How can I change the value of a face in a field?
Like Tree3Likes
  • 2 Post By einstein_zee
  • 1 Post By einstein_zee
Old   December 12, 2019, 12:44
Default How can I change the value of a face in a field?
David Andersson
sippanspojk is on a distinguished road
Dear foamers, I need your help!
As the title says I am trying to change the value of the faces of a defined patch. I have modified the pimpleFoam solver to generate a dimensionless volScalarField that I have initialized to 0.0.
I would then like to within a functionObject loop over the faces of the desired patch and assign a specific value to each face.
As I start I did a very simple case where I wanted to try to change the initial value 0.0 to 1.0 but that didn't work.
In my myFunctionObject.C file I have the following code
    const volScalarField& myField = lookupObject<volScalarField>("myField");
    forAll(myField.boundaryField()["defined patch"], faceIt){
        myField.boundaryField()["defined patch"][faceIt] == 1.0;
        Info << myField.boundaryField()["defined patch"][faceIt] << endl;
The functionObject does compile but with a warning saying:
myFunctionObject.C:178:41: warning: value computed is not used [-Wunused-value]
myField.boundaryField()[6][faceIt] == 1.0;
When I then run the case the output is still 0 and not 1 as I was hoping for.
Can someone help me whit this one??
Thank you!
David
sippanspojk is offline   Reply With Quote
Old   December 12, 2019, 16:49
Joachim Herb
jherb is on a distinguished road
[QUOTE=sippanspojk;752272]
This compares your boundary field value with 1.0 and then throws away the result. You should use just one "=".
jherb is offline   Reply With Quote
Old   December 13, 2019, 03:14
David Andersson
[QUOTE=jherb;752291]
Ok that makes sence actually. "==" returns either false or true and then moves on, right?
I tried it out with only one "=" and then I couldn't compile my functionObject. I got the following error message:
myFunctionObject.C:178:41: error: assignment of read-only location '(&(&(& myField)->Foam::GeometricField<Type, PatchField, GeoMesh>::boundaryField<double, Foam::fvPatchField, Foam::volMesh>())->Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Boundary::<anonymous>.Foam::FieldF ield<Foam::fvPatchField, double>::<anonymous>.Foam::PtrList<Foam::fvPatchFi eld<double> >::<anonymous>.Foam::UPtrList<T>:perator[]<Foam::fvPatchField<double> >(6))->Foam::fvPatchField<double>::<anonymous>.Foam::Fie ld<double>::<anonymous>.Foam::List<double>::<anony mous>.Foam::UList<T>:perator[]<double>(faceIt)'
myField.boundaryField()[6][faceIt] = 1.0;
Any idea of what this means?
Old   December 16, 2019, 06:03
Hosein
einstein_zee is on a distinguished road
Hii there,
Looks like you should use boundaryFieldRef() instead of boundaryField().
jherb and Tobi like this.
einstein_zee is offline   Reply With Quote
Old   December 17, 2019, 04:04
David Andersson
Originally Posted by einstein_zee View Post
Hii there,
Thanks Hosein, this helps!
However, only if I modify the solver and change the boundary value from there. But If I take the exact same row in my functionObject it complains:
myFunctionObject.C:179:34: error: passing ‘const volScalarField {aka const Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>}’ as ‘this’ argument of ‘Foam::GeometricField<Type, PatchField, GeoMesh>::Boundary& Foam::GeometricField<Type, PatchField, GeoMesh>::boundaryFieldRef() [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh]’ discards qualifiers [-fpermissive]
myField.boundaryFieldRef()[patchIt][faceIt] = 1.0;
Old   December 17, 2019, 05:44
Hosein
I think this one "lookupObjectRef()" should solve the issue. This means now you don't need "const" qualifier.
nado likes this.
Old   December 17, 2019, 05:52
David Andersson
That did the trick!
Thank you very much for you quick and helpful response.
functionobject, volscalarfield
[blockMesh] Internal walls of zero thickness anger OpenFOAM Meshing & Mesh Conversion 23 February 6, 2020 19:25
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
change velocity field LM4112 OpenFOAM Running, Solving & CFD 12 February 5, 2014 12:56
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
Error message: 8 face(s) not in face lists of adjacent cells jyoung79 FLUENT 0 November 10, 2012 17:09
