Why Do I Need This Workaround? (Custom functionObject)
Like Tree2Likes
  • 2 Post By olesen
Old   October 12, 2020, 15:07
Default Why Do I Need This Workaround? (Custom functionObject)
Conor Crickmore
cjc96 is on a distinguished road
Hey!
As always, I hope everyone is keeping well at the moment!
I'm still stumbling my way through self-teaching C++ and basic OpenFOAM editing/development but without the time available to properly devote to learning C++ explicitly, I'm basically building my knowledge one error at a time.
Last week I implemented a new functionObject bringing the DESModelRegions functionality from OpenFOAM v2.3 to OpenFOAM v7 with a little help from wyldckat's own implementation but using a slightly different structure as a practice exercise.
The function itself works but I've had to implement a small workaround to overcome a compilation error. The problem section is as follows:
	const icoDESmodel& DES = dynamic_cast<const icoDESmodel&>(turbModel);
	tmp<volScalarField> tDESfield(DES.LESRegion());
	volScalarField &DESmodelRegions = tDESfield.ref();
	word result("DESmodelRegions");
	return store
		result,
		DESmodelRegions / dimensionedScalar(dimless, 1)
Without the (mathematically) redundant division by one, the compiler complains about type mismatches, specifically:
error: no matching function for call to ‘Foam::functionObjects::DESmodelRegions::store(Foam::word&, Foam::volScalarField&)’
‘Foam::volScalarField {aka Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>}’ is not derived from ‘const Foam::tmp<T>’
Now, I know enough to infer that the issue is if I just attempt to store 'DESmodelRegions' the program is trying to store a word, whereas with the division by one, it's being forced into storing a volScalarField as is intended. So I think the problem is in improper use of referncing in my actual calculation of DESmodelRegions, but I don't know what I've actually done wrong and arbitrary removal/addition of references didn't accomplish much
Obviously the current implementation works but is far from elegant and I'd like to understand how to avoid it in the future, so if anyone could point out my error I'd be very grateful as always!
Conor Crickmore
PhD Researcher in Automotive Aerodynamics
Aeronautical and Automotive Engineering
Loughborough University
LE11 3TU
cjc96 is offline   Reply With Quote
Old   October 31, 2020, 15:47
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Actually the problem the error shows is not the word (first parameter) but the second parameter! The store() expects the second parameter to be tmp type, which it can claim the memory of etc. In your version that didn't compile, you passed a volScalarField for storage, not a tmp. By adding in the pointless division operation, you have created a tmp and it works. You will have to decide yourself which quantity you want to store.
cjc96 and FaroukH like this.
olesen is offline   Reply With Quote
Making my custom functionObject run in parallel sippanspojk OpenFOAM Programming & Development 21 February 25, 2020 14:13
OF-4.x: Multiple Inheritance of a functionObject A_Pete OpenFOAM Programming & Development 1 September 21, 2016 11:01
Problem in sampling data of custom field function in ANSYS FLUENT v14 apek_great ANSYS 1 February 26, 2014 06:10
Create registered object at runtime using a functionObject CedricVH OpenFOAM Programming & Development 21 November 28, 2012 06:04
defining custom convetive terms CFD user CFX 1 February 22, 2009 23:40
