make custom functionObject available with postProcess
Like Tree1Likes
  • 1 Post By Shibi
Old   July 15, 2021, 08:57
Default make custom functionObject available with postProcess
Shibi is on a distinguished road
Hello to all,
I would like to know how to make a custom functionObject available via the postProcess utility in OpenFOAM from ESI (v2012).
As an example, I have duplicated the writeCellCentres functionObject and renamed it as myWriteCellCentres. Did the same inside the .H and .C files.
Prepared a Make folder with (copied from OpenFOAM-v2012/src/functionObjects/field):
files
myWriteCellCentres.C
LIB = $(FOAM_USER_LIBBIN)/libmyFunctionObjects
options
EXE_INC = \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I$(LIB_SRC)/fileFormats/lnInclude \
    -I$(LIB_SRC)/surfMesh/lnInclude \
    -I$(LIB_SRC)/meshTools/lnInclude \
    -I$(LIB_SRC)/sampling/lnInclude \
    -I$(LIB_SRC)/lagrangian/basic/lnInclude \
    -I$(LIB_SRC)/lagrangian/distributionModels/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/basic/lnInclude \
    -I$(LIB_SRC)/transportModels \
    -I$(LIB_SRC)/transportModels/compressible/lnInclude \
    -I$(LIB_SRC)/TurbulenceModels/turbulenceModels/lnInclude \
    -I$(LIB_SRC)/TurbulenceModels/incompressible/lnInclude \
    -I$(LIB_SRC)/TurbulenceModels/compressible/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/solidThermo/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/chemistryModel/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/reactionThermo/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/specie/lnInclude \
    -I$(LIB_SRC)/fvAgglomerationMethods/pairPatchAgglomeration/lnInclude
LIB_LIBS = \
    -lfiniteVolume \
    -lfileFormats \
    -lsurfMesh \
    -lmeshTools \
    -lsampling \
    -llagrangian \
    -ldistributionModels \
    -lfluidThermophysicalModels \
    -lsolidThermo \
    -lincompressibleTransportModels \
    -lturbulenceModels \
    -lcompressibleTransportModels \
    -lincompressibleTurbulenceModels \
    -lcompressibleTurbulenceModels \
    -lchemistryModel \
    -lreactionThermophysicalModels \
    -lpairPatchAgglomeration
In the controlDict I have:
functions
    writeBoundaryCells1
        // Mandatory entries (unmodifiable)
        type            myWriteCellCentres;
        libs            (libmyFunctionObjects.so);
The functionObject work as expected.
When I try to execute it with the postProcess utility with:
postProcess -func myWriteCellCentres -lib myFunctionObjects
I get:
--> FOAM Warning :
    From static bool Foam::functionObjectList::readFunctionObject(const Foam::string&, Foam::dictionary&, Foam::HashSet<Foam::wordRe>&, const Foam::word&)
    in file db/functionObjects/functionObjectList/functionObjectList.C at line 336
     Cannot find functionObject file myWriteCellCentres
What is the correct way of calling a custom functionObject with postProcess?
Mars409 likes this.
Shibi is offline   Reply With Quote
Old   July 17, 2021, 15:44
Anyone can give a hand with this issue?
Old   July 19, 2021, 01:14
Yogesh Bapat
ybapat is on a distinguished road
You can try by including your compiled library in libs entry in controlDict file. This will load your library while running the case and your functionObject should be then available for postProcess utility.
-Yogesh
ybapat is offline   Reply With Quote
Old   July 19, 2021, 04:21
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Try calling postprocces with your function "writeBoundaryCells1" instead. Probably don't need the - lib argument since it is already mentioned in the dictionary.
The function execution is by your function name, not by the type of functionObject.
olesen is offline   Reply With Quote
Old   July 19, 2021, 05:51
trailer is on a distinguished road
Hello Mr. Olesen,
I had no luck with that.
I know you have a very busy schedule but I will attach the case with the functionObject in case your are interested in having a look.
test.zip
trailer is offline   Reply With Quote
Old   October 4, 2023, 03:55
Default Same issue here
Voulet is on a distinguished road
Hi there. I'm facing the same issue. I use the primer openfoam.
I've compilated my custom function object with
LIB = $(FOAM_USER_LIBBIN)/libcalcul_surface_faceFunctionObject
I put this in my controlDict :
functions
    calc_SF
        type            calcul_surface_face;
        libs ("libcalcul_surface_faceFunctionObject.so");
        executeControl  writeTime;
        writeControl    writeTime;
And when doing postProcess -func calcul_surface_face I get the following error:
--> FOAM Warning :
    in file db/functionObjects/functionObjectList/functionObjectList.C at line 290
    Cannot find functionObject file calcul_surface_face
Can any one give insights ?
« Debugging is what CFD is about. 5 minutes to modify your code, 5 months to find why it does not work anymore. »
Voulet is offline   Reply With Quote
Old   October 5, 2023, 19:40
Mark Olesen
try with the foamLibrary utility if your library can even load properly. If it does load then did you also remember to register the function in your code as well?
