Fully Coupled Solvers for OpenFOAM7+ (To be ported From FE4 code base) |
July 15, 2020, 06:41 |
Elwardi Fadeli
Rep Power: 9 |
Hi folks,
So, while trying to re-write my awful library for reservoir simulations http://github.com/FoamScience/OpenRSR (Was my end-of-studies project, so I had little time ...), I decided to ditch the whole thing and start anew. Here is the logic: - Reservoir Engineering Problems desperately need fully coupled solvers (not provided in mainline OpenFOAM), so I turned to Foam-Extend: The base functionality is there (basically BlockLduMatrix); I only had to consume the library. - I don't know why, but I get the feeling that the Foam-Extend project is dying out! - FE4 was actually based on OF3 I think. So, the code base is fairly old. It has no fvOptions and the IO/solver interface is not great (among many other things). OF5+ introduced significant library-interface changes and I want to port (at least) the block-matrix functionality to newer OF releases before things get worse! Hence I have two questions: 1. How come this fully-coupled functionality didn't make it to mainline OF yet? It has been around since FE-1.6 I think! I started poking around the code in both libraries to estimate how hard (or time-consuming) porting the code from FE4 to OF7 would be (We only need several classes: VectorN/TensorN, CoeffField, [Block]:lduInterface,lduMatrix,preconditionners,solvers and smoothers). Generally speaking, It's a matter of coping with the changing interfaces of original classes but something in particular is interesting; and that is the handling of "coupled interfaces" in the code. In short, the coupled interface functionality in FE4 is handled with 3 member methods for the lduInterfaceField class (See this line from FE4 source code). Talking about: transformCoupleField, initInterfaceMatrixUpdate and updateInterfaceMatrix. As you can see, some of these methods take a lduMatrix as an argument, so, when one wants to create equivalent functions for block-coupled interfaces, it's natural to put a blockLduMatrix instead of lduMatrix. The thing is, in OF7 (See the equivalent class in OF7), these methods no longer have a lduMatrix argument (check coupledFvPatchField for an example usage of one of these methods). 2. What should I do? Stick to the interface from FE4? or is there something else I'm missing here. ----- Elwardi, Best Regards |
July 22, 2020, 07:06 |
Elwardi Fadeli
Rep Power: 9 |
Just for future reference; if anyone would attempt this again, one of the first commands you should run is (inside $FOAM_SRC/foam from foam-extend of course):
find -type d -not -iname "(*[bB]lock*)" -exec grep -r {} -e "#include.*[bB]lock.*" \; | grep -ve "/Block" account for Block-specific operations (foam-extend explicitly includes block-specific headers in those classes). Mainly, we need to edit (or create a similar class) "lduMatrix/lduSolverPerformance.H" and "GeometricField/GeometricField.H". In short, I need to re-write the hole lduMatrix and *GeometricField framework. |
July 27, 2020, 00:07 |
Vu
Rep Power: 9 |
I have been asking the same question for a long time. Hopefully, someone can reveal the reasons behind the abandonment of that feature.
By the way, You might want to try the blockCoupleSolver in rhoTool (https://github.com/fppimenta/rheoTool), which is a library developed on top of OpenFOAM. It uses petsc to assembly and solves for the matrix of coupled equations. |
July 27, 2020, 05:34 |
Elwardi Fadeli
Rep Power: 9 |
Yep, I asked related questions in different places and apparently, there is a licensing
issue (Although not sure why OF devs themselves didn't incorporate this feature in the code). See https://sourceforge.net/p/foam-extend/tickets/51/ As of JUL 2020, I see this as a lost case and won't engage in any related development. Also, I think using PETSc is cool as I hear it supports hybrid GPU/MPI parallelism but I would still prefer using a native solution. Otherwise, it might be better (from the programmer's perspective) to switch another CFD package that uses coupling out of the box You see, this feature is vital for me so I have to continue using FE4 for the time being. Thank you for reading this far! |
January 7, 2024, 03:54 |
Block-coupled solvers in OpenFOAM
Rep Power: 13 |
Dear Elwardi,
I stumbled upon this thread while looking into this topic. I've seen that a few years passed by since your last post. Is there any news on this front? Do you know if the maintainers of OpenFOAM (either .com/.org) plan to implement this feature in the code? Thanks |
block matrix, coupled solver, discussion |
[swak4Foam] swak4foam openfoam 7 installation problem | Andrea23 | OpenFOAM Community Contributions | 1 | February 17, 2020 18:11 |
Demand for a VOF OPENFOAM code base on Welch, Wilson paper (VOFWW) | Asghari_M | OpenFOAM Running, Solving & CFD | 0 | May 30, 2018 04:47 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 14:07 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Design Integration with CFD? | John C. Chien | Main CFD Forum | 19 | May 17, 2001 15:56 |
