Adding Libraries to OpenFOAM
Like Tree5Likes
  • 1 Post By EdoardoCip
  • 1 Post By MCrossover97
  • 1 Post By Antimony
  • 1 Post By Dcn
Old   October 20, 2020, 07:07
Default Adding Libraries to OpenFOAM
Mohammad Khojastehmehr
MCrossover97 is on a distinguished road
Hi everybody, hope you are doing fine!
There is a library that I wanted to add to OpenFOAM called "Reaktoro". Here is a link to the source:
https://github.com/reaktoro/reaktoro
Unfortunately, I don't know much about C++ so I would be very appreciative if someone can help me with this in detail. I know it has something to do with options in the make folder but I don't know exactly how I can add this library in this case; since there are a bunch of folders in the source file.
I've read somethings about libraries in OpenFOAM but I'm a little bit confused; perhaps because I don't know the basics.
https://cfd.direct/openfoam/user-gui...-applications/
Thank you so much.
MCrossover97 is offline   Reply With Quote
Old   October 20, 2020, 12:45
Default Put the source in the make folder
I realized all you have to do is to create a folder named lnInclude in your solver folder. Then put the whole source into this lnInclude.
Old   October 21, 2020, 09:49
Default undefined reference to ...
Now I'm getting some errors making the solver:
g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3  -DNoRepository -ftemplate-depth-100 -I/opt/openfoam8/src/finiteVolume/lnInclude -I/opt/openfoam8/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam8/src/OpenFOAM/lnInclude -I/opt/openfoam8/src/OSspecific/POSIX/lnInclude   -fPIC -fuse-ld=bfd -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/reaktoroFOAM.o -L/opt/openfoam8/platforms/linux64GccDPInt32Opt/lib \
    -lfiniteVolume -lmeshTools -lOpenFOAM -ldl  \
     -lm -o /home/mcrossover97/OpenFOAM/mcrossover97-8/platforms/linux64GccDPInt32Opt/bin/reaktoroFOAM.C
Make/linux64GccDPInt32Opt/reaktoroFOAM.o: In function `main':
reaktoroFOAM.C:(.text.startup+0x60): undefined reference to `Reaktoro::ChemicalEditor::ChemicalEditor()'
reaktoroFOAM.C:(.text.startup+0x6f): undefined reference to `Reaktoro::StringList::StringList(char const*)'
reaktoroFOAM.C:(.text.startup+0x7a): undefined reference to `Reaktoro::ChemicalEditor::addAqueousPhaseWithElementsOf(Reaktoro::StringList const&)'
reaktoroFOAM.C:(.text.startup+0x82): undefined reference to `Reaktoro::StringList::~StringList()'
reaktoroFOAM.C:(.text.startup+0x91): undefined reference to `Reaktoro::StringList::StringList(char const*)'
reaktoroFOAM.C:(.text.startup+0x9c): undefined reference to `Reaktoro::ChemicalEditor::addGaseousPhase(Reaktoro::StringList const&)'
reaktoroFOAM.C:(.text.startup+0xa4): undefined reference to `Reaktoro::StringList::~StringList()'
reaktoroFOAM.C:(.text.startup+0xb3): undefined reference to `Reaktoro::StringList::StringList(char const*)'
reaktoroFOAM.C:(.text.startup+0xbe): undefined reference to `Reaktoro::ChemicalEditor::addMineralPhase(Reaktoro::StringList const&)'
reaktoroFOAM.C:(.text.startup+0xc6): undefined reference to `Reaktoro::StringList::~StringList()'
reaktoroFOAM.C:(.text.startup+0xd1): undefined reference to `Reaktoro::ChemicalEditor::operator Reaktoro::ChemicalSystem() const'
reaktoroFOAM.C:(.text.startup+0xe1): undefined reference to `Reaktoro::EquilibriumProblem::EquilibriumProblem(Reaktoro::ChemicalSystem const&)'
reaktoroFOAM.C:(.text.startup+0x11f): undefined reference to `Reaktoro::EquilibriumProblem::add(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, double, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >)'
reaktoroFOAM.C:(.text.startup+0x179): undefined reference to `Reaktoro::EquilibriumProblem::add(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, double, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >)'
reaktoroFOAM.C:(.text.startup+0x1d3): undefined reference to `Reaktoro::EquilibriumProblem::add(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, double, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >)'
reaktoroFOAM.C:(.text.startup+0x22d): undefined reference to `Reaktoro::EquilibriumProblem::add(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, double, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >)'
reaktoroFOAM.C:(.text.startup+0x263): undefined reference to `Reaktoro::equilibrate(Reaktoro::EquilibriumProblem const&)'
reaktoroFOAM.C:(.text.startup+0x282): undefined reference to `Reaktoro::ChemicalState::output(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, int) const'
reaktoroFOAM.C:(.text.startup+0x29d): undefined reference to `Reaktoro::ChemicalState::~ChemicalState()'
