fvOptions - sign for sources in scalarCodedSource
Like Tree3Likes
  • 1 Post By user
  • 1 Post By mAlletto
  • 1 Post By sharonyue
Old   March 17, 2021, 16:22
Default fvOptions - sign of sources in scalarCodedSource
user is on a distinguished road
Hello foamers,
I'm struggling with adding a heat source via scalarCodedSource because it seems that negative values are needed to have a positive source.
For further investigations I made a simple test case with rhoPimpleFoam where I used a scalarSemiImplicitSource in a cellZone to define a positive heat source in a closed system:
heatSource1
    type            scalarSemiImplicitSource;
    active          true;
    scalarSemiImplicitSourceCoeffs
        selectionMode   cellZone; // all, cellSet, cellZone, points
        cellZone        sourceZone;
        volumeMode      absolute;
        injectionRateSuSp
            h   (0.1 0);
and additionally a scalarCode which simply reads out the eqn.source() and printing the sum of it:
heatSource2
    type            scalarCodedSource;
    active          true;
    name            heatSource2;
    scalarCodedSourceCoeffs
        fields          (h);
        codeInclude
        codeCorrect
        codeAddSup
            scalarField& hSource = eqn.source();
            const scalarField& V = mesh_.V();
            double hSourceTot = 0;
            forAll(V, i)
                hSourceTot += hSource[i];
            Pout << " hSourceTot = " << hSourceTot << " with dimension " << eqn.dimensions() << endl;
        codeConstrain
        code
            $codeInclude
            $codeCorrect
            $codeAddSup
            $codeSetValue
In the above case the toal sum of the heat sources are "-0.1" - a negative value. Could somebody explain why sources in scalarCodedSources must be negative? Is this specific to the energy equation?
I tested it with OpenFOAM-v2006 and v2012 and have attached the test case. Just unpack and run "./runMesh" and after that rhoPimpleFoam
Thanks in advance
Ulf
saladbowl likes this.
user is offline   Reply With Quote
Old   March 20, 2021, 09:29
Michael Alletto
mAlletto will become famous soon enough
If I'm not mistaken, the function below gives you a reference to the source of the whole equation (the term on the right hand side the equation . If you are solving the temperature equation there is not only coded source in it but a lot more staff. Think about the laplacian discretization on non ortognonal grids. There you get also explicit source term.
eqn.source();
mAlletto is offline   Reply With Quote
Old   March 22, 2021, 15:39
Yes, thanks for your reply - your are absolutely right and I also thought about this. That's why I tested it without the scalarSemiImplicitSource and then the reported sources from scalarCodedSource is zero.
Any ideas? I also looked at the code and couldn't find any difference (regarding the sign) between scalarCoded and scalarSemiImplicit. Maybe some C/C++ expert could analyse this ;-)
Old   August 30, 2021, 13:01
Zhen WANG
zhenFoam is on a distinguished road
Hello, everyone
I'm stuck with the same problem. Can someone please explain?
1. why sources in scalarCodedSources must be negative?
2. why sources in scalarCodedSources always multiply by voluMe V[i] ?
zhenFoam is offline   Reply With Quote
Old   September 3, 2021, 09:24
René Thibault
Tibo99 is on a distinguished road
This maybe could answer your question #2 (see picture in attachment).
I don't have the answer for your 1st question though. I encounter the same question and don't have the answer yet.
If someone can answer this one, it would be appreciated.
Best Regards,
Tibo99 is offline   Reply With Quote
Old   September 3, 2021, 09:59
Michael Alletto
the answer to queston 2 is that if you discretize a source term in a fine volume framework you integrate it over the cell volume. For a source term which is constant in the volume (this is the usual assumption made) you have to multiply it by the cell volume
SHUBHAM9595 likes this.
Old   September 3, 2021, 10:53
Zhen WANG
I got it! Great thanks for your reply @Tibo99, @mAlletto
Could somebody explain the queston 2: why sources in scalarCodedSources must be negative?
Old   September 3, 2021, 11:02
René Thibault
You mean question 1?
Old   September 3, 2021, 20:28
Zhen WANG
Yes, I mean question 1. Sorry for the type error.
Old   September 4, 2021, 04:44
Michael Alletto
Can you formulate your question a bit more clearly?
Old   March 10, 2023, 07:06
Dongyue Li
sharonyue is on a distinguished road
I run into this problem today. I did some research. I think its because of the following:
code.template<class Type>
Foam::tmp<Foam::fvMatrix<Type>> Foam::operator==
    const fvMatrix<Type>& A,
    const fvMatrix<Type>& B
    checkMethod(A, B, "==");
    return (A - B);
ShaneheSSSS likes this.
My OpenFOAM algorithm website: http://dyfluid.com
By far the largest Chinese CFD-based forum: http://www.cfd-china.com/category/6/openfoam
We provide lots of clusters to Chinese customers, and we are considering to do business overseas: http://dyfluid.com/DMCmodel.html
sharonyue is offline   Reply With Quote
Howto use scalarCodedSource in fvOptions hanness OpenFOAM Running, Solving & CFD 61 November 18, 2022 13:11
scalarCodedSource fvOptions example moving heat source superkelle OpenFOAM Running, Solving & CFD 1 March 4, 2021 16:59
Configuration of boundary conditions and fvOptions file Raza Javed OpenFOAM Running, Solving & CFD 16 May 3, 2019 17:35
[ICEM] ICEM wind tunnel sign panel mesh tigerdroppings ANSYS Meshing & Geometry 5 July 30, 2018 14:28
reading in a field into fvOptions with type: scalarCodedSource Ali Blues OpenFOAM Programming & Development 4 June 7, 2018 11:25
