how to output the volVectorField correctly?
Like Tree1Likes
  • 1 Post By akashpatel95
Old   February 17, 2020, 10:26
Post how to output the volVectorField correctly?
王子阳
wangziyang is on a distinguished road
hi everyone!
i recently try to output a volVectorField CC_ in a turbulent moedel DCMM.C
but when i complie .c programm, it show show the following error:
HTML Code:
DCmM.C: In member function ‘virtual void Foam::incompressible::LESNonlinearModels::DCMM::correct(const Foam::tmp<Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh>
 >&)’:DCMM.C:291:6: error: expected primary-expression before ‘)’ token
my output code is as follows:
HTML Code:
void DCMM::correct
    const tmp<volTensorField>& gradU
    LESNonlinearModel::correct(gradU);
    updateSubGridScaleFields(gradU());
 const volVectorField CC_=CC(gradU);  // CC is a function of gradU, also is a volVectorField
       CC_
        IOobject
            "CC_",
            runTime_.timeName(),
            mesh_,
            IOobject::NO_READ,
            IOobject::AUTO_WRITE
        mesh_,
     );      //  expected primary-expression?? why??
how can i solve the problem?
i need help
thanks
wangziyang is offline   Reply With Quote
Old   February 17, 2020, 17:16
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
You try to construct CC_ twice?
HPE is offline   Reply With Quote
Old   February 17, 2020, 20:50
王子阳
hi HPE
thanks for your reply!
how can i "construct" twice? i am a newer in openfoam, i can't understand what's your saying
best wishes
ziyang
Old   February 18, 2020, 03:21
HPE
HPE's Avatar
An object with the same name and the same type cannot be constructed more than once in its scope in C++. Pay attention to the two opers you did for CC_.
Old   February 19, 2020, 17:22
Akash Patel
akashpatel95 is on a distinguished road
Originally Posted by wangziyang View Post
hi everyone!
HTML Code:
DCmM.C: In member function ‘virtual void Foam::incompressible::LESNonlinearModels::DCMM::correct(const Foam::tmp<Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> >&)’:DCMM.C:291:6: error: expected primary-expression before ‘)’ token      );
HTML Code:
void DCMM::correct(    const tmp<volTensorField>& gradU){    LESNonlinearModel::correct(gradU);    updateSubGridScaleFields(gradU()); const volVectorField CC_=CC(gradU);  // CC is a function of gradU, also is a volVectorField       CC_     (        IOobject        (            "CC_",            runTime_.timeName(),            mesh_,            IOobject::NO_READ,            IOobject::AUTO_WRITE        ),        mesh_,             );      //  expected primary-expression?? why?? }
i need help
thanks
volVectorField
CC_
IOobject
"CC_",
mesh_,
IOobject::NO_READ,
mesh_,
dimensionedVector("0",dimLength/dimTime,Zero)
This will create empty volVectorField defined on mesh with all fields as zero and dimension as m/s. If you need dimension less fields simply swap "dimLength/dimTime" by "dimless"
Also it seems that you have already declared volVectorField CC_ in the line above which constructs an object named CC_. You cannot create another object with same name immediately below.
akashpatel95 is offline   Reply With Quote
Old   February 25, 2020, 03:23
Smile
王子阳
thanks for your reply! akashpatel95
i will try again
best wishes
ziyang
Old   February 25, 2020, 11:08
Fabien Robaux
frobaux is on a distinguished road
HTML Code:
DCmM.C: In member function ‘virtual void  error: expected primary-expression before ‘)’}
Well, This error, I got it a lot. It happens most of the time when you called
myFunction(a,b, )
(There is a comma => so before the ')', we expect another primary expression, which is missing.)
What you should do is something like, as akashpatel95 said:
Originally Posted by akashpatel95 View Post
volVectorField
       CC_
        IOobject
            "CC_",
            mesh_,
            IOobject::NO_READ,
         mesh_,
Then you fill it
//then, you fill it with the output of your function
CC_=CC(gradU);
//then you write it manually
CC_.write(); // this write directly the fields, so most of the time at each time step => to use only in the debugging steps
frobaux is offline   Reply With Quote
Old   February 27, 2020, 00:00
Post output the field every 0.001s
王子阳
thanks for your reply! frobaux
it works well according to your guidance!
but i want to output the CC_ fields based on ControlDict , for example, output CC_ every 0.001s
i try to insert the code " if (runTime.writeTime())" ,but produce the error
"error: ‘runTime’ was not declared in this scope
if (runTime.outputTime())"
i think i may be need insert the "creatTime.H" and "writeTime.H"
how can i output the field every 0.001s?
best wishes
ziyang
Old   February 27, 2020, 00:33
Akash Patel
First you need to create runTime object using
Foam::Time runTime(Foam::Time::controlDictName, args);
Then, you can use it like this (This will make sure that your CC_ field is only written when you want according to controlDict, in this case, every 0.001 seconds).
if(runTime.write()) {
CC_.write();
We are developing an open-source software for constructing reduced order models for your CFD simulations in OpenFOAM that runs several magnitude faster. Visit the link below to learn more.