reaktoroFOAM.C:(.text.startup+0x2a5): undefined reference to `Reaktoro::EquilibriumProblem::~EquilibriumProblem()'
reaktoroFOAM.C:(.text.startup+0x2ad): undefined reference to `Reaktoro::ChemicalSystem::~ChemicalSystem()'
reaktoroFOAM.C:(.text.startup+0x2b5): undefined reference to `Reaktoro::ChemicalEditor::~ChemicalEditor()'
reaktoroFOAM.C:(.text.startup+0x305): undefined reference to `Reaktoro::ChemicalState::~ChemicalState()'
reaktoroFOAM.C:(.text.startup+0x310): undefined reference to `Reaktoro::EquilibriumProblem::~EquilibriumProblem()'
reaktoroFOAM.C:(.text.startup+0x318): undefined reference to `Reaktoro::ChemicalSystem::~ChemicalSystem()'
reaktoroFOAM.C:(.text.startup+0x320): undefined reference to `Reaktoro::ChemicalEditor::~ChemicalEditor()'
reaktoroFOAM.C:(.text.startup+0x381): undefined reference to `Reaktoro::StringList::~StringList()'
collect2: error: ld returned 1 exit status
/opt/openfoam8/wmake/makefiles/general:140: recipe for target '/home/mcrossover97/OpenFOAM/mcrossover97-8/platforms/linux64GccDPInt32Opt/bin/reaktoroFOAM.C' failed
make: *** [/home/mcrossover97/OpenFOAM/mcrossover97-8/platforms/linux64GccDPInt32Opt/bin/reaktoroFOAM.C] Error 1
I can't understand what I'm missing. I'm still wondering is there anything I should have done more? Does it have anything to do with .so files? I can't see any .so file in the source folder so that I can put them in the option under EXE_LIBS. Should I somehow create these .so files? I'm confused. any help would be greatly appreciated.
Old   October 21, 2020, 18:46
EdoardoCip is on a distinguished road
Did you build the Reaktoro library? Following the guide for building Reaktoro you should end up with a directory called "build" that probably contains a folder with the .so files and another one with the headers (.H files).
Once you built Reaktoro you can use it in OpenFOAM by adding to the Make/options:
- The positions of the headers in EXE_INC
- The positions of the .so files and the name of the built libraries that you are using in EXE_LIBS. For example, if you build the boost libraries you end up with a folder containing two other folders: include and lib. "include" contains the headers, while "lib" contains the compiled libraries in .so files. One of these files is libboost_system.so. To add this file to the Make/options file you should write something like:
EXE_INC = \
-I<path/to/include> \
EXE_LIBS = \
-L<path/to/lib> \
-lboost_system \
The folder lnInclude is automatically generated when you use wmake to compile, you sould not create it
MCrossover97 likes this.
EdoardoCip is offline   Reply With Quote
Old   October 21, 2020, 20:17
Default error while loading shared libraries
EXE_INC = \
EXE_LIBS = \
-L<path/to/lib> \
-lboost_system \
Dear EdoardoCip,
Thank you so much for your answer. I build the library using miniconda with this command:
conda install reaktoro
I followed your instructions and now I am able to make the solver without any error; but now when I want to call my solver (reaktoroFOAM), it gives me this error:
reaktoroFOAM.C: error while loading shared libraries: libReaktoro.so: cannot open shared object file: No such file or directory
Did I miss something?
This is the body of the solver:
#include <Reaktoro/Reaktoro.hpp>
using namespace Reaktoro;
int main()
    ChemicalEditor editor;
    editor.addAqueousPhaseWithElementsOf("H2O NaCl CaCO3 CO2");
    editor.addGaseousPhase("CO2(g)");
    editor.addMineralPhase("Calcite");
    ChemicalSystem system(editor);
    EquilibriumProblem problem(system);
    problem.add("H2O", 1, "kg");
    problem.add("CO2", 1, "mol");
    problem.add("NaCl", 0.7, "mol");
    problem.add("CaCO3", 1, "g");
    ChemicalState state = equilibrate(problem);
    state.output("result.txt");
And this is what is in the option file:
EXE_INC = \
	-I/home/mcrossover97/miniconda3/include
EXE_LIBS = \
	-L/home/mcrossover97/miniconda3/lib \
	-lReaktoro
and make file:
reaktoroFOAM.C
EXE = $(FOAM_USER_APPBIN)/reaktoroFOAM.C
I appreciate your help so much,
Mohammad
SHUBHAM9595 likes this.
Old   October 22, 2020, 02:22
Antimony is on a distinguished road
You might also have to location of the folder containing libReaktoro.so to the environment variable LD_LIBRARY_PATH
Hope this helps.
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   October 22, 2020, 02:54
You can update LD_LIBRARY_PATH with the position of libReaktoro.so. with the following command:
LD_LIBRARY_PATH=‘$LD_LIBRARY_PATH:<path/to/folder-with-libReaktoro.so>’
Also, you are missing return 0; at the end of the main.
int main()
return 0;
While the Make/file shuld be like this:
reaktoroFOAM.C
Otherwise your exe would be called reaktoroFOAM.C
Old   October 22, 2020, 07:33
Default Done!
