undefined symbol - could not load library
Like Tree4Likes
  • 1 Post By Kosdalak
  • 2 Post By nainavinod
Old   February 26, 2021, 03:53
Default undefined symbol - could not load library
Jan
Kosdalak is on a distinguished road
Hey,
I'm currently trying to implement my own RSM Model in OF.
For that I just copied the SSG Files in a new directory with the goal to change them later.
Before that I tried to compile them after changing their names and all appearances in the files. No Errors so far (nothing really changed, so why should be there erros?). I was using the "makeTemplatedTurbulenceModel" macro. That's the way you should implement your own model, right?
Now, I started a test run with the "new" model. Not found... I got a small warning directly at the start (loading my own, new library with the model):
--> FOAM Warning :
    From function void* Foam::dlOpen(const Foam::fileName&, bool)
    in file POSIX.C at line 1251
    dlopen error : /home/xxx/OpenFOAM/xxx-X/platforms/linux64GccDPInt32Opt/lib/libmySSGLRR.so: undefined symbol: _ZN4Foam8RASModelINS_29IncompressibleTurbulenceModelINS_15turbulenceModelEEEE8typeNameE
--> FOAM Warning :
    From function bool Foam::dlLibraryTable::open(const Foam::fileName&, bool)
    in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 105
    could not load "libmySSGLRR.so"
Obviously, the library was not load because of a undefined symbol. I figured out it could help to load an extra library with this symbol within it.
BUT there is no library with this symbol in it (at least not in the normal directory...)
I using OF Version 7 on Ubuntu 20.04.1 LTS.
Does anybody have an idea how I can solve this problem?
Thanks in advance!
Jan
lpz456 likes this.
Kosdalak is offline   Reply With Quote
Old   February 26, 2021, 05:04
Agustín Villa
agustinvo is on a distinguished road
as far as I know, it's better if you replicate the existing files structure in your OF user directory, instead of generating your own library like this. It can also help to implement more models in the future. At least, this is what I do and I had no problems until now.
PS: I'm curious about the RSM model you want to implement. ¿Which one is it?
agustinvo is offline   Reply With Quote
Old   February 26, 2021, 05:11
Jan
I have to admit thats a good idea. You mean just copy the whole installation of OF and than change the "original" models?
I want to try the SSG-LRR omega model proposed by Eisfeld. The basic idea is to combine the SSG and the LRR with a omega equation and to create a low Re model (like Menters SST).
The (I believe original paper) is:
"REYNOLDS STRESS MODELLING FOR COMPLEX AERODYNAMIC
FLOWS" from Bernhard Eisfeld.
You can also check the NASA website:
https://turbmodels.larc.nasa.gov/rsm-ssglrr.html
lpz456 likes this.
Old   February 26, 2021, 10:31
Agustín Villa
The idea is to replicate the folders structure. Then, on the wmake files tou just link these libraries to the ones of the installation if needed (e.g. when compiling a new turbulence model just link it to the turbulence model).
Old   February 26, 2021, 13:19
clapointe is on a distinguished road
To add to the discussion, for OF7 specifically, what I've done in the past is :
Like was suggested make folders in e.g. your project directory for src/TurbulenceModels/turbulenceModels/RAS and src/TurbulenceModels/compressible (or incompressible)
Then just add new code, without replicating native code, in each folder respectively. An example for compressible LES models can be found here : https://github.com/clapointe2011/public/tree/master/of7. The resulting library can be loaded at runtime to use your custom model.
Caelan
clapointe is offline   Reply With Quote
Old   June 29, 2022, 07:08
pisharoti05
nainavinod is on a distinguished road
Hey Jan!
This might be late, but I have succesfully implemented the SSG/LRR-omega fully turbulent model by Eisfeld et al., (that you're referring to) on OpenFOAM-v2006. You can find the code here:
https://github.com/nainapisharoti/SSG-LRR-omega-gamma
You can find the complete code for the SSG/LRR-omega model in the "Base folder". The "RAS" folder also has the makeTurbulenceModel.C script which you just have to compile using "wmake" and you should be good to go.
I had implemented the fully turbulent model to formulate my transition model SSG/LRR-omega-gamma. If you're interested, you can find the code for that as well in the same repository.
Good luck!
Naina.
lpz456 and shuji_type97 like this.
nainavinod is offline   Reply With Quote
Old   February 15, 2024, 11:20
ASR
sr786 is on a distinguished road
I know this is an old thread but I am also looking into implementing changes with the Reynolds Stress models using OpenFOAM. All I am looking to do is simplify the DREff() term in the .C file. I am using OpenFOAM-v9.
Prior to introducing any changes to the source code I am first sorting out compiling a new turbulence model.
