How can we use non-dimensional forms of governing equations in openFoam.
Like Tree1Likes
  • 1 Post By alexeym
Old   January 21, 2021, 11:19
Default How can we use non-dimensional forms of governing equations in openFoam.
idrees khan
idrees khan is on a distinguished road
Dear former's
please any one could guide me How to use Non-Dimensional equations(see screenshot of equ's) in OpenForm(foam-extend-4.0).
regards
Idrees
File Type: jpg Screenshot from 2021-01-21 17-17-23.jpg (54.1 KB, 52 views)
idrees khan is offline   Reply With Quote
Old   January 25, 2021, 04:34
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
What kind of guidance do you need? Equations in OpenFOAM are written in dimensioned form, so you have to rewrite you equations to learn what solver to use, what models to use, etc.
Right now it seems that you need
1. buoyantBoussinesqPimpleFoam solver.
2. Arrhenius viscosity model.
3. solidificationMeltingSource fvOption.
Guess, lambda in your case is thermal conductivity, so you will have to implement additional source terms to have temperature-dependent thermal diffusivity.
Just for your future posts (if you want to get answers without employing Skype):
- Nobody want to decrypt your screen-shots. Post your equations using MATH tags.
- Usually people answer questions, not vague guidance requests.
- There are a number of OpenFOAM users, limit yourself with foam-extend 4.0 is to reduce number of people, who can answer you.
- Search. I do not think, you are the first, who wants to solve dimensionless equations with OpenFOAM.
guin likes this.
alexeym is offline   Reply With Quote
Old   January 25, 2021, 05:55
idrees khan
Hi Dear Nancy,
I'm going to solve a paper(having viscoelastic Model more specifically having momentum,temperature,Oldroyd-B model) in openFaom,which is basically solved in Matlab using Finite difference Method.
so difinitly i will have to use ViscoelasticFluidFoam solver which is basically for isothermal case so far in foam-extend.4.0 version,so i'll have to add Temperature equation
to viscoelasticFluidFoam solver as given in the paper.
so to compare the results with the paper,as it is solved in dimensionless form i would like to use the dimensionless governing equations(screenshot given) in openFaom (if I'm not wrong).
so kindly i need guidance for that,where i should need to make the changes?,as openFoam is strictly dimensioned.
regards
idrees khan
Old   January 25, 2021, 11:03
idrees khan
Originally Posted by alexeym View Post
Dear Alexey,
Sorry I'm new don't know how to write equations using MATH tags, but let me write the equation's without that. the stress equation(using Oldroyd-B model) for isothermal case is like so,
// Stress transport equation
fvSymmTensorMatrix tauEqn
fvm::ddt(tau_)
+ fvm::div(phi(), tau_)
etaP/lambda*twoD
+ twoSymm(C)
- fvm::Sp(1/lambda, tau_)
tauEqn.relax();
tauEqn.solve();
But for non-isothermal case in the stress equation
//- WLF to update viscosities for temperature dependence
volScalarField lambda = Foam::exp( -C11_*(T - To_) / (C21_ + T - To_) )*lambda_;
volScalarField etaP = Foam::exp( -C11_*(T - To_) / (C21_ + T - To_) )*etaP_;
volScalarField muS = Foam::exp( -C11_*(T - To_) / (C21_ + T - To_) )*etaS_;
there is a term (lambda*tua_*D(log(T)/Dt where Lambda is relaxation time which also depends upon temperature i.e as define above ) means multiplication of relaxation time lambda(T) tau_ and material derivative of log(T) please have a look of screenshot)
my question is how to define in openFoam term lambda*tua_*D(log(T)/Dt rest of the equation is same as given above.
if define it like
// material derivative term of log(T) in multiplication with tau_
fvc::ddt(tau_/lambda,logT) +fvc::div(phi()*tau_,logT/lambda)
which is wrong beacause this: fvc::div(phi()*tau_,logT), phi is a surface field that are multiplying a volumetric field,I'm getting erorr's while compiling
if define like so
tau_*fvc::ddt(1/lambda,logT) + tau_*fvc::div(phi(),logT/lambda)
But I'm not sure although it compile successfully by running "wmake libso"
what i'm thinking just like we define material derivative in momentum eqaution i.e DU/Dt which is wrtten in openFaom
fvm::ddt(U) +fvm:phi ,U) here U is a variable to whom we are taking the derivative.
regards
idrees
Energy equations in OpenFoam Bloerb OpenFOAM Running, Solving & CFD 9 July 1, 2024 14:22
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 05:37
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 09:51
Solving the Same Governing Equations Over Different Regions Saleh Abuhanieh OpenFOAM Programming & Development 2 April 27, 2018 06:03
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin CFDFoundation OpenFOAM Announcements from Other Sources 0 January 4, 2017 07:15