I tried to update LD_LIBRARY_PATH with the following command:
LD_LIBRARY_PATH=‘$LD_LIBRARY_PATH:</home/mcrossover97/miniconda3/lib>’
It didn't give me any error but apparently, nothing had happened as I checked it to make sure it is updated:
echo $LD_LIBRARY_PATH
but it wasn't.
Then I tried to update the LD_LIBRARY_PATH with the following command:
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/home/mcrossover97/miniconda3/lib
Now it works! Thank you so much for your help and time!
Old   November 6, 2020, 03:42
Default Problem adding in Ubuntu
Hey Sorry to bother you guys again.
Now I want to do all the procedure in Ubuntu 18.04 (not WSL). I have done exactly the same things; but I cannot even make the solver, because it gives me this error:
(base) mohammad@mohammad-VirtualBox:~/OpenFOAM/mohammad-8/applications/solvers/reaktoroFoam$ wmake
g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3  -DNoRepository -ftemplate-depth-100 -I/opt/openfoam8/src/finiteVolume/lnInclude -I/opt/openfoam8/src/meshTools/lnInclude -I/home/mohammad/miniconda3/include -IlnInclude -I. -I/opt/openfoam8/src/OpenFOAM/lnInclude -I/opt/openfoam8/src/OSspecific/POSIX/lnInclude   -fPIC -fuse-ld=bfd -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/reaktoroFoam.o -L/opt/openfoam8/platforms/linux64GccDPInt32Opt/lib \
    -L/home/mohammad/miniconda3/lib -lfiniteVolume -lmeshTools -lreaktoro -lOpenFOAM -ldl  \
     -lm -o /home/mohammad/OpenFOAM/mohammad-8/platforms/linux64GccDPInt32Opt/bin/reaktoroFoam
/usr/bin/ld.bfd: cannot find -lreaktoro
/opt/openfoam8/wmake/makefiles/general:140: recipe for target '/home/mohammad/OpenFOAM/mohammad-8/platforms/linux64GccDPInt32Opt/bin/reaktoroFoam' failed
make: *** [/home/mohammad/OpenFOAM/mohammad-8/platforms/linux64GccDPInt32Opt/bin/reaktoroFoam] Error 1
The contents of the files are same as before:
EXE_INC = \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I$(LIB_SRC)/meshTools/lnInclude \
EXE_LIBS = \
    -L/home/mohammad/miniconda3/lib \
    -lfiniteVolume \
    -lmeshTools \
    -lreaktoro
And the LD_LIBRARY_PATH is updated:
(base) mohammad@mohammad-VirtualBox:~/OpenFOAM/mohammad-8/applications/solvers/reaktoroFoam$ echo $LD_LIBRARY_PATH
 ‘/opt/ThirdParty-8/platforms/linux64Gcc/gperftools-svn/lib:/opt/paraviewopenfoam56/lib:/opt/openfoam8/platforms/linux64GccDPInt32Opt/lib/openmpi-system:/opt/ThirdParty-8/platforms/linux64GccDPInt32/lib/openmpi-system:/usr/lib/x86_64-linux-gnu/openmpi/lib:/home/mohammad/OpenFOAM/mohammad-8/platforms/linux64GccDPInt32Opt/lib:/opt/site/8/platforms/linux64GccDPInt32Opt/lib:/opt/openfoam8/platforms/linux64GccDPInt32Opt/lib:/opt/ThirdParty-8/platforms/linux64GccDPInt32/lib:/opt/openfoam8/platforms/linux64GccDPInt32Opt/lib/dummy::/home/mohammad/miniconda3/lib
What would possibly be different between WSL and Ubuntu on VirtualBox?
Thank you so much for your help again!
Mohammad
Old   October 26, 2021, 07:37
David Moravec
dmoravec is on a distinguished road
Im very late, but maybe it is because you seem to have double : before path to reaktoro library in your LD_LIBRARY_PATH
dmoravec is offline   Reply With Quote
Old   February 23, 2024, 03:34
Dcn
Dcn is on a distinguished road
hi try changing your options as shown below
EXE_INC = \
EXE_LIBS = \
-Wl,-rpath=/home/mcrossover97/miniconda3/lib \
-lReaktoro
it should work i think after this change
libReaktoro.so is a dynamically link so OS need to know its location at runtime an this can be done using -Wl,-rpath=<location of your library>
aee likes this.
Dcn is offline   Reply With Quote
library
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
chtMultiRegionSimpleFoam samiam1000 OpenFOAM Running, Solving & CFD 39 March 31, 2016 09:43
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
Adding Radiation Sub-models into OpenFOAM 1.5 shajitah OpenFOAM 0 September 13, 2010 22:26
OpenFOAM Training and Workshop Zagreb 2628Jan2006 hjasak OpenFOAM 1 February 2, 2006 22:07
