MULES in Eulerian solvers
Like Tree1Likes
  • 1 Post By gianniTre
Old   July 2, 2020, 14:25
Lightbulb MULES in Eulerian solvers
MMNCH's Avatar
mohammadmahdi noroozi
MMNCH is on a distinguished road
Dear all friends...
I have an ambiguity about Eulerian solvers.
It is completely reasonable to use MULES in VOF based solvers like interFoam to keep the interface sharp. but in the eulerian based solvers like twoPhaseEulerFoam, multiPhaseEulerFoam, reactingEulerFoam, etc., why this limiter is used?
If I'm not mistaken, eulerian based solvers are not able to capture the interface and the nature of these methods is associated with dispersion , so what is the purpose of using this limiter in these solvers?
Can anyone clarify this issue for me?
Thanks in advance...
MMNCH is offline   Reply With Quote
Old   July 7, 2020, 14:25
Giovanni Tretola
gianniTre is on a distinguished road
The main goal of MULES is to keep the scalar bounded without limiting to an upwind scheme. So more than keep the interface sharp the results is to reduce the numerical diffusion (which is kind of the same thing but more as a side effect).
What is designed to keep the interface sharp is mainly the "compression" velocity. You control this compression through the constant Calpha.
All the solvers you mentioned use MULES primarily to ensure a bounded solution limiting the numerical diffusion.
Cheers,
Giovanni
MMNCH likes this.
gianniTre is offline   Reply With Quote
Old   July 7, 2020, 14:58
MMNCH's Avatar
Dear Dr. Tretola
Thank you very much for your reply.
eulerian multiphase flow, mules, multiphaseeulerfoam, openfoam, twophaseeulerfoam
Free Surface Ship Flow timfranke OpenFOAM Running, Solving & CFD 322 March 3, 2021 10:04
Free surface issues with interDyMFoam for hydroturbine oumnion OpenFOAM Running, Solving & CFD 0 October 6, 2017 15:05
Problem of simulating of small droplet with radius of 2mm liguifan OpenFOAM Running, Solving & CFD 5 June 3, 2014 03:53
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 23:40
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 12:16
