recompiling solver issue with wmake
Like Tree6Likes
  • 3 Post By peterhess
  • 1 Post By peterhess
  • 1 Post By joshmccraney
Old   March 23, 2020, 14:48
Default recompiling solver issue with wmake
Josh McCraney
joshmccraney is on a distinguished road
Hi FOAMers!
I am trying to recompile a solver in OF6 on Ubuntu 18.04, specifically interFoam.C. This file is located here: /opt/openfoam6/applications/solvers/multiphase/interFoam
Now after editing I execute "wclean" and have no issues. When I execute "wmake" I get the error
mkdir: cannot create directory ‘/opt/openfoam6/platforms/linux64GccDPInt32Opt/applications’: Permission denied
/bin/sh: 1: cannot create /opt/openfoam6/platforms/linux64GccDPInt32Opt/applications/solvers/multiphase/interFoam/options: Directory nonexistent
make: *** No rule to make target '/opt/openfoam6/platforms/linux64GccDPInt32Opt/applications/solvers/multiphase/interFoam/options'.  Stop.
make: *** No rule to make target '/opt/openfoam6/platforms/linux64GccDPInt32Opt/applications/solvers/multiphase/interFoam/options', needed by 'all'.  Stop.
wmake error: file '/opt/openfoam6/platforms/linux64GccDPInt32Opt/applications/solvers/multiphase/interFoam/sourceFiles' could not be created in /opt/openfoam6/applications/solvers/multiphase/interFoam
If I run as root, the command is not found. Any idea what is happening? And if I go to /opt/openfoam6 and execute ./Allmake I get the error
Allwmake /opt/openfoam6
make: Nothing to be done for 'all'.
Allwmake: no ThirdParty directory found - skipping
Allwmake src
no git description found
Allwmake src/Pstream
wmake dummy
mkdir: cannot create directory ‘/opt/openfoam6/platforms/linux64GccDPInt32Opt/src’: Permission denied
/bin/sh: 1: cannot create /opt/openfoam6/platforms/linux64GccDPInt32Opt/src/Pstream/dummy/options: Directory nonexistent
make: *** No rule to make target '/opt/openfoam6/platforms/linux64GccDPInt32Opt/src/Pstream/dummy/options'.  Stop.
make: *** No rule to make target '/opt/openfoam6/platforms/linux64GccDPInt32Opt/src/Pstream/dummy/options', needed by 'all'.  Stop.
wmake error: file '/opt/openfoam6/platforms/linux64GccDPInt32Opt/src/Pstream/dummy/sourceFiles' could not be created in /opt/openfoam6/src/Pstream/dummy
joshmccraney is offline   Reply With Quote
Old   March 23, 2020, 17:37
Peter Hess
peterhess is on a distinguished road
Hello!
You need to change the premission to be able to add/modifi files in the folder.
The most easy but "dirty" way is to change the permission for the whole folder
- Go to root folder
- Type: sudo chmod -R 777 /opt/openfoam6/
- Give the password
- If that did not works then try:
Regards
Peter
Marpole, joshmccraney and MANI18 like this.
peterhess is offline   Reply With Quote
Old   March 23, 2020, 17:46
Josh McCraney
Originally Posted by peterhess View Post
Hello!
- Go to root folder
- Give the password
Regards
Peter
Two questions: what is the root folder? Would that be /opt/openfoam6?
Also, in opt/openfoam6 when I run ./Allmake I get the error
Allwmake src
wmake dummy
Is there a way I can fix this or should I uninstall-reinstall OpenFOAM? Given the Coronavirus I have very slow internet and would prefer not to reinstall if you know a way to fix the issue?
Old   March 23, 2020, 18:29
Peter Hess
Go to /opt
Type: cd ..
You are now in root!
Regards
Peter
joshmccraney likes this.
Old   March 24, 2020, 12:03
Josh McCraney
Go to /opt
Type: cd ..
Regards
Peter
You're the man Peter! Thanks so much; you've no idea what a headache you've saved me from!
Old   May 19, 2020, 21:32
Josh McCraney
Hey Peter
I copied /opt/openfoam6/applications/solvers/multiphase/interFoam and called it bfInterFoam. Then I edited bfInterFoam/Make/files to match the name bfInterFoam.
From here, I went into /opt/openfoam6/applications/solvers/multiphase/bfInterFoam and executed wclean (no errors) and then wmake, to which I get
make: *** No rule to make target '/opt/openfoam6/platforms/linux64GccDPInt32Opt/applications/solvers/multiphase/bfInterFoam/bfInterFoam.C.dep', needed by '/opt/openfoam6/platforms/linux64GccDPInt32Opt/applications/solvers/multiphase/bfInterFoam/bfInterFoam.o'.  Stop.
I executed both commands you recommended but I still get this error. Any idea?
EDIT: nevermind, the error was I forgot to change the name of the .C file. can't believe this!
Old   May 20, 2020, 04:51
Peter Hess
Hallo!
The best road map für doing this is to follow the tutorial:
https://openfoamwiki.net/index.php/H...ure_to_icoFoam
I can not answer the question directly, cause it is a while since I made thoe changes...
Regards
Peter
Old   May 20, 2020, 17:21
Luis Eduardo
lebc is on a distinguished road
I had a similar issue some time ago, I was compiling a new solver and it just didn't work, but after changing:
EXE = $(FOAM_APPBIN)/interFoam
by
EXE = $(FOAM_USER_APPBIN)/interFoam
it worked. Just go to your Make folder and change it in the file "files".
Hope it works!
lebc is offline   Reply With Quote
Old   May 20, 2020, 17:42
Josh McCraney
Thanks for the reply! I think I should have made my edit bigger, but the issue was the .C was not capitalized
lebc likes this.
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 07:29
[OpenFOAM.org] Errors compiling OpenFOAM-5.0 renardf OpenFOAM Installation 1 January 12, 2018 09:35
[OpenFOAM.org] wmake problem vville OpenFOAM Installation 1 October 8, 2015 06:01
Patches for OpenFOAM 1.7 on MacOS X gschaider OpenFOAM Installation 101 September 21, 2011 06:37
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 05:26
