How to write rho field for incompressible interFoam
Like Tree2Likes
  • 1 Post By Wenyuan
  • 1 Post By Wenyuan
Old   October 27, 2020, 13:23
Default How to write rho field for incompressible interFoam
Prasad ADHAV
Alpha001 is on a distinguished road
Hello Foamers,
This is my first time asking a question here, so please be patient with any mistakes.
System:
OpenFOAM 7
Ubuntu 18.04LTS
Problem-Statement:
I am trying to couple interFoam to a in-house DEM solver.(Using preCICE)
When using pimpleFoam I could just hard set the values for density and viscocity.
I need the rho and nu field for calculating the Bouyant force on particles. But currently just trying to solve the issue with rho.
In interFoam we have two-phase, so different densities through the domain depending on where you see.
I am using the incompressible interFoam solver.
Changes
I have the following changes in the createFields.H
Info<< "Reading transportProperties\n" << endl;
immiscibleIncompressibleTwoPhaseMixture mixture(U, phi);
volScalarField& alpha1(mixture.alpha1());
volScalarField& alpha2(mixture.alpha2());
const dimensionedScalar& rho1 = mixture.rho1();
const dimensionedScalar& rho2 = mixture.rho2();
// Need to store rho for ddt(rho, U)
volScalarField rho
    IOobject
        "rho",
        runTime.timeName(),
        mesh,
        IOobject::READ_IF_PRESENT
        IOobject::AUTO_WRITE
    alpha1*rho1 + alpha2*rho2
rho.oldTime();
I get the following error when I compile the solver using wmake command.
./createFields.H: In function ‘int main(int, char**)’:
./createFields.H:110:5: error: expected primary-expression before ‘(’ token
./createFields.H:115:9: error: expected ‘)’ before ‘IOobject’
In file included from exInterFoam.C:60:0:
I am a bit unsure of what I am messing up.
Any tips, advice and help is welcome.
Thank you.
Alpha001 is offline   Reply With Quote
Old   October 27, 2020, 14:33
Wenyuan Fan
Wenyuan is on a distinguished road
It seems that a comma is missing before the newly added line.
Alpha001 likes this.
Wenyuan is offline   Reply With Quote
Old   October 28, 2020, 02:53
Prasad ADHAV
Thank you.
It works.
Old   October 28, 2020, 04:39
Prasad ADHAV
In the above code in createFields.H, how can I add the nu field?
const dimensionedScalar& nu1 = mixture.nu1();
const dimensionedScalar& nu2 = mixture.nu2();
// Getting viscocity
volScalarField nu
    IOobject
        "nu",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
    alpha1*nu1 + alpha2*nu2
I added this, but I get the following error:
./createFields.H:107:40: error: ‘class Foam::immiscibleIncompressibleTwoPhaseMixture’ has no member named ‘nu1’; did you mean ‘nu’?
                                        nu
./createFields.H:108:40: error: ‘class Foam::immiscibleIncompressibleTwoPhaseMixture’ has no member named ‘nu2’; did you mean ‘nu’?
                                        nu
SO I did some digging and found that in src/transportModels/immiscibleIncompressibleTwoPhaseMixture/immiscibleIncompressibleTwoPhaseMixture.H.
Old   October 28, 2020, 05:19
Wenyuan Fan
nu1() and nu2() are not defined in incompressibleTwoPhaseMixture, which is the parent class of immiscibleIncompressibleTwoPhaseMixture.
You can call nu() directly, which returns a tmp<volScalarField>.
Old   October 28, 2020, 05:40
Prasad ADHAV
Thank you. The solver is compiling.
I was also able to write out mu field in the similar way since it is present in incompressibleTwoPhaseMixture.H.
//- Return the dynamic laminar viscosity
        tmp<volScalarField> mu() const;
Old   July 8, 2021, 01:15
Abhishek Mukherjee
absrocks is on a distinguished road
Hi, I want to use turbulence->nut() and turbulence->nu() in interFoam solver, but I am getting the error while compiling
error: ‘class Foam::incompressibleInterPhaseTransportModel<Foam::immiscibleIncompressibleTwoPhaseMixture>’ has no member named ‘nu’
error: ‘class Foam::incompressibleInterPhaseTransportModel<Foam::immiscibleIncompressibleTwoPhaseMixture>’ has no member named ‘nut’
I am using openfoam2106 version. When I used the same in OpenFOAM-8 it works perfectly. Can anyone have an idea?
If I use mixture->nu() I did not get any error, but how would I access nut?
absrocks is offline   Reply With Quote
Old   October 18, 2021, 13:53
Venkat Ganesh
Venky_94 is on a distinguished road
Hey, did you check the written out mu and nu values to see if they're right? Because I followed the same procedure as you and my mu and nu values are written out but they're constant values and not the calculated values at each time step.
Did you have to do something in addition to what you have mentioned earlier?
Venky_94 is offline   Reply With Quote
createfields, interfoam, rho, write data
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 14:06
[swak4Foam] swakExpression not writing to log alexfells OpenFOAM Community Contributions 3 March 16, 2020 19:19
strange distribution of velocity field when using O-block mesh in interFoam Zhanyuan Wang OpenFOAM 0 December 18, 2019 22:41
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 04:34
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 15:37