I have found that I am really struggling to compile either the LRR or SSG model in the OpenFOAM environment as compared to compiling a eddy viscosity model.
Here are my Make files
Options
  EXE_INC = \
    -I$(LIB_SRC)/MomentumTransportModels/momentumTransportModels/lnInclude \
    -I$(LIB_SRC)/MomentumTransportModels/incompressible/lnInclude \
    -I$(LIB_SRC)/transportModels/lnInclude \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I$(LIB_SRC)/meshTools/lnInclude \
LIB_LIBS = \
    -ltransportModels \
    -lmomentumTransportModels \
    -lfiniteVolume \
    -lmeshTools
Files
mykinematicMomentumTransportModels.C
LIB = $(FOAM_USER_LIBBIN)/mykinematicMomentumTransportModels
I am getting the following error message
  wmake libso .
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file mykinematicMomentumTransportModels.C
g++ -std=c++14 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3  -DNoRepository -ftemplate-depth-100 -I/home/cfd/OpenFOAM/OpenFOAM-9/src/MomentumTransportModels/momentumTransportModels/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/MomentumTransportModels/incompressible/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/transportModels/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/finiteVolume/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/meshTools/lnInclude  -IlnInclude -I. -I/home/cfd/OpenFOAM/OpenFOAM-9/src/OpenFOAM/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/OSspecific/POSIX/lnInclude   -fPIC -c mykinematicMomentumTransportModels.C -o Make/linux64GccDPInt32Opt/mykinematicMomentumTransportModels.o
In file included from myLRR.H:219:0,
                 from mykinematicMomentumTransportModels.C:49:
myLRR.C: In instantiation of ‘Foam::RASModels::myLRR<BasicMomentumTransportModel>::myLRR(const alphaField&, const rhoField&, const volVectorField&, const surfaceScalarField&, const surfaceScalarField&, const transportModel&, const Foam::word&) [with BasicMomentumTransportModel = Foam::IncompressibleMomentumTransportModel<Foam::kinematicTransportModel>; Foam::RASModels::myLRR<BasicMomentumTransportModel>::alphaField = Foam::geometricOneField; Foam::RASModels::myLRR<BasicMomentumTransportModel>::rhoField = Foam::geometricOneField; Foam::volVectorField = Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>; Foam::surfaceScalarField = Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>; Foam::RASModels::myLRR<BasicMomentumTransportModel>::transportModel = Foam::kinematicTransportModel]’:
/home/cfd/OpenFOAM/OpenFOAM-9/src/MomentumTransportModels/momentumTransportModels/lnInclude/RASModel.H:100:9:   required from ‘static Foam::autoPtr<Foam::RASModel<BasicMomentumTransportModel> > Foam::RASModel<BasicMomentumTransportModel>::adddictionaryConstructorToTable<RASModelType>::New(const alphaField&, const rhoField&, const volVectorField&, const surfaceScalarField&, const surfaceScalarField&, const transportModel&) [with RASModelType = Foam::RASModels::myLRR<Foam::IncompressibleMomentumTransportModel<Foam::kinematicTransportModel> >; BasicMomentumTransportModel = Foam::IncompressibleMomentumTransportModel<Foam::kinematicTransportModel>; Foam::RASModel<BasicMomentumTransportModel>::alphaField = Foam::geometricOneField; Foam::RASModel<BasicMomentumTransportModel>::rhoField = Foam::geometricOneField; Foam::volVectorField = Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>; Foam::surfaceScalarField = Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>; Foam::RASModel<BasicMomentumTransportModel>::transportModel = Foam::kinematicTransportModel]’
/home/cfd/OpenFOAM/OpenFOAM-9/src/MomentumTransportModels/momentumTransportModels/lnInclude/RASModel.H:100:9:   required from ‘Foam::RASModel<BasicMomentumTransportModel>::adddictionaryConstructorToTable<RASModelType>::adddictionaryConstructorToTable(const Foam::word&) [with RASModelType = Foam::RASModels::myLRR<Foam::IncompressibleMomentumTransportModel<Foam::kinematicTransportModel> >; BasicMomentumTransportModel = Foam::IncompressibleMomentumTransportModel<Foam::kinematicTransportModel>]’
mykinematicMomentumTransportModels.C:50:1:   required from here
myLRR.C:219:14: error: ‘bound’ was not declared in this scope
         bound(epsilon_, this->epsilonMin_);
myLRR.C:219:14: note: suggested alternative: ‘found’
         found
myLRR.C: In instantiation of ‘void Foam::RASModels::myLRR<BasicMomentumTransportModel>::correct() [with BasicMomentumTransportModel = Foam::IncompressibleMomentumTransportModel<Foam::kinematicTransportModel>]’:
mykinematicMomentumTransportModels.C:50:20:   required from here
myLRR.C:325:10: error: ‘bound’ was not declared in this scope
myLRR.C:325:10: note: suggested alternative: ‘found’
     found
make: *** [/home/cfd/OpenFOAM/OpenFOAM-9/wmake/rules/General/transform:26: Make/linux64GccDPInt32Opt/mykinematicMomentumTransportModels.o] Error 1
I have no clue as to why this has happened. As you guys have managed to successfully implement a new RSM could I please have some guidance on why I can't compile LRR?
