K
Rep Power: 9 ![]() |
Hi foamers,
I have a solver and I used it for quite a while. It retrieve data from a table and read it and use it (I am 100% sure as I did some validations against experimental data). However, there was always this warning of [-Wunused-variable] occurring at compilation for the variable A in createfields.H : Code:
tableParam tableObject("model",mesh); const volScalarField& A = tableObject.getData("A"); False warning: unused variable It seems that the problem is coming from initialization. I changed the second line of the code in different ways but it did not help. So, I would be grateful if you can help me with this issue. |
Andrew Bickerdike
Rep Power: 5 ![]() |
I'm having the same problem, have you since found a solution? |
Mark Olesen
Rep Power: 40 ![]() ![]() |
If the code looks OK, just ignore the warning and get on with other things.
Ali B.
Rep Power: 6 ![]() |
If you really want to get rid of it, just cast it to void.
tableParam tableObject("model",mesh); const volScalarField& A = tableObject.getData("A"); (void) A; |
createfields.h, table data, [-wunused-variable] |
foamToTecplot360 | thomasduerr | OpenFOAM Post-Processing | 121 | June 11, 2021 10:05 |
Caffa 3D code | Waliur Rahman | Main CFD Forum | 0 | May 29, 2018 00:53 |
[swak4Foam] installation problem with version 0.2.3 | Claudio87 | OpenFOAM Community Contributions | 9 | May 8, 2013 10:20 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 04:37 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
