fvmLaplacianUncorrected
Like Tree2Likes
  • 1 Post By deepsterblue
Old   June 18, 2021, 13:23
Default fvmLaplacianUncorrected
ecles is on a distinguished road
Hello!
I have been trying to become acquainted with OpenFOAM code. Nonetheless I got stuck in one thing.
In gaussLaplacianScheme.C, we have the following line of code in fvmLaplacian routine:
tmp<fvMatrix<Type>> tfvm = fvmLaplacianUncorrected
SfGammaSn,
this->tsnGradScheme_().deltaCoeffs(vf),
vf
The object of the second parameter passed should belong to a surfaceScalarField class:
template<class Type, class GType>
tmp<fvMatrix<Type>>
gaussLaplacianScheme<Type, GType>::fvmLaplacianUncorrected
const surfaceScalarField& gammaMagSf,
const surfaceScalarField& deltaCoeffs,
const GeometricField<Type, fvPatchField, volMesh>& vf
Nonetheless, deltaCoeffs(vf), a pure virtual function declared in snGradScheme.H, is set to return a tmp pointer.
virtual tmp<surfaceScalarField> deltaCoeffs
) const = 0;
Should it not be returned as a surfaceScalarField object? What am I missing here? Is there any implicit conversion taking place?
Thank you!
ecles is offline   Reply With Quote
Old   June 20, 2021, 10:57
Sandeep Menon
deepsterblue will become famous soon enough
The GeometricField class (from which surfaceScalarField is defined) has a constructor that operates on a tmp object. The tmp class also has a const dereference operator overload, which implicitly converts a tmp object to a const reference (check tmp.H). All of this allows tmp objects to be implicitly convertible to the underlying GeometricField, while including reference counting capabilities.
ecles likes this.
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   July 13, 2021, 22:29
Just to be sure I understood, is the implicit conversion implemented in this routine?
template<class T>
inline Foam::tmp<T>::operator const T&() const
return operator()();
Old   July 14, 2021, 10:22
Sandeep Menon
Yup - that's the one.
ecles likes this.
Sandeep Menon
fvm::laplacian, laplacianscheme