A link to the thread I originally published is provided OpenFOAM - Implement Change To Modelled Term Reynolds Stress Models (LRR & SSG)
sr786 is offline   Reply With Quote
Old   February 15, 2024, 11:33
pisharoti05
Hey! It seems like you might be missing some header file declarations. Have you made sure you have included the following lines in your header file?
#include "RASModel.H"
#include "ReynoldsStress.H"
Can you also share the way you have declared your model class at the beginning of your header file?
Maybe you're missin some step there.
Regards,
Naina.
Old   February 15, 2024, 13:45
ASR
For myLRR.H, both RASModel.H and ReynoldsStress.H have been declared as I have not made any changes to the files barring changing LRR to myLRR
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Copyright (C) 2011-2021 OpenFOAM Foundation
     \\/     M anipulation  |
License
    This file is part of OpenFOAM.
    OpenFOAM is free software: you can redistribute it and/or modify it
    under the terms of the GNU General Public License as published by
    the Free Software Foundation, either version 3 of the License, or
    (at your option) any later version.
    OpenFOAM is distributed in the hope that it will be useful, but WITHOUT
    ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
    FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License
    for more details.
    You should have received a copy of the GNU General Public License
    along with OpenFOAM.  If not, see <http://www.gnu.org/licenses/>.
Class
Description
    Launder, Reece and Rodi Reynolds-stress turbulence model for
    incompressible and compressible flows.
    Reference:
    \verbatim
        Launder, B. E., Reece, G. J., & Rodi, W. (1975).
        Progress in the development of a Reynolds-stress turbulence closure.
        Journal of fluid mechanics, 68(03), 537-566.
    \endverbatim
    Including the recommended generalised gradient diffusion model of
    Daly and Harlow:
    \verbatim
        Daly, B. J., & Harlow, F. H. (1970).
        Transport equations in turbulence.
        Physics of Fluids (1958-1988), 13(11), 2634-2649.
    \endverbatim
    Optional Gibson-Launder wall-reflection is also provided:
    \verbatim
        Gibson, M. M., & Launder, B. E. (1978).
        Ground effects on pressure fluctuations in the
        atmospheric boundary layer.
        Journal of Fluid Mechanics, 86(03), 491-511.
    \endverbatim
    The default model coefficients are:
    \verbatim
        myLRRCoeffs
            Cmu             0.09;
            C1              1.8;
            C2              0.6;
            Ceps1           1.44;
            Ceps2           1.92;
            Cs              0.25;
            Ceps            0.15;
            wallReflection  yes;
            kappa           0.41
            Cref1           0.5;
            Cref2           0.3;
            couplingFactor  0.0;
    \endverbatim
SourceFiles
    myLRR.C
#ifndef myLRR_H
#define myLRR_H
I've been really stuck on why its failing to compile. If I can get it to compile successfully then the change I want to implement should be very straightforward
Old   February 16, 2024, 04:31
Domenico Lahaye
dlahaye is on a distinguished road
Pls. share here the output of the linux command
nm -g myLRR.o
dlahaye is offline   Reply With Quote
Old   February 16, 2024, 06:46
ASR
Here is the output of the command
 cfd@UOL-PC-301943:~/OF_cases/myLRR> nm -g myLRR.o
nm: 'myLRR.o': No such file
Old   February 16, 2024, 06:49
ASR
I think that command might be redundant in OF9. As I typed the same thing for a compiled mykOmega and it gave the same output message:
 cfd@UOL-PC-301943:~/OF_cases/mykOmega> wmake libso
wmake libso .
