October 2, 2020, 08:27 |
Running a python file from OpenFOAM
K
Rep Power: 8 |
Hey Foamers
I am wondering if it is possible to run a python file by modifying OpenFOAM solver source code (like say simpleFOAM). Lets just say the python file forces printing out a random statement during running of the solver. My understanding of PyFOAM is that it is a wrapper around the C++ OpenFOAM source code so it doesn't allow running python script in the solver. Thank you in advance for your comments and thoughts on this! |
October 2, 2020, 09:27 |
Yann
Rep Power: 27 |
Hello Kuria,
Why not using the systemCall function object for this ? This function allow to execute shell commands during a run. Code:
Executes system calls, entered in the form of a string lists. Calls can be made at the following points in the calculation: - every time step - every output time - end of the calculation I usually use it to execute gnuplot scripts (e.g. to monitor residuals) but running a python script should not be a problem. Cheers, Yann |
October 6, 2020, 03:28 |
Carlo_P
Rep Power: 8 |
Hey Yann,
nice functionObject.. Does it works both with Esi and org foam version? For Kuris: you can simple write "python pythonfile.py > pythonfile.log" in that system call. |
October 6, 2020, 05:07 |
#4 | |
Yann
Rep Power: 27 |
Yes this is quite an old function object and it exists in both branches! I think it's an overlooked but powerful way to automatize tasks during a run, whether it is about running some shell commands or using other tools such as python or gnuplot. Cheers, Yann |
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 14:30 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 17:18 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 10:57 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
