Why polyBoundaryMesh wasn't made into a nested class?
Like Tree2Likes
  • 1 Post By olesen
  • 1 Post By olesen
Old   January 6, 2021, 00:26
Default Why polyBoundaryMesh wasn't made into a nested class?
Mandeep Shetty
granzer is on a distinguished road
I see that polyBoundaryMesh class is used in polyMesh class (has-a relationship) to take care of boundary mesh. Why isn't the polyBoundaryMesh class made into nested class inside the polyMesh class like how the GeometricField:: Boundary is a nested class inside GeometricField and takes care of the boundary fields and related boundary conditions.
granzer is offline   Reply With Quote
Old   January 6, 2021, 15:13
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Stick it on an issue (https://develop.openfoam.com/Develop...nfoam/-/issues).
Can't see any particular advantage to having it nested, but off-hand no particular disadvantage either.
BTW: one general issue with nested classes is that it makes them almost impossible to forward declare (this hit us with the profiling classes). Maybe not a factor here, but figured I might mention it anyhow.
granzer likes this.
olesen is offline   Reply With Quote
Old   January 7, 2021, 13:19
Mandeep Shetty
What do you think about the case where we just import the surface mesh(I have never tried this)? Would polyBoundaryMesh as a inner class still work in such a case or will having it as a seperate class be advantageous.
(I didn't know nested class couldn't be forward declared outside the enclosing class. That helped me learn something new .)
Old   January 8, 2021, 15:22
Mark Olesen
In the meantime can't really see any advantages for nesting polyBoundaryMesh. Could maybe add as a typedef inside polyMesh I suppose, but still can't see what it helps.
granzer likes this.
OpenFOAM class declaration error with volScalarField raunakbardia OpenFOAM Programming & Development 0 June 2, 2019 16:46
BasicTurbulenceModel class declaration in OpenFOAM 6 rod_petrone OpenFOAM Programming & Development 3 April 15, 2019 09:27
Extract a member function from a class by using autoPtr mkhm OpenFOAM Programming & Development 9 November 13, 2018 13:05
tailor made class, wmake libso successfully, but run failed. sharonyue OpenFOAM Programming & Development 1 November 20, 2014 22:49
Possible bug in OpenFoam Interpolation class MMC15 OpenFOAM Bugs 2 March 23, 2014 13:55
