customized BCs: using value as gradient of another parameter and no constraint
Like Tree1Likes
  • 1 Post By shuxuejia
Old   July 15, 2020, 23:05
Smile customized BCs: using value as gradient of another parameter and no constraint
dp
shuxuejia is on a distinguished road
Dear all,
I have been studying OpenFOAM and groovyBC boundary condition recently since I really need to use some kinds of customized boundary conditions in my customized solver. I am not sure if they can be realized in OpenFOAM or by groovyBC. I know it is very powerful but unfortunately I cannot fully handle it now. The two boundary conditions are very straightforward:
1, using value as gradient of another parameter. For example, I have two parameters to be solved, r and s. At the boundary I would like to set r=-normal gradient (s), s=0. It is different from commonly-used fixedValue, fixedGradient and mixed.
2, setting zero value and zero gradient for one parameter at the same time and no constraint for another parameters. For example, I have two parameters to be solved, p and q. At the boundary I would like to set p=0, normal gradient (p)=0, and no constraint for q.
Mathematically, the number of equations and boundary conditions did not change and still the same. Someone posted a similar question recently but what if the parameter to be solved is not the velocity but a new parameter ?
fixedValue BC with zeroGradient
Moreover, I am confused with no constraint boundary condition. Typically I called it free boundary condition. However, in the CFD and OpenFOAM, it seems that every boundary need to be implemented a boundary constraint.
If it cannot be done by groovyBC, how can I realize it by programming a new boundary condition ? I am looking forward to your responses. Thank you all for your help and comments in advance !
dp
shuxuejia is offline   Reply With Quote
Old   August 22, 2020, 00:38
Lightbulb
dp
Although I did not get response here, I have solved these problems by myself. I would like to share my methods if you need.
1)
Use a user defined BC for r. The key code is
void Foam:: sGradientFvPatchScalarField::updateCoeffs()
const fvPatchField<scalar>& si =
patch().lookupPatchField<volScalarField, scalar>("s");
scalarField sigrad = si.snGrad();
operator==(-sigrad);
fixedValueFvPatchScalarField::updateCoeffs();
2)
First set fixedValue BC with value 0. Then use fvOptions FixedValueConstraint to set value 0 in the adjacent cell of the BC.
the_ichthyologist likes this.
gradient at boundary, groovybc, no constraint
