rhoPimpleFoam energy equation understanding problem he
Like Tree1Likes
  • 1 Post By mAlletto
Old   May 28, 2020, 09:04
Question rhoPimpleFoam energy equation understanding problem he
alexander thierfelder
superkelle is on a distinguished road
Hey,I looked into rhoPimpleFoam source code and I wonder about the energy equation. I have some questions for that.
1) Why is he.name() == "e" necessary?
2) I applied an fvOptions scalarCodedSource term to it, what was only possible on "e"
not on "he", but fvOptions(rho, he) is coded into the equation, and also the correction is called on "he" fvOptions.correct(he). Is that just because of 1) ?
scalarCodedSource fvOptions example moving heat source
3) Where does the temperature field "T" gets calculated, since it does not even get created in "createFields"? ( I think it has to be somehow implemented in the "thermo" functionality what is for me whitchcraft until now, I would be very happy for some advice to begin my research about "thermo")
    volScalarField& he = thermo.he();
    fvScalarMatrix EEqn
        fvm::div(phi, he)
            he.name() == "e"
          ? fvc::div(phi, volScalarField("Ekp", 0.5*magSqr(U) + p/rho))
          : fvc::div(phi, volScalarField("K", 0.5*magSqr(U)))
      - fvm::laplacian(turbulence->alphaEff(), he)
        fvOptions(rho, he)
    EEqn.relax();
    fvOptions.constrain(EEqn);
    EEqn.solve();
    fvOptions.correct(he);
    thermo.correct();
It would be very nice if someone of you takes some time for answering, or even just giving some hints. Thank you in advance.
superkelle is offline   Reply With Quote
Old   May 28, 2020, 12:15
Michael Alletto
mAlletto will become famous soon enough
In openfoam you can either solve an equation for the internal energy ("e") or enthalpy ("he").
This is the if else statement in the energy equation.
Once solved the energy equation, the temperature is calculated in the termo package.
For the latter see https://caefn.com/openfoam/temperature-calculation
superkelle likes this.
mAlletto is offline   Reply With Quote
Old   May 28, 2020, 12:33
Isn't it quite confusing that there is not a dummy variable instead of "he" ? So for example "x" that get set to "e" or "he" .
Old   July 12, 2020, 20:18
Joachim Herb
jherb is on a distinguished road
he is the dummy variable. Enthalpy is "h". In he.name() it is store, what is actually solved (e or h) and then the energy equation is modified accordingly. See : https://cfd.direct/openfoam/energy-equation/
jherb is offline   Reply With Quote
eeqn.h, rhopimpledymfoam, thermo
Why doesn't my simulation solve two energy equation? Roh FLUENT 12 April 18, 2019 12:33
Fluent do not use my velocity field(by UDF) to solve energy equation tangleiplus Fluent UDF and Scheme Programming 6 January 21, 2019 22:28
Convergence problem on the energy equation naruto5255 Fluent Multiphase 0 November 1, 2015 13:28
problem on energy and flow equation solving separately preetam69 FLUENT 2 July 30, 2013 22:08
Why FVM for high-Re flows? Zhong Lei Main CFD Forum 23 May 14, 1999 14:22
