How to code the the coupling of velocity and concentration fluctuations? |
December 13, 2019, 09:25 |
Pedro Ramos
Rep Power: 14 |
to study the fluctuations of the velocity and the fluctuations of the concentration of a passive scalar, I've inserted this in my controlDict file: fieldAverage { type fieldAverage; functionObjectLibs ( "libfieldFunctionObjects.so"); [...] fields ( U { mean on; prime2Mean on; base time; } s { mean on; prime2Mean on; base time; } ); } #includeFunc scalarTransport As you know, this will give me U_prime2mean and s_prime2mean (indicated with arrows) Now, I want to couple both fluctuations and get uprime_sprime_mean. Does anyone know how? |
December 15, 2019, 16:45 |
Tobias Holzmann
Rep Power: 52 |
maybe you can use the new fields and use a calc function. E.g. Code:
postProcess -func calc ... It might also work on the fly, by using the calc function directly inside the controlDict but for this, the new generated fields should be registered in the database. Out of the box, I am not sure, if this can be done on the fly.
Keep foaming, Tobias Holzmann |
December 15, 2019, 16:53 |
#3 | |
Pedro Ramos
Rep Power: 14 |
December 16, 2019, 06:50 |
Agustín Villa
Rep Power: 15 |
Hi Pedro,
I faced the same problem when performing LES. I think you want to do something similar, isn't it? What you would need is to create a functionObject that reads U, UMean and T,TMean and computes ut=(U-UMean)*(T-TMean) You can do this, of course, directly in your solver by calling TMean and UMean, defining ut... In my case I went farther (other turbulent statistics) and I modified a function object in order to generate the fluctuating fields. |
December 16, 2019, 07:22 |
Pedro Ramos
Rep Power: 14 |
Gracias, Agustín!
do you mean I need to write a separate solver (copy-paste the files of an existent one) and adapt two things: In the fields.H file, all variables are defined. I can add my new variable there; In the solver, in the while loop of the time, after the flow equations are solved, add the operation for you new variable. For example: newVariable = c * U; is this your suggestion? |
December 16, 2019, 07:25 |
Agustín Villa
Rep Power: 15 |
De nada Pedro
Yes, it is. Remember that you must include not only ut, but also UMean and TMean in your new solver. You can run it as you prefer, but please wait until you have a converged UMean and TMean! |
December 16, 2019, 07:34 |
Pedro Ramos
Rep Power: 14 |
Yes, ok, but I already get that from here:
U { mean on; prime2Mean on;\leftarrow base time; } no? |
December 16, 2019, 07:50 |
Agustín Villa
Rep Power: 15 |
Effectively. You must run first a simulation averaging U and T (with your usual solver), and once UMean and TMean have converged you can use the second solver.
December 16, 2019, 07:51 |
#9 |
Pedro Ramos
Rep Power: 14 |
aaaaah, I get it now, thanks a lot!!!
January 22, 2020, 08:41 |
#10 | |
Pedro Ramos
Rep Power: 14 |
February 24, 2020, 09:30 |
#11 |
Pedro Ramos
Rep Power: 14 |
average field, concentration, fluctuations, passive scalar |
dispersion with radial velocity | CharlineF | OpenFOAM Programming & Development | 3 | September 13, 2019 13:24 |
Unsteady field advected by steady velocity field | t.oliveira | OpenFOAM Running, Solving & CFD | 2 | December 28, 2015 14:42 |
Velocity from varying particle's concentration | nombood | Fluent Multiphase | 2 | April 25, 2014 10:32 |
velocity in diffusion process | reyeszjj | Main CFD Forum | 1 | March 21, 2010 04:24 |
How to solve velocity & concentration seperately? | Cloudy | Phoenics | 5 | March 11, 2002 23:13 |
