Using fvOption for adding momentum in pimpleFoam(changes in pimpleFoam example) |
October 20, 2020, 13:53 |
Farzad Faraji
Rep Power: 8 |
Dear friends
I have changed pitzdaily example(pimpleFoam solver), and I want to add momentum source to that. I use the topoSetDict as below to create the desired zone; Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object topoSetDict.1; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // actions ( { name farzaaadSulzerCellSet; type cellSet; action new; //remove; // new; source boxToCell; sourceInfo { box (0.096 0.10 0.0357) (0.404 0.20 0.0643); } } { name farzaaadSulzer; type cellZoneSet; action new; // remove; // new; source setToCellZone; sourceInfo { set farzaaadSulzerCellSet; } } ); // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object fvOptions; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // momentumSource { type meanVelocityForce; active on; //on/off switch //cellSet sourceSet; meanVelocityForceCoeffs { timeStart 0.; duration 1000.; selectionMode cellZone; //cellSet; //cellZone; cellZone farzaaadSulzer; //cellZone farzadSulzer; fields (Uc); Ubar ( 5.0 0.0 0.0); // ( 0. -1.0 0.); relaxation 1.0; } } What I am doing wrong in my simulation(momentum source did not do anything)? I have attached the figure of my domain and also the momentum source inside it to this post. Thanks, Farzad |
October 20, 2020, 17:25 |
incompressible/pimpleFoam/LES/channel395/
Farzad Faraji
Rep Power: 8 |
in the "incompressible/pimpleFoam/LES/channel395/", we have;
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: dev \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object fvOptions; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // momentumSource { type meanVelocityForce; selectionMode all; fields (U); Ubar (0.1335 0 0); } // ************************************************************************* // But why it does not work in my pimpleFoam example? Farzad |
October 22, 2020, 06:41 |
Michael Alletto
Rep Power: 16 |
any special reason you wrote fields
fields (Uc); |
Using fvOption for adding momentum | farzadmech | OpenFOAM Programming & Development | 11 | October 20, 2020 13:55 |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 17, 2020 00:44 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 18:38 |
Spray total droplet momentum calculation help | tarnsharma | AVL FIRE | 0 | July 19, 2012 09:17 |
Derivation of Momentum Equation in Integral Form | Demonwolf | Main CFD Forum | 2 | October 29, 2009 20:53 |
