OpenFOAM vs ANSYS Fluent (Solution and Schemes)
Like Tree1Likes
  • 1 Post By gentodin
Old   January 21, 2021, 09:27
Default OpenFOAM vs ANSYS Fluent (Solution and Schemes)
Anonymous.
gentodin is on a distinguished road
Hi all,
I am trying to replicate the simulation from ANSYS fluent to OpenFOAM but I could not find some settings or do not know how to set them in OF.(This is my way of learning, feel free to drop comment for a better way).
The following are the areas I am looking at fvSolution and fvScheme in the OF settings.
Currently there are 4 segments of input parameters I divided them into and each contains question as shown below:
1) The fvSolution algorithm used was PISO
Fluent settings:
Skewness Correction 1
Neighbor Correction 1
OF settings:
PIMPLE
nNonOrthogonalCorrectors 1
nCorrectors 1
nOuterCorrectors 1
Questions:
When the simulation is running in fluent, there is an additional option of setting max iteration per timestep, does this iteration refer to total no. of PISO loop per timestep or the control of other loops?
2) fvSchemes grad and div settings
fluent settings:
gradient, leastsquareCellBased
Pressure, Second Order upwind
Momentum, Second Order upwind
TKE, Second Order upwind
TDR, Second Order upwind
Energy, Second Order upwind
Transient Formulation, First Order implicit
OF settings:
ddtSchemes
default Euler;
gradSchemes
default none;
grad(U) leastSquares;
grad(T) leastSquares;
grad(k) leastSquares;
grad(epsilon) leastSquares;
grad(R) leastSquares;
divSchemes
default none;
div(phi,U) Gauss linearUpwind grad(U);
div(phi,T) Gauss linearUpwind grad(T);
div(phi,k) Gauss linearUpwind grad(k);
div(phi,epsilon) Gauss linearUpwind grad(epsilon);
div(phi,R) Gauss linearUpwind grad(R);
div(R) Gauss linearUpwind grad(R);
div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear uncorrected;
interpolationSchemes
default linear;
snGradSchemes
default uncorrected;
Questions:
Are the laplacianSchemes/interpolationschemes in fluent follow the individual schemes that are present? i.e. momentum follows all second order upwind for div, laplacian and interpolation schemes.
Why can't set linearUpwind for div((nuEff*dev2(T(grad(U))))) under divSchemes?
3) fvSolution Residuals
All settings are the same except for continuity and pressure.
Does anyone know where to set the Pressure residuals in fluent?
Does anyone know where to set the continuity Residuals in OF?
4) fvSolution Under-Relaxation Factors
Fluent settings:
Pressure 0.3
Density 1
Body Forces 1
Momentum 0.7
TKE 0.8
TDR 0.8
Turbulent Viscosity 1
Energy 1
OF settings:
Momentum 0.7
TKE 0.8
TDR 0.8
Question: How do I set Pressure, Density, Body Forces and Turbulent Viscosity Under relaxation factors in OF. ?
THANK YOU to anyone that can answer any of these questions.
ztnuaa likes this.
gentodin is offline   Reply With Quote
Old   February 3, 2021, 03:04
Ilhwan Yeo
jayson is on a distinguished road
Originally Posted by gentodin View Post
Hi all,
Fluent settings:
OF settings:
PIMPLE
nCorrectors 1
nOuterCorrectors 1
Questions:
fluent settings:
OF settings:
ddtSchemes
default Euler;
gradSchemes
default none;
divSchemes
default none;
laplacianSchemes
default linear;
snGradSchemes
Questions:
Fluent settings:
Pressure 0.3
Density 1
Body Forces 1
Momentum 0.7
TKE 0.8
TDR 0.8
Energy 1
OF settings:
Momentum 0.7
TKE 0.8
TDR 0.8
Did you solve this problem??
jayson is offline   Reply With Quote
Old   February 21, 2021, 21:56
Default Reply to this thread
Anonymous.
I manage to find out about the 1st question where the max iteration in ANSYS fluent is referring to max outer iterations per timestep as shown here:
For 4th question, setting pressure relaxation is simple typing this in fvSolution file in OF:
relaxationFactors
equations
p 0.3; //Pressure relaxation
pFinal 1;
U 0.7; //Velocity relaxation
UFinal 1;
OpenFoam underestimates lift coefficient compared to fluent or XFOIL SAI_ OpenFOAM 0 November 21, 2018 14:33
OpenFOAM 4.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 2 October 6, 2017 06:40
ddt schemes in openFoam muhammss OpenFOAM Running, Solving & CFD 7 July 4, 2016 09:17
schemes used in fluent HaKu FLUENT 0 May 6, 2011 14:54
OpenFOAM vs Fluent for cylinder at Re%3d150 lr103476 OpenFOAM Running, Solving & CFD 40 December 18, 2008 10:09
