Implementation of rpm as function of time in SRF module results in solver error
Like Tree1Likes
  • 1 Post By user_HH
Old   January 11, 2021, 13:29
Default Implementation of rpm as function of time in SRF module results in solver error
HH
user_HH is on a distinguished road
I am trying to change the functionality of SRF in OF v1806 to input rpm as function of time.
I created a new folder "varSRF" in src/finiteVolume/cfdtools/general/
After making the required changes, I added the destination for .C files in the src/finiteVolume/Make/files. The folder compiled without any errors
However, when I made all the required changes to my solver and compiled it, I get the following error:
OpenFOAM-v1806/build/linux64GccDPInt32Opt/applications/solvers/grooveAsperityFoam_generic_reversed_SRF_var/grooveAsperityFoam_generic_reversed_SRF_var.o: In function `main':
grooveAsperityFoam_generic_reversed_SRF_var.C.te xt.startup+0x1690): undefined reference to `Foam::varSRF::varSRFModel::New(Foam::GeometricFie ld<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&)'
grooveAsperityFoam_generic_reversed_SRF_var.C.te xt.startup+0x39e1): undefined reference to `Foam::varSRF::varSRFModel::New(Foam::GeometricFie ld<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&)'
collect2: error: ld returned 1 exit status
make: *** [/home/hharia/OpenFOAM/OpenFOAM-v1806/platforms/linux64GccDPInt32Opt/bin/grooveAsperityFoam_generic_reversed_SRF_var] Error 1
I have been struggling with this error related to autoPtr and suspect that this is associated with the additional lines in the createFields.H. I have read several of posts on this error and tried various things to resolve it. However, I have not been successful and currently stuck.
I originally posted the question in the following thread: rpm as function of time in SRF model ?
But i haven't received any answers for the same.
Any help will be highly appreciated. Thanks in advance!
Additional Information:
OF version: v1806
Solver: It is a user defined solver built using PimpleFOAM as a reference (the solver has been tested with constant SRF speed and works. It crashes with this new modification for rpm as a function of time)
Lines in createFields. H:
autoPtr<varSRF::varSRFModel> varSRF
varSRF::varSRFmodel::New(Urel)
Modifications to original SRF functionality
1. Changed names from SRF to varSRF wherever relevant
2. Modified rpm.H to varrpm.H along with the following lines in the file
Old: scalar rpm_;
New: autoPtr<Function1<scalr>> rpm_;
3. Added appropriate header file
Best,
Hiral
user_HH is offline   Reply With Quote
Old   January 12, 2021, 08:42
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Dear Hiral,
its a long time ago that I was programming in FOAM but
Tells you that you are calling a function named New(..) which is derived from your new class which does not exist.
I guess that you did not include the new source (varSRF) file to the library you compiled and hence, in the library the solver loads, the reference is not available.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   January 12, 2021, 09:42
Default Thanks Tobi
HH
Tobi,
Thanks for your reply. Really appreciate your help.
I had been going through the log file I created while compiling the varSRF functionality and realized that varSRFNew.C was not included in Make/files.
I also added EXE_LIBS to the options file with -lfiniteVolume
The functionality and the solver compiled without errors. However, I am not sure if adding EXE_LIBS made any difference or not.
I also tried updating the post earlier after I discovered this error but couldn't find a way to reach the post when under moderator review.
Thank you for the help.
P.S. Your blogs and book on pimpleFoam have been very helpful in my solver development activity.
Best,
Hiral
Tobi likes this.
autoptr, compilation error, rpm, srf
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 14:21
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 08:11
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 21:30
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 13:34