g++ -std=c++14 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3  -DNoRepository -ftemplate-depth-100 -I/home/cfd/OpenFOAM/OpenFOAM-9/src/MomentumTransportModels/momentumTransportModels/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/MomentumTransportModels/incompressible/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/transportModels/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/finiteVolume/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/meshTools/lnInclude  -IlnInclude -I. -I/home/cfd/OpenFOAM/OpenFOAM-9/src/OpenFOAM/lnInclude -I/home/cfd/OpenFOAM/OpenFOAM-9/src/OSspecific/POSIX/lnInclude   -fPIC -fuse-ld=bfd -shared -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/mykinematicMomentumTransportModels.o -L/home/cfd/OpenFOAM/OpenFOAM-9/platforms/linux64GccDPInt32Opt/lib \
    -ltransportModels -lmomentumTransportModels -lfiniteVolume -lmeshTools  -o /home/cfd/OpenFOAM/cfd-9/platforms/linux64GccDPInt32Opt/lib/mykinematicMomentumTransportModels.so
cfd@UOL-PC-301943:~/OF_cases/mykOmega> nm -g mykOmega.o
nm: 'mykOmega.o': No such file
Old   February 16, 2024, 06:54
Domenico Lahaye
Apologies, my bad.
In case that the compilation of myLRR.C fails, the file myLRR.o is indeed not created.
Pls. share output of
nm -g LRR.o
Observe the use of the original LRR.o here.
Old   February 16, 2024, 07:02
ASR
I've inputted the same command but for LRR.o, same result
 cfd@UOL-PC-301943:~/OF_cases> nm -g LRR.o
nm: 'LRR.o': No such file
Old   February 16, 2024, 07:20
Domenico Lahaye
In the compilation of kEpsilon.C, kOmega.C and LRR.C does succeed (as you claim above), the files kEpsilon.o, kOmega.o and LRR.o should most obviously be created and written somewhere.
Old   February 16, 2024, 07:57
ASR
When I compile mykOmega I get a .o file for mykinematicMomentumTransportModels.o
 cfd@UOL-PC-301943:~/OF_cases/mykOmega/Make/linux64GccDPInt32Opt> ls
files  mykinematicMomentumTransportModels.C.dep  mykinematicMomentumTransportModels.o
Old   February 16, 2024, 08:00
ASR
When I attempt to compile myLRR, the .o file is missing for mykinematicMomentumTransportModels.o
 cfd@UOL-PC-301943:~/OF_cases/myLRR/Make/linux64GccDPInt32Opt> ls
Old   February 16, 2024, 08:48
ASR
Okay, I spoke to someone with experience in modifying source code for OpenFOAM. He went through my test case and found that in the myLRR.C file, you have to include the following term:
#include "simpleLRR.H"
#include "fvModels.H"
#include "fvConstraints.H"
#include "wallDist.H"
#include "bound.C"
Which for some reason was omitted in the LRR file originally. This allowed me to successfully compile a new turbulence model and test it worked.
SIMPLE: Convergence criteria found
        U: tolerance 1e-05
        p: tolerance 1e-05
        k: tolerance 1e-05
        epsilon: tolerance 1e-05
        R: tolerance 1e-05
        omega: tolerance 1e-05
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model myLRR
RAS
    model           myLRR;
    turbulence      on;
    printCoeffs     on;
    couplingFactor  0;
    Cmu             0.09;
    C1              1.8;
    C2              0.6;
    Ceps1           1.44;
    Ceps2           1.92;
    Cs              0.25;
    Ceps            0.15;
    wallReflection  true;
    kappa           0.41;
    Cref1           0.5;
    Cref2           0.3;
Creating MRF zone list from MRFProperties
    creating MRF zone: SRF
No fvModels present
No fvConstraints present
Starting time loop
Old   February 16, 2024, 10:32
ASR
I've now managed to implement my changes and I can successfully compile and run a simulation
The simulation can run in serial or parallel. The only thing I am noticing is for a parallel run some warning symbols appear when decomposing:
--> FOAM Warning :
    in file POSIX.C at line 1247
    dlopen error : /home/cfd/OpenFOAM/cfd-9/platforms/linux64GccDPInt32Opt/lib/libsimpleLRRMomentumTransportModels.so: undefined symbol: _ZTIN4Foam36incompressibleMomentumTransportModelE
--> FOAM Warning :
    in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 106
    could not load "libsimpleLRRMomentumTransportModels.so"
FOAM Warning :
--> FOAM Warning :
Is this just a bug as the simulation still runs regardless of the warning sign. Someone else has also made a similar observation before too in reddit https://www.reddit.com/r/OpenFOAM/co...ryso_warnings/ and he suggested the warning signs didn't make any difference as he could still run his simulations.
Old   November 21, 2024, 03:25
SunTime
lpz456 is on a distinguished road
Have you solve this problem? I also met the issue. I want to create a base model like kOmegaSSTBase model, and derive other models. Ths same issue happened.
lpz456 is offline   Reply With Quote
LEMOS InflowGenerator r_gordon OpenFOAM Running, Solving & CFD 103 December 18, 2018 01:58
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 13:38
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 01:34
