Transport of chemical species in rhoCentralFoam |
July 15, 2020, 14:32 |
Rep Power: 7 |
Hi!
I am still learning how to use OpenFOAM, and I would like to know how can I add transport of chemical species in the implementation of rhoCentralFoam in a Mach5 case. I have already tried following the only tutorials I have found, but they are very old and since then many things have changed. I would like to do a non-equilibrium, non-reacting case (with Shatalov empirical modelling). I am using OpenFOAM-7. The ideal would be using hy2Foam, but it runs with other versions of OpenFOAM and it would be too heavy to handle with a normal pc. Thank you in advance. |
July 15, 2020, 18:24 |
Rep Power: 15 |
A masters student worked in our lab for a bit and used a reacting version of rhoCentralFoam that I'd made based on hy2Foam and the older versions that you mentioned. I'll point you to his git repository where you can find it and other potentially useful information. https://github.com/duncanam/rhoReactingCentralFoam
Caelan |
January 23, 2021, 06:48 |
#3 | |
Rep Power: 14 |
You might find this useful: http://blog.nus.edu.sg/huangwei/nus-...alfoam-solver/.
hypersonic flow, rhocentralfoam; |
Transport coefficients for chemical species | Larrein | Main CFD Forum | 0 | January 5, 2016 16:57 |
species transport model simulating chemical reaction | richard ben | FLUENT | 9 | April 10, 2013 09:57 |
chemical reaction and species transport | mohamad3564 | FLUENT | 0 | June 11, 2012 04:58 |
how to solve the multiphase species transport without chemical reaction | manjuchem0179 | Main CFD Forum | 0 | April 13, 2009 07:26 |
chemical reaction - decompostition | La S. Hyuck | CFX | 1 | May 23, 2001 01:07 |
