March 20, 2021, 17:30 |
InterFoam letting one phase leave the domain
Rep Power: 6 |
Hello to all,
I would like to simulate the flow of a liquid and gas with InterFoam. I would like to have one of the phases (the gas) to leave the domain while the other (the liquid) fills the domain. Does OpenFOAM have any boundaries for this? What do you recommend to achieve this? Would it be achievable with a custom boundary condition that dynamically changes from outlet to wall based on the value of alpha? Best regards |
March 28, 2021, 12:12 |
Rep Power: 6 |
So, apparently this question has been going around in the forum for several years without a proper answer.
Some questions I still have:
myOutlet { type codedMixed; refValue uniform (0 0 0); refGradient uniform (0 0 0); valueFraction uniform 0; name dynamicOutlet; code #{ // Code goes here // Gets the alpha field scalarField alphap = patch().lookupPatchField<volScalarField, scalar>("alpha.liquid"); alphap = max(alphap, scalar(0)); alphap = min(alphap, scalar(1)); // write value as a function of alpha this->valueFraction() = alphap; #}; } if alpha = 1, we get a pure fixedValue if alpha =0 , we get a pure zeroGradient Any contribution would be very welcome! |
March 28, 2021, 12:35 |
Michael Alletto
Rep Power: 16 |
For a rising air bubble in water I applied zeruGradient for alpha and this https://www.openfoam.com/documentati...alarField.html
For prgh at the upper boundary. In this way the air bubble left the upper boundary |
March 29, 2021, 08:05 |
Rep Power: 6 |
After some reading, I need to implement something like this: with: So, the first one is a no-slip boundary which is straightforward to implement. Just need to loop over the patch faces and check the value of alpha is higher than 0.5 (or any specified value for alpha). If so, I set Code:
this->refValue()[faceI] = vector::zero; this->valueFraction()[faceI] = 1.0; Any help be appreciated! |
March 29, 2021, 09:09 |
Rep Power: 5 |
Although I do not have any input to give you, I am also interested in this matter! Best of luck! |
March 29, 2021, 11:04 |
Michael Alletto
Rep Power: 16 |
March 30, 2021, 13:12 |
#7 | |
Rep Power: 6 |
Wouldn't it be better to create two boundaries. One that switches from zero velocity gradient to zero FixedValue and another for pressure that switches from fixedValue to zeroGradient? |
April 1, 2021, 08:58 |
Rep Power: 6 |
Can anyone confirm this approach?
I have implemented this dynamic boundary, but now I am facing several convergence issues because the initial state of the problem has imposed value of pressure everywhere expect at the inlet ... |
April 5, 2021, 12:51 |
#9 |
Michael Alletto
Rep Power: 16 |
Can you sketch your case? From the description above it's hard to guess what the exact problem is
April 6, 2021, 06:17 |
#10 | |
Rep Power: 6 |
Sure, Filling of a plate with water (other kind of fluid) with air inside the cavity. The water enters through an inlet and all other patches in the geometry should behave like a dynamic wall, letting the air out and keeping the water in. |
April 6, 2021, 06:48 |
#11 |
Michael Alletto
Rep Power: 16 |
Where is the outlet and where the walls. The direction of g is missing
April 6, 2021, 07:12 |
#12 | |
Rep Power: 6 |
There is no outlet (at least explicitly specified). The walls should behave like an outlet up to and alpha of 0.5 and as a wall for values higher than 0.5 . Gravity is not being considered in this problem. |
April 6, 2021, 08:57 |
#13 |
Michael Alletto
Rep Power: 16 |
This seem a good solution. How did you implement this. Seem you wrote a new boundary conditions
April 6, 2021, 13:10 |
#14 |
Bruno Ramoa
Rep Power: 7 |
I would also be very interested in this kind of boundary! Based on your previous input, I wrote for U: Code:
wall { type codedMixed; refValue uniform (0 0 0); refGradient uniform (0 0 0); valueFraction uniform 0; name dynamicOutlet; code #{ scalarField alphap = patch().lookupPatchField<volScalarField, scalar>("alpha.liquid"); alphap = max(alphap, scalar(0)); alphap = min(alphap, scalar(1)); const scalar alphaValue = 0.5; // Loops over the patch forAll(patch(), faceI) { if(alphap[faceI] > alphaValue) { // Imposes fixedValue this->refValue()[faceI] = vector::zero; this->valueFraction()[faceI] = scalar(1); } else { // Imposes zeroGradient this->refGrad()[faceI] = vector::zero; this->valueFraction()[faceI] = scalar(0); } } #}; } and for P Code:
wall { type codedMixed; refValue uniform 0; refGradient uniform 0; valueFraction uniform 1; name dynamicOutlet; code #{ scalarField alphap = patch().lookupPatchField<volScalarField, scalar>("alpha.liquid"); alphap = max(alphap, scalar(0)); alphap = min(alphap, scalar(1)); const scalar alphaValue = 0.5; // Loops over the patch forAll(this->patch(), faceI) { if (alphap[faceI] > alphaValue) { // Imposes zeroGradient this->refGrad()[faceI] = scalar(0); this->valueFraction()[faceI] = scalar(0); } else { // Imposes fixedValue this->refValue()[faceI] = scalar(0); this->valueFraction()[faceI] = scalar(1); } } #}; } For: U: Fixed velocity on the inlet, no-slip for the walls and zeroGradient for the outlet. P: ZeroGradient for the inlet and the walls and fixedValue for the outlet The simulation worked fine. However, with the codedMixed boundary the convergence is not good... Hopefully the code will get you started and someone else can fill in with a little CFD magic to make the boundary more well behaved |
April 21, 2021, 05:34 |
#15 |
Rep Power: 6 |
Any suggestions on a possible strategy to improve the convergence of this boundary condition?
Best Regards! |
August 17, 2022, 09:05 |
#16 | |
Julian Re
Rep Power: 4 |
Hey Shibi, you made any progress imroving convergence for the coded BC? I found this custom BC in the web; within the paper the code of the BC is also linked!: https://www.emerald.com/insight/cont...0190/full/html However, in my case this BC blows up my simulation within the first iterations... |
boundary conditions, interfoam |
[ICEM] How to generate an unstructured mesh for a 2 fluid domain rotor in ICEM CFD | Hazem24 | ANSYS Meshing & Geometry | 0 | December 21, 2020 07:52 |
UDF to constrain one of the phase to stay in the domain | Koromajor | Fluent UDF and Scheme Programming | 23 | April 15, 2020 20:21 |
interFoam high air phase velocities | indy07cz | OpenFOAM Running, Solving & CFD | 1 | November 8, 2017 06:00 |
Sudden increase the residual of Maxwell's equations | hsezsz | CFX | 2 | October 13, 2016 07:58 |
phase fraction part of domain | RBJ | OpenFOAM Post-Processing | 0 | July 6, 2010 10:33 |
