Coupling a multiphase solver with a heat solver in the solid
Like Tree1Likes
  • 1 Post By Mehdi04
Old   December 9, 2020, 10:24
Post Coupling a multiphase solver with a heat solver in the solid
Mehdi Go
Mehdi04 is on a distinguished road
Dear Foamers,
I'm looking for solvers that can solve a compressible multiphase flow (i.e compressibleInterFoam) coupled to the heat transfer in the solid (walls) which we can call thick walls. I haven't found one yet.
There are some boundaries that can modelize this type of wall, but with only conduction or convection. I want to solve model both at the same type.
Is there any solver that can already do that ? If not, I want to work on developping one. If any one have tips or a base from where to start to couple the solvers, I ould be glad if you guide me to it.
I can share more details, if necessary.
Best Regards,
mikulo likes this.
Mehdi04 is offline   Reply With Quote
compressibleinterfoam, coupling 2 solvers, heat transfer modelling, multiphase
Conjugate heat transfer virothi Main CFD Forum 10 January 5, 2021 05:46
I want to find proper solver. (multiphase & heat exchange) Munho OpenFOAM Running, Solving & CFD 4 September 3, 2020 10:28
[solids4Foam] How to calculate drag coeff when using solids4Foam amuzeshi OpenFOAM CC Toolkits for Fluid-Structure Interaction 15 November 7, 2019 13:50
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 08:54
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
