Adding dimensioned scalar/scalar field to chtMultiRegionSimpleFoam/chtMultiRegionFoam |
March 7, 2020, 08:36 |
Xun Lan
Rep Power: 7 |
Hi Foamers,
I am currently trying to add electrical potential transport equations to chtMultiRegionSimpleFoam/chtMultiRegionFoam. However, I failed to add dimensioned scalars and scalar fields to createFields.H (createSolidFields.H) in chtMultiRegionFoam. The way I did is the same as what I did for icoFoam (https://openfoamwiki.net/index.php/H...ure_to_icoFoam) But it does not work here. In chtMultiRegionFoam, the createFields.H (createSolidFields.H) file is more complex and it seems that the way of defining scalars is also different, which I don't understand by scanning the code lines. Does anyone have any idea/experience on this? Btw I installed Openfoam 5x because it's the latest version that still has chtMultiRegionSimpleFoam, while the later versions combine chtMultiRegionSimpleFoam and chtMultiRegionFoam. Thanks in advance, Lan |
March 9, 2020, 09:00 |
Hasan Celik
Rep Power: 10 |
Would you share what you are trying to do exactly, your modifications and the error that you get? This way is it not possible to guess where you are having a problem.
For v6, v7, you can use chtMultiRegionFoam as well, you just define it as steady problem and it works like old chtMultiRegionSimpleFoam I guess. |
March 9, 2020, 10:45 |
#3 | |
Xun Lan
Rep Power: 7 |
Simply speaking, I'm trying to add a transport equation into chtMultiRegionFoam like fvm::laplacian(a, X) == b My current problem is to implement the parameters / dimensioned scalars (a and b) and the scalar field (X). In the tutorial that I listed above, it can be done by simply add the lines below into createFields.H: HTML Code:
Info<< "Reading diffusivity a" << endl; dimensionedScalar a ( transportProperties.lookup("a") ); Info<< "Reading field fe and fH\n" << endl; volScalarField X ( IOobject ( "X", runTime.timeName(), solidRegions[i], IOobject::MUST_READ, IOobject::AUTO_WRITE ), solidRegions[i] ); HTML Code:
// Initialise solid field pointer lists PtrList<coordinateSystem> coordinates(solidRegions.size()); PtrList<solidThermo> thermos(solidRegions.size()); PtrList<radiation::radiationModel> radiations(solidRegions.size()); PtrList<fv::options> solidHeatSources(solidRegions.size()); PtrList<volScalarField> betavSolid(solidRegions.size()); PtrList<volSymmTensorField> aniAlphas(solidRegions.size()); List<bool> residualReachedSolid(solidRegions.size(), true); List<bool> residualControlUsedSolid(solidRegions.size(), false); Thanks again, Lan Last edited by Lann; March 10, 2020 at 06:38. |
March 9, 2020, 11:05 |
Carlos Rubio Abujas
Rep Power: 11 |
I've been recently trying to adapt chMultiRegionFoam as well. Using OF6 in this my case.
As far as I can understand the code, in this solver the parameters (T, p, rho, ...) are not contained in a single field but each region has its own parameters. In the fluid/createFluidFields.H file a series of PtrList are defined for the magnitudes of interes. Bellow, inside the forAll loop, these properties are read and stored in the list. Code:
// Initialise fluid field pointer lists PtrList<rhoReactionThermo> thermoFluid(fluidRegions.size()); PtrList<volScalarField> rhoFluid(fluidRegions.size()); PtrList<volVectorField> UFluid(fluidRegions.size()); PtrList<surfaceScalarField> phiFluid(fluidRegions.size()); PtrList<uniformDimensionedVectorField> gFluid(fluidRegions.size()); PtrList<uniformDimensionedScalarField> hRefFluid(fluidRegions.size()); PtrList<volScalarField> ghFluid(fluidRegions.size()); PtrList<surfaceScalarField> ghfFluid(fluidRegions.size()); PtrList<compressible::turbulenceModel> turbulenceFluid(fluidRegions.size()); PtrList<CombustionModel<rhoReactionThermo>> reactionFluid(fluidRegions.size()); PtrList<volScalarField> p_rghFluid(fluidRegions.size()); PtrList<radiation::radiationModel> radiation(fluidRegions.size()); PtrList<volScalarField> KFluid(fluidRegions.size()); PtrList<volScalarField> dpdtFluid(fluidRegions.size()); PtrList<multivariateSurfaceInterpolationScheme<scalar>::fieldTable> fieldsFluid(fluidRegions.size()); PtrList<volScalarField> QdotFluid(fluidRegions.size()); List<scalar> initialMassFluid(fluidRegions.size()); PtrList<IOMRFZoneList> MRFfluid(fluidRegions.size()); PtrList<fv::options> fluidFvOptions(fluidRegions.size()); // Populate fluid field pointer lists forAll(fluidRegions, i) { Info<< "*** Reading fluid mesh thermophysical properties for region " << fluidRegions[i].name() << nl << endl; Info<< " Adding to thermoFluid\n" << endl; thermoFluid.set(i, rhoReactionThermo::New(fluidRegions[i]).ptr()); ... } The same things apply to the solid fields, in case you need to modify them. Hope it helps! |
March 10, 2020, 04:28 |
Hasan Celik
Rep Power: 10 |
You need to define it in a such way:
betavSolid.set ( i, new volScalarField ( IOobject ( "betavSolid", runTime.timeName(), solidRegions[i], IOobject::NO_READ, IOobject::NO_WRITE ), solidRegions[i], dimensionedScalar(dimless, scalar(1)) ) ); |
March 10, 2020, 06:40 |
Xun Lan
Rep Power: 7 |
Thanks Carlos! I'll look into setRegionFluid/SolidField.H
adding term, chtmulitregionfoam, chtmultiregionsimplefoam, solver development |
multiRegionHeater error | ordinary | OpenFOAM Running, Solving & CFD | 2 | June 9, 2020 18:43 |
Adding magnetic field to rhoCentralFoam | pumpkinITER | OpenFOAM Programming & Development | 5 | April 7, 2016 13:33 |
chtMultiRegionSimpleFoam: strange error | samiam1000 | OpenFOAM Running, Solving & CFD | 26 | December 29, 2015 23:14 |
Adding Temperature field to IcoFoam | yapalparvi | OpenFOAM Programming & Development | 14 | November 19, 2015 05:57 |
Adding temperature field to InterFoam | yapalparvi | OpenFOAM Running, Solving & CFD | 8 | October 14, 2009 21:18 |
