Face pressure interpolation scheme based on linear interpolation |
Rep Power: 6 ![]() |
Hello to all,
I would like to create a new interpolation scheme for the face pressure. Traditionally this is estimated by a linear interpolation scheme, where: ![]() where ![]() Can anyone point me to which class(classes) I should change in OpenFoam to implement something based on this linear interpolation scheme for the pressure? Best Regards! |
Rep Power: 14 ![]() |
Typically pressure enters the transport equations through the laplacian term, and the discretisation of this is linear because that is consistent with the finite volume approach.
Using anything other than linear is pretty unorthodox, but I guess you could try setting the laplacianScheme for pressure to something other than linear ... i would strongly recommend rethinking this, though. Can I ask why you want to apply something other than linear? |
#3 | |
Hi, Sure, I want to define a density weighted interpolation scheme for the face pressure: Where: ![]() This is for multi-phase flow where the linear interpolation should introduce considerable numerical errors if the pressure gradient at cell P and N differ greatly. |
So,
I guess a good starting point could be the linear interpolation scheme at: Code:
/OpenFOAM/OpenFOAM-v2012/src/finiteVolume/interpolation/surfaceInterpolation/schemes/linear and change the weights() function. Since this->mesh().surfaceInterpolation::weights() will get the linear interpolation weights I think I just need to access the density at cell P and N. But I am not sure on how to do this. Any suggestions would be highly appreciated. |
The cell values on either side of a given face are addressed using the lduAddressing functions lower() and upper(), with the face number being the index. Take a look at fvmDiv for an example of them in action, and good luck.
Hello to all,
Some new updates. When you do fvc::grad(p), the solver will go though several files, namely: fvcGrad.C, gradScheme.C, linear.H , surfaceInterpolation.C, basicFvGeometryScheme.C (if you do not have the linear weights), surfaceInterpolationScheme.C. Of special importance to this problem are the surfaceInterpolationScheme.C and linear.H files. In linear.H the weights will be computed as: Code:
forAll(owner, facei) { // Note: mag in the dot-product. // For all valid meshes, the non-orthogonality will be less than // 90 deg and the dot-product will be positive. For invalid // meshes (d & s <= 0), this will stabilise the calculation // but the result will be poor. scalar SfdOwn = mag(Sf[facei] & (Cf[facei] - C[owner[facei]])); scalar SfdNei = mag(Sf[facei] & (C[neighbour[facei]] - Cf[facei])); w[facei] = SfdNei/(SfdOwn + SfdNei); } Code:
for (label fi=0; fi<P.size(); fi++) { sfi[fi] = Sfi[fi] & (lambda[fi]*(vfi[P[fi]] - vfi[N[fi]]) + vfi[N[fi]]); } Sfi[fi] being a vector of ones (for the time being I do not know what this operation exists), vfi[P[fi]] the value of the variable at cell P (owner) vfi[N[fi]] the value of the variable at cell N (neighbor) The above expression, mathematically, reads: ![]() ![]() ![]() For my case, to implement a density weighted interpolation scheme it seems that openFoam is "too" hard-coded into the linear interpolation (where a unique weighting parameter is defined). I could of course rewrite the dotInterpolate function in the source code to accommodate my needs, but I would really prefer not to. Would really appreciate some suggestions on this issue! Edit: this is solved. Just had to redefine the correct template functions Best Regards Last edited by Shibi; June 23, 2021 at 08:36. |
René Thibault
Hi Shibi!
Really glad that you were able to find a solution to your challenge. I am trying to implement a new interpolation scheme also, but for the velocity U. My friend and I tried a different approach then yours, but it doesn't work for some reason and I cant find the bug. It compile and everything without error, but the results are not affected at all. Here is the link to the GitHub repository: https://github.com/RTibo/OpenFOAM-Ne...ation-Scheme-U So, I was thinking about changing the method by using a 'weighting' factor and then I found your post. It basically the same thing that I'm trying to implement. The only thing that will differ probably is the 'weighting' factor equation (eq. 45, see image). Since I needed the same equation in my previous code, the 'weight' equation factor is already coded, but I don't know where to implement this 'weight' factor code snippet in the file linear.H. Since you said in your last post that you make it work by using the file linear.H as a starting point, which template functions you redefine exactly? Thank you very much for your help and consideration. Best Regards, René Link of the paper (Eq. 44 & 45): https://onlinelibrary.wiley.com/doi/10.1002/fld.2709 |
If you only want to change the weights, write a new weights function.
See if this is useful: https://github.com/UnnamedMoose/Basi...discretisation |
#9 |
René Thibault
Thanks for answering!
From what I look quickly, the scheme of the tutorial interpolate the actual weights from the center of cells to the face of the cells (horizontal and vertical). The weights function that I need to code is depending of 'z' (see eq. 45 in my previous post), but it only apply at the horizontal face of the cells. That means, the weights of the vertical face of the cell is 1. So, what I conclude is, I don't need to interpolate the weights from the center of the cells, but assign the weights of the horizontal face of the cell directly. Then, use this 'weights' as 'lambda' in the file 'surfaceInterpolationScheme.C'. I don't know if I can make it work that way? Or is there a better approach? What is your thoughts? Thank you again for replying! René Last edited by Tibo99; February 14, 2022 at 15:39. |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
pimpleFoam in OF1612 shows same time step twice in log file | shang | OpenFOAM Bugs | 10 | January 24, 2018 10:43 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
Explicit Pressure Based Scheme | Apurva | Main CFD Forum | 4 | June 3, 2004 20:01 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
