How to add source term and material derivative of log(T) in openFaom.
Like Tree1Likes
  • 1 Post By alexeym
Old   January 26, 2021, 09:13
Default How to add source term and material derivative of log(T) in openFaom.
idrees khan
idrees khan is on a distinguished road
Hi Dear's
I'm adding non-isothermal Oldroyd-B model to viscoelasticFluidFaom solver the stress equation(using Oldroyd-B model) for isothermal case is like so,
// Stress transport equation
    fvSymmTensorMatrix tauEqn
        fvm::ddt(tau_)
      + fvm::div(phi(), tau_)
        etaP/lambda*twoD
      + twoSymm(C)
      - fvm::Sp(1/lambda, tau_)
tauEqn.relax();
tauEqn.solve();
But for non-isothermal case in the stress equation
//-  WLF to update viscosities for temperature dependence
    volScalarField lambda = Foam::exp( -C11_*(T - To_) / (C21_ + T - To_) )*lambda_;
    volScalarField etaP   = Foam::exp( -C11_*(T - To_) / (C21_ + T - To_) )*etaP_;
there is a term (
lambda*tua_*D(log(T))/Dt
where Lambda is relaxation time which also depends upon temperature i.e as define above ) means multiplication of relaxation time lambda(T) tau_ and material derivative of log(T) please have a look of screenshot)
my question is how to define it in openFoam term
  lambda*tua_*D(log(T)/Dt
rest of the equation is same as given above.
if i define it like
volScalarField  logT = log(T);
// material derivative term of log(T) in multiplication with tau_
       fvc::ddt(tau_/lambda,logT) +fvc::div(phi()*tau_,logT/lambda)
which is wrong beacause this:
 fvc::div(phi()*tau_,logT),
phi is a surface field that are multiplying a volumetric field,I'm getting erorr's while compiling
if define like so
tau_*fvc::ddt(1/lambda,logT) + tau_*fvc::div(phi(),logT/lambda)
But I'm not sure although it compile successfully by running "wmake libso"
but give me and error when I'm running the solver saying
argument of transcendental function is not dimensionless
which is i think because of the declaration of
but if I'm not declaring it like so it doesn't compile with "wmake libso"
what i'm thinking just like we define material derivative in momentum eqaution i.e DU/Dt which is wrtten in openFaom
fvm::ddt(U) +fvm::phi ,U)
here U is a variable to whom we are taking the derivative.
so I'm applying the same track for
also i want to add the source term to momentum eqaution,
source term
F=g*Cb(T - To)
where F is is the body force due to thermal convection with g gravitational accelaration and Cb thermal expansion
i write
fvm::Sp(g*Cb, T)   - g*Cb*To   or fvc::Sp(g*Cb, T)   - g*Cb*To and simply  (g*Cb(T - To))
but getting error's (Have a look screenshot please)
regards
idrees
idrees khan is offline   Reply With Quote
Old   January 27, 2021, 15:32
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
1. There is fvc::DDt(phi, Field). Here is a link to Foundation's documentation (fvc::DDt), guess, foam-extend has something similar.
2. To use T in log, T should be dimensionless. Either divide the field by 1K, or do something more appropriate.
3. Error screenshot is irrelevant. Post simple text of the whole error. But it seems, you have tried to add different types of fields (ex. vector and tensor).
idrees khan likes this.
alexeym is offline   Reply With Quote
how to Add the material derivative of log(T) in the constitutive equation's. idrees khan OpenFOAM Programming & Development 5 January 21, 2021 08:57
curvature correction term, material derivative of a tensor volker OpenFOAM Programming & Development 7 June 3, 2010 09:08
UDF Scalar Code: HT 1 Greg Perkins FLUENT 8 October 20, 2000 13:40
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 14, 2000 00:03
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 04:43
