old   July 19, 2021, 17:47
trailer is on a distinguished road
Originally Posted by rol97 View Post
Hi everyone,
Any advice?
Will this be useful? https://www.openfoam.com/documentati...bcs-mixed.html
    "(Patch1|Patch2)"
       type            codedMixed;
       refValue        uniform 0;
       refGradient     uniform 0;
       valueFraction   uniform 0;
       name        test;
       code
           forAll(this->patch(), faceI)
               CodeGoes in here
          Info << (this->refValue()*this->valueFraction() ) + (1-this->valueFraction())*(this->patchInternalField() + this->refGrad()/this->patch().deltaCoeffs()) << endl;
rol97 likes this.
trailer is offline   Reply With Quote
codedmixed, storing data
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 22:00
Run OpenFoam in 2 nodes of a cluster WhiteW OpenFOAM Running, Solving & CFD 16 December 20, 2016 01:51
Fuse Mesh Zone not Saving / Reopening in Case and data jagpreetw FLUENT 0 July 27, 2015 03:59
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 11:52
Urgent : Saving the plot data to a file ck1973 FLUENT 1 July 14, 2006 08:44
