get dimensionless field values of a geometric field |
April 6, 2020, 09:34 |
alexander thierfelder
Rep Power: 6 |
I wish to use a approximation for a coefficient "Rstabilisation" that is dependent on a dimension variable/field " nElectron" in my whole simulated region. The value of nElectron is in the "log" what is a transcendent function and only accepts dimensionless values. I worked around by defining a new dimensionless field nElectronDimless.
volScalarField nElectronDimless = nElectron; nElectronDimless.dimensions().reset(dimless); volScalarField RStabilisation = RDefault*exp(-stabParamR*log(nElectronDimless)); Code:
volScalarField RStabilisation = RDefault*exp(-stabParamR*log(nElectron.field()); ... volScalarField RStabilisation = RDefault*exp(-stabParamR*log(nElectron.value()); |
April 9, 2020, 08:08 |
Rep Power: 6 |
When someone is interested, now I work with and I define RStabilisation with its dimensions in "createFields"
RStabilisation.field() = RDefault.value()*exp(-stabParamR*log(nElectron.field())); volScalarField to power of constant how to convert to dimensionless scalar in openfoam |
November 26, 2020, 05:28 |
Adriana Ferreira
Rep Power: 8 |
I had the some problem using tanh and it worked with your solution! Thanks a lot
Field values at the boundary cells | vcvedant | OpenFOAM Running, Solving & CFD | 4 | August 2, 2017 18:50 |
using chemkin | JMDag2004 | OpenFOAM Pre-Processing | 2 | March 8, 2016 23:38 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 07:51 |
How to input Magnetic Field values in ESTER Code? | Amit Gupta | Phoenics | 0 | September 21, 2006 14:38 |
