Issue with codedFixedValue: oldTime()
Like Tree1Likes
  • 1 Post By anthonygay1812
Old   May 3, 2020, 01:55
Default Issue with codedFixedValue: oldTime()
Anthony Gay
anthonygay1812 is on a distinguished road
Hello
I'm trying to implement the following BC
        type               codedFixedValue;
        value              $internalField;
        redirectType       hybridParticleContinuim;
        code
            const fvMesh& fluidMeshRef = patch().boundaryMesh().mesh();
            const volScalarField& pFluid = db().lookupObject<volScalarField>("p");
            const volScalarField& pParticle = db().lookupObject<volScalarField>("p_Mean");
            const volScalarField& pFluidOld=pFluid.oldTime();
            Info<< "code accessed";
            //const scalar t = this->db().time().value();
            const label fluidIdx=fluidMeshRef.nCells();
            const label particleIdx=1;
            const scalar w=0.75;
            operator==(1-w)*pFluidOld[fluidIdx]+w*(0.5*pFluid[fluidIdx]+0.5*pParticle[particleIdx]);
Unfortunately the
pFluidOld[fluidIdx]
is triggering the following error
/p.boundaryField.fluidBound:43:28: error: invalid operands of types ‘void’ and ‘const double’ to binary ‘operator*’
/opt/openfoam7/wmake/rules/General/transform:25: recipe for target 'Make/linux64GccDPInt32Opt/fixedValueFvPatchFieldTemplate.o' failed
make: *** [Make/linux64GccDPInt32Opt/fixedValueFvPatchFieldTemplate.o] Error 1
--> FOAM FATAL IO ERROR
I can't quite figure out how to approach this. I have figured out that its pFluidOld[fluidIdx] thats returning a void value. Is there a better way to get the pressure from the previous timestep?
Any help is appreciated thank you!
anthonygay1812 is offline   Reply With Quote
Old   May 3, 2020, 02:58
Default Resolved Sort of
Anthony Gay
So it turns out my initial guess was way off and I simply had a syntax error in the operator statement, the correct line is
            operator==((1-w)*pFluidOld[fluidIdx]+w*(0.5*pFluid[fluidIdx]+0.5*pParticle[particleIdx]));
Notice the parenthesis. Unfortunately now my code is crashing when it tries to access the BC
Create time
Create mesh for time = 0
Meshes created
Reading thermophysical properties
Selecting thermodynamics package
    type            hePsiThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleInternalEnergy;
Using dynamicCode for patch fluidBound on field p at line 30 in "/home/anthonygay1812/OpenFOAM/Working/finalShockTube/0/fluid/p.boundaryField.fluidBound"
I have run into this sort of issue before and it happened when I had not properly initialized with the setFields command. So my guess is that something within the BC code may not accessible.
ruloz likes this.
boundary condition, codedfixedvalue, time average problem
Issue on zeroGradient BC for system rotation magnushaese OpenFOAM Running, Solving & CFD 2 January 28, 2022 14:43
rhoCentralFoam inviscid airfoil issue (Foam::error::printStack(Foam::Ostream&) at ??) kmkb21 OpenFOAM Running, Solving & CFD 1 March 1, 2018 02:07
Prism Layer - Core Mesh Boundary Issue InfernoxCJC STAR-CCM+ 7 November 21, 2017 16:46
foamToTecplot360 issue with multiregion solvers manuc OpenFOAM Post-Processing 2 November 21, 2016 14:51
Pressure boundary condition issue Vijay FLUENT 0 April 6, 2012 14:35