Old   October 5, 2023, 23:56
Hello Olesen. Thanks for your message. I'm sad because it seems that I'm not enough skilled to fully understand it.
Yes foamHasLibrary -detail libcalcul_surface_faceFunctionObject.so do returns me the lib.
What do you mean by register the function ? I put TypeName("calcul_surface_face"); inside the header of my class declaraction if this is what you means.
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     |
    \\  /    A nd           | www.openfoam.com
     \\/     M anipulation  |
#ifndef functionObjects_calcul_surface_face_H
#define functionObjects_calcul_surface_face_H
#include "fvMeshFunctionObject.H"
namespace Foam
namespace functionObjects
                       Class calcul_surface_face Declaration
class calcul_surface_face
    public fvMeshFunctionObject
public:
    //- Runtime type information
    // Constructors
        //- Construct from Time and dictionary
        calcul_surface_face
            const word& name,
            const Time& runTime,
            const dictionary& dict
        //- No copy construct
        calcul_surface_face(const calcul_surface_face&) = delete;
        //- No copy assignment
        void operator=(const calcul_surface_face&) = delete;
    //- Destructor
    virtual ~calcul_surface_face() = default;
    // Member Functions
        //- Read the cell-volume data
        virtual bool read(const dictionary&);
        //- Do nothing
        virtual bool execute();
        //- Write the cell-volume fields
        virtual bool write();
} // End namespace functionObjects
} // End namespace Foam
#endif
Old   October 6, 2023, 05:36
Mark Olesen
You need something like this (but of course with your own function):
#include "addToRunTimeSelectionTable.H"
namespace Foam
    defineTypeNameAndDebug(grad, 0);
    addToRunTimeSelectionTable(functionObject, grad, dictionary);
Old   October 6, 2023, 05:50
Yes I have it :
   \\    /   O peration     |
     \\/     M anipulation  |
    Copyright (C) 2016 OpenFOAM Foundation
    Copyright (C) 2016-2020 OpenCFD Ltd.
License
    This file is part of OpenFOAM.
    OpenFOAM is free software: you can redistribute it and/or modify it
    under the terms of the GNU General Public License as published by
    the Free Software Foundation, either version 3 of the License, or
    (at your option) any later version.
    OpenFOAM is distributed in the hope that it will be useful, but WITHOUT
    ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
    FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License
    for more details.
    You should have received a copy of the GNU General Public License
    along with OpenFOAM.  If not, see <http://www.gnu.org/licenses/>.
#include "calcul_surface_face.H"
#include "surfaceFields.H"
#include "fvMesh.H"
#include "Time.H"
// * * * * * * * * * * * * * * Static Data Members * * * * * * * * * * * * * //
namespace Foam
    defineTypeNameAndDebug(calcul_surface_face, 0);
    addToRunTimeSelectionTable(functionObject, calcul_surface_face, dictionary);
// * * * * * * * * * * * * * * * * Constructors  * * * * * * * * * * * * * * //
Foam::functionObjects::calcul_surface_face::calcul_surface_face
    const word& name,
    fvMeshFunctionObject(name, runTime, dict)
    read(dict);
// * * * * * * * * * * * * * * * Member Functions  * * * * * * * * * * * * * //
bool Foam::functionObjects::calcul_surface_face::read(const dictionary& dict)
    return fvMeshFunctionObject::read(dict);
bool Foam::functionObjects::calcul_surface_face::execute()
    return true;
bool Foam::functionObjects::calcul_surface_face::write()
    surfaceVectorField Sf
        IOobject
            mesh_.Sf().name(),
            time_.timeName(),
            mesh_,
            IOobject::NO_READ,
            IOobject::NO_WRITE,
            IOobject::NO_REGISTER
        mesh_,
        Zero
    Sf.ref() = mesh_.Sf();
    // Without correctBoundaryConditions() - boundary faces have zero volume
    Log << type() << " " << name() << " write:" << nl
        << "    writing cell-face area field Sf"
        << " to " << time_.timeName() << endl;
    Sf.write();
    return true;
Old   October 6, 2023, 06:05
In fact when I run it on a tutorial case with one of the following comand :
or
postProcess
it does works !
But the openfoam case I wanted to treat was an old case which was run with openfoam8. With this case : (using ofv23 and the objectFunction compiled with ofv23)
postProcess -func calcul_surface_face doesn't find the function
or
postProcess works
This is quite strange but I suppose my issue is solved.
Thanks Olesen
postProcess functionality in openFOAM 4 bullmut OpenFOAM Post-Processing 23 July 21, 2017 10:11
OF-4.x: Multiple Inheritance of a functionObject A_Pete OpenFOAM Programming & Development 1 September 21, 2016 11:01
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
Create registered object at runtime using a functionObject CedricVH OpenFOAM Programming & Development 21 November 28, 2012 06:04
a way to make lots of money quick and easy no lies Dob Main CFD Forum 0 October 10, 2006 17:45