AccelerateCFD - OpenFOAM based reduced order model solver for CFD using Proper Orthogonal Decomposition.
Old   February 27, 2020, 05:56
Fabien Robaux
Well, I'm not sure of that but
- if you used the IOobject::AUTO_WRITE options, it should work automatically according to the main parameters of your controlDict (writeControl and writeInterval)
- you can also add a subdictionnary in your controlDict file
functions
     myOutputObject
        type writeObjects;
        functionObjectLibs ( "libutilityFunctionObjects.so" );
        objects
                "CC_"
        writeControl     adjustableRunTime;
        writeInterval    0.001;
The third possibility is the solution given by akashpatel95.: You recreate a runTime.
But where is that part of code located/ called?
Old   February 27, 2020, 09:11
Post
  #11
王子阳
functions
     myOutputObject
        type writeObjects;
        objects
                "CC_"
Thanks very much for your reply!akashpatel95 and frobaux
my code is in a new SGS turbulent model.
The code i present to you is a part of DCNM .C programm (this new turbulent model)
the code is as follows:
// * * * * * * * * * * * * * * * Member Functions  * * * * * * * * * * * * * //
void DCNM::correct
 //int main(int argc, char *argv[])
 // #include "setRootCase.H"
 //  #include "createTime.H"
      volVectorField     CC_
        IOobject
            "CC_",
            mesh_,
            IOobject::MUST_READ,
            mesh_,
            dimensionedVector ("CC_",dimless,vector(0,0,0))
            CC_=CC(gradU); // CC is a function of gradU, it has been calculated in private member function section
	if(runTime.write())
	      CC_.write();
but the code will make a error according the suggestion of akashpatel95,
  error: ‘args’ was not declared in this scope
i think my output code is in tubulence model source program, so it can't use the "AUTO_WRITE",
and i also think akashpatel95's advice is right, but how can i solve the error ?
do i need insert any code to my program?
best wishes!
ziyang
Old   February 27, 2020, 09:43
raumpolizei is on a distinguished road
Hey, if this inside a turbulence model, you should be able to access the Time object with the following line (no need to create a new Time object, it is already present so lets use it):
const Time& t = this->time();
Regarding the writing part, try to use something like this(check the extended source code guide for more information):
if(t.writeTime()) // or t.outputTime()
    CC_.write();
raumpolizei is offline   Reply With Quote
Old   February 27, 2020, 12:34
Akash Patel
If your code is inside a turbulence model, then you cannot create runTime object. The syntax I provided for runTime is for process happening inside main() function.
I think for source code, AUTO_WRITE should work just fine while declaring volVectorField
frobaux likes this.
Old   February 27, 2020, 13:34
Fabien Robaux
Well, args is not defined in your scope.
Did you try to add what I suggest in your controlDict?
Not sure because I'm also quite a beginer in openFoam, but you have acess to time trough db or mesh_, so maybe try
if(db().time().write()) // or mesh_.time().write()
Old   March 10, 2020, 00:09
Default my view
  #15
王子阳
hi! frobaux and akashpate95
very thanks for your reply, and i also very sorry the late reply
according to your suggestions, i have solve my question, i want to share the solution here
first, it shoulid note that i work in of2.3, my purpose is to output the volVectorField CC_ in turbulence model program (eg Smagorinsky.C)
the first step, in priviate member faction, i insert the cord as followsin "updateSubGridScaleFields" part)
CC_=CC(gradU);
CC_.correctBoundaryConditions();
and i also define a volVectorField named CC in this part,and it will return the value to CC.
the second part, in Constructors part, insert the CC_ write code.(the code is memtioned before)
the last part,in Member faction part, insert the code " CC_=CC(gradU); "
meanwhile, in .H programe , CC and CC_ should declare.
ziyang
best wishes!
ioobject
Projected area to output parameters Daniil85 Fluent UDF and Scheme Programming 1 March 16, 2016 16:44
CGNS Output file parameters ant0wn SU2 1 August 19, 2013 15:47
[ANSYS Meshing] ICEM output precision papis ANSYS Meshing & Geometry 4 July 9, 2013 10:54
[Other] Output Format of MetaMesh t42 OpenFOAM Meshing & Mesh Conversion 0 August 3, 2007 05:28
Output from the Monitor point command swapnil CFX 0 November 20, 2002 23:08
