Polynomial in cellLimited<cubic> seems dodgy
Like Tree2Likes
  • 2 Post By scleakey
Old   June 2, 2021, 06:40
Lightbulb Polynomial in cellLimited<cubic> seems dodgy
Shannon Leakey
scleakey is on a distinguished road
Hello
After having some convergence problems in a Godunov-type scheme I programmed in OpenFOAM, I have been investigating the source code for the gradScheme cellLimited<cubic> in src/finiteVolume/finiteVolume/gradSchemes/limitedGradSchemes/cellLimitedGrad/gradientLimiters/cubicGradientLimiter.H
The paper it is based on (Michalak and Ollivier-Gooch, 2008) says that the limiter function should be a cubic polynomial P(r) with P(r = 0) = 0, P(r = t) = 1, P'(r = 0) = 1, P'(r = t) = 0. By my calculations, this should be:
P(r) = ar^3 + br^2 + r
a = (t - 2)/(t^3)
b = - (3at^2 + 1)/(2t)
https://www.wolframalpha.com/input/?...+and+t+%3D+1.5
But the source code says:
a = 2/t^2 - 2/t^3
b = - (3/2)at
The Wolfram|Alpha graphs (shown for t = 1.5) suggest that P'(r = t) is definitely not zero for the polynomial that is in the OpenFOAM code. Coincidentally, I initially ended up with the same coefficients as in the OpenFOAM code when I accidentally said the derivative of r with respect to r was 0 and not 1 when incorporating the constraint P'(r = t), then I plotted the graphs and realised something was wrong.
Is this a mistake in the code or do I just not understand it properly?
Thanks,
Shannon
Last edited by scleakey; June 4, 2021 at 05:26. Reason: change "y" to "r" in last paragraph
scleakey is offline   Reply With Quote
Old   June 3, 2021, 11:40
Tobermory will become famous soon enough
Perhaps worth dropping a bug report?
Tobermory is offline   Reply With Quote
Old   June 9, 2021, 05:53
Shannon Leakey
I submitted a bug report https://develop.openfoam.com/Develop.../-/issues/2113 and it is getting fixed
saladbowl and Tobermory like this.
Old   June 9, 2021, 05:57
Well done - the system works! Thanks for putting the effort in to get this fixed for us all.
Fluent UDF - polynomial profile description mihnea333 FLUENT 0 February 26, 2021 04:19
Error: GENERAL CAR CDR - User-Defined-Material-Database EvaKn FLUENT 0 December 21, 2020 09:01
Add piecewise polinomial material property EvaKn FLUENT 0 December 21, 2020 07:03
thermophysicalProperties with polynomial values Gerrit OpenFOAM Running, Solving & CFD 4 April 21, 2020 11:51
polynomial BC from 3d vector data map OpenFOAM Programming & Development 0 March 30, 2015 09:48
