Interpolation from several volscalarfield named Y[i]
Like Tree2Likes
  • 1 Post By Daniel_Khazaei
Old   January 27, 2020, 08:25
Default Interpolation from several volscalarfield named Y[i]
Farzad Faraji
farzadmech is on a distinguished road
Dear friends
I have defined several volScalarField as below;
label N = 2;
    PtrList<volScalarField> Y(N);
and now I want to interpolate them. As am example, we interpolate velocity U as below;
 UInterp_
        interpolation<vector>::New
            cloud.solution().interpolationSchemes(),
            cloud.U()
How should I interpolate using PtrList?
Thanks,
Farzad
farzadmech is offline   Reply With Quote
Old   January 27, 2020, 09:58
Daniel
Daniel_Khazaei will become famous soon enough
I think you can try and make a PtrList of your interpolators which can be recalled for each element by [] operator.
farzadmech likes this.
Daniel_Khazaei is offline   Reply With Quote
Old   January 27, 2020, 10:46
Farzad Faraji
Thank you for your response dear Daniel. So what are you saying is this(could you please confirm that);
YiInterp_[1]
        interpolation<scalar>::New              //scalarField
            cloud.Yi()
And;
YiInterp_[2]
            cloud.Yi()
So what should I do with Yi()?
Old   January 27, 2020, 11:32
Daniel
Well I'm writing this on the fly without knowing what your trying to do exactly, it seems that you are trying to implement this at constructor level:
1- You can create a PtrList without knowing its size and elements by using the null constructor provided by class PtrList.
step #1
Initialize your list with null constructor at initializer list level as follow:
YiInterp_()
if you already know the size:
YiInterp_(list_size_here)
step #2
Now inside the constructor body just loop over the element, but if you have used the null constructor you need to set a size before starting to access elements:
YiInterp_.setSize(list_size_here); // skip this if you have set the size before
forAll(YiInterp_, i)
    YiInterp_.set
        i,
            cloud.Yi()[i]
NOTE: here I assumed that Yi is a PtrList itself, otherwise I don't see any point to create a list of interpolators.
Old   January 27, 2020, 12:37
Farzad Faraji
Thanks Daniel. I will try the way you suggested and let you know.
Farzad
Old   January 27, 2020, 13:05
Daniel
Farzad
I have just updated my previous post with the correct syntax.
ptrlist, volscalarfield list
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 06:37
Near wall treatment in k-omega SST Arnoldinho OpenFOAM Running, Solving & CFD 38 March 8, 2017 14:48
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 12:39
writing execFlowFunctionObjects immortality OpenFOAM Post-Processing 30 September 15, 2013 07:16
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
