dividing a dimensioned vectorfield by a dimensioned scalar
Like Tree1Likes
  • 1 Post By Tobi
Old   February 8, 2021, 08:58
Default dividing a dimensioned vectorfield by a dimensioned scalar
Wiebke Scholz
weikou is on a distinguished road
I am aiming to write a chemistry-solver (I am still with OpenFoam v4.1) , that is solving the reaction and scalar transport on a (RANS averaged turbulent) incompressible flow field, that is already in steady state.
Therefore I need to solve the YEqn only, but adjust it by giving it a reaction source term.
Since I am working with incompressible flow, the dimensions of the terms are all in s⁻¹.
But dimension of reaction->R(Yi) is in kgm⁻³s⁻¹.
Therefore I would like to calculate
volScalarField& reactionRate = (reaction->R(Yi)) / rhoRef;
with 'rhoRef' being a scalar with dimensions kgm⁻³ to end up with reactionRate in dimension s⁻¹.
But when I try, it doesn't compile and gives me the error
no match for ‘operator/’ (operand types are ‘Foam::tmp<Foam::fvMatrix<double> >’ and ‘Foam::dimensionedScalar {aka Foam::dimensioned<double>}’)
Because I didn't find a lot of information on this in the OpenFOAM programmers' guide, I naively thought, this should work, but it seems like I was wrong. Maybe you have an idea, on how to fix this?
Thanks already in advance!
Wiebke
weikou is offline   Reply With Quote
Old   February 8, 2021, 09:31
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
The problem you encounter here is that the ::R() function will not return a volScalarField but it will rather be a fvScalarMatrix and for the fvScalarMatrix we don´t have the operator/ defined. Out of the box, I am not sure about the conversions implemented. However, I don´t think that even this line will work:
volScalarField& reactionRate = reaction->R(Yi)
weikou likes this.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   February 8, 2021, 09:47
Wiebke Scholz
Hi Tobias,
thanks for the quick answer. In that case, it is probably best to leave the result of ::R() as it is and multiply all the other fields in the equation with a constant density.
I just tried it and that seems to work. Thanks for clarifying the types there.
Wiebke
Old   February 8, 2021, 09:55
Tobi's Avatar
Tobias Holzmann
A work around could be to make it in that way:
fvScalarMatrix reactionRates = reaction->R();
fvScalarMatrix tmp(reactionRates.size(), dimensionSet("tmp", dimensions(Your Dimensions), scalar(0));    // Not sure about the constructor of that class right now
// Create loop and copy only the data without the units into the new one.
Keep foaming,
Tobias Holzmann
dimensioned scalars, dimensioned vectorfields, incompressible flow, reaction
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 05:18
Division by zero exception - loop over scalarField Pat84 OpenFOAM Programming & Development 6 February 18, 2017 06:57
Issue symmetryPlane 2.5d extruded airfoil simulation 281419 OpenFOAM Running, Solving & CFD 5 November 28, 2015 14:09
Diverging solution in transonicMRFDyMFoam tsalter OpenFOAM Running, Solving & CFD 30 July 7, 2014 07:20
compressible flow in turbocharger riesotto OpenFOAM 50 May 26, 2014 02:47
