Alex
Rep Power: 7 ![]() |
I am trying to create a new solver to analyse the Nusselt number along a vertical wall. I get the following errors after I input the cmmand "wmake".
Do you know how could I solve it? Code:
federico@federico-ZenBook-Pro-15-UX550GE-UX550GE:~/OpenFOAM/OpenFOAM-4.x/applications/solvers/heatTransfer/buoyantBoussinesqPimpleFoamNu$ wmake /home/federico/OpenFOAM/OpenFOAM-4.x/applications/solvers/heatTransfer/buoyantBoussinesqPimpleFoamNu Making dependency list for source file buoyantBoussinesqPimpleFoamNu.C could not open file fvCFD.H for source file buoyantBoussinesqPimpleFoamNu.C due to No such file or directory could not open file volFieldsFwd.H for source file buoyantBoussinesqPimpleFoamNu.C due to No such file or directory could not open file surfaceFieldsFwd.H for source file buoyantBoussinesqPimpleFoamNu.C due to No such file or directory could not open file turbulentTransportModel.H for source file buoyantBoussinesqPimpleFoamNu.C due to No such file or directory could not open file radiationModel.H for source file buoyantBoussinesqPimpleFoamNu.C due to No such file or directory could not open file fvOptions.H for source file buoyantBoussinesqPimpleFoamNu.C due to No such file or directory could not open file pimpleControl.H for source file buoyantBoussinesqPimpleFoamNu.C due to No such file or directory could not open file wallFvPatch.H for source file buoyantBoussinesqPimpleFoamNu.C due to No such file or directory could not open file fvPatch.H for source file buoyantBoussinesqPimpleFoamNu.C due to No such file or directory could not open file createControl.H for source file buoyantBoussinesqPimpleFoamNu.C due to No such file or directory could not open file createPhi.H for source file buoyantBoussinesqPimpleFoamNu.C due to No such file or directory could not open file readTransportProperties.H for source file buoyantBoussinesqPimpleFoamNu.C due to No such file or directory could not open file readGravitationalAcceleration.H for source file buoyantBoussinesqPimpleFoamNu.C due to No such file or directory could not open file readhRef.H for source file buoyantBoussinesqPimpleFoamNu.C due to No such file or directory could not open file gh.H for source file buoyantBoussinesqPimpleFoamNu.C due to No such file or directory could not open file createMRF.H for source file buoyantBoussinesqPimpleFoamNu.C due to No such file or directory could not open file createIncompressibleRadiationModel.H for source file buoyantBoussinesqPimpleFoamNu.C due to No such file or directory could not open file createFvOptions.H for source file buoyantBoussinesqPimpleFoamNu.C due to No such file or directory could not open file createTimeControls.H for source file buoyantBoussinesqPimpleFoamNu.C due to No such file or directory could not open file CourantNo.H for source file buoyantBoussinesqPimpleFoamNu.C due to No such file or directory could not open file setInitialDeltaT.H for source file buoyantBoussinesqPimpleFoamNu.C due to No such file or directory could not open file initContinuityErrs.H for source file buoyantBoussinesqPimpleFoamNu.C due to No such file or directory could not open file readTimeControls.H for source file buoyantBoussinesqPimpleFoamNu.C due to No such file or directory could not open file setDeltaT.H for source file buoyantBoussinesqPimpleFoamNu.C due to No such file or directory could not open file continuityErrs.H for source file buoyantBoussinesqPimpleFoamNu.C due to No such file or directory g++ -std=c++0x -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I. -I../buoyantBoussinesqSimpleFoamNu -I/home/federico/OpenFOAM/OpenFOAM-4.x/src/TurbulenceModels/turbulenceModels/lnInclude -I/home/federico/OpenFOAM/OpenFOAM-4.x/src/TurbulenceModels/incompressible/lnInclude -I/home/federico/OpenFOAM/OpenFOAM-4.x/src/transportModels -I/home/federico/OpenFOAM/OpenFOAM-4.x/src/transportModels/incompressible/singlePhaseTransportModel -I/home/federico/OpenFOAM/OpenFOAM-4.x/src/thermophysicalModels/radiation/lnInclude -I/home/federico/OpenFOAM/OpenFOAM-4.x/src/sampling/lnInclude -I/home/federico/OpenFOAM/OpenFOAM-4.x/src/meshTools/lnInclude -I/home/federico/OpenFOAM/OpenFOAM-4.x/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/federico/OpenFOAM/OpenFOAM-4.x/src/OpenFOAM/lnInclude -I/home/federico/OpenFOAM/OpenFOAM-4.x/src/OSspecific/POSIX/lnInclude -fPIC -c buoyantBoussinesqPimpleFoamNu.C -o /home/federico/OpenFOAM/OpenFOAM-4.x/platforms/linux64GccDPInt32Opt/applications/solvers/heatTransfer/buoyantBoussinesqPimpleFoamNu/buoyantBoussinesqPimpleFoamNu.o buoyantBoussinesqPimpleFoamNu.C:48:10: fatal error: fvCFD.H: No such file or directory #include "fvCFD.H" ^~~~~~~~~ compilation terminated. make: *** [/home/federico/OpenFOAM/OpenFOAM-4.x/wmake/rules/General/transform:8: /home/federico/OpenFOAM/OpenFOAM-4.x/platforms/linux64GccDPInt32Opt/applications/solvers/heatTransfer/buoyantBoussinesqPimpleFoamNu/buoyantBoussinesqPimpleFoamNu.o] Error 1 |
Alex
Any help please? I really need it
Yogesh Bapat
Rep Power: 15 ![]() |
Use proper Make/options file. You can check Make/options file for similar solver.
Alex
Thanks for the answer, I copied the options file from buoyantBoussinesqPimpleFoam. I even created a dummy solver as an attempt, copying the same folder of buoyantBoussinesqPimpleFoam and just changing the name of the solver, but I have the same errors when I type wmake
Eren
Rep Power: 9 ![]() |
You need to change the line in make/files
EXE = $(FOAM_APPBIN)/XFoam to Code:
EXE = $(FOAM_USER_APPBIN)/XFoam |
new solver, nusselt calculation, wmake error |
Two phase flow in porous medium | Milaad | OpenFOAM | 7 | July 1, 2024 05:08 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
