What does setOriented() do?
Like Tree3Likes
  • 3 Post By olesen
Old   December 4, 2019, 09:54
Post What does setOriented() do?
Jesper R. K. Qwist
Jesper_Roland is on a distinguished road
Hi everyone,
When constructing a field like surface field of Type like the following:
    // construct GeometricField<Type, fvsPatchField, surfaceMesh>
    tmp<GeometricField<Type, fvsPatchField, surfaceMesh>> tfieldFlux
        new GeometricField<Type, fvsPatchField, surfaceMesh>
            IOobject
                "flux("+psi_.name()+')',
                psi_.instance(),
                psi_.mesh(),
                IOobject::NO_READ,
                IOobject::NO_WRITE
            psi_.mesh(),
            dimensions()
    GeometricField<Type, fvsPatchField, surfaceMesh>& fieldFlux = tfieldFlux.ref();
I see the following line of code right after the construct of the field:
    fieldFlux.setOriented();
What are we specifying should be oriented here, and with respect to what?
Kind regards,
Jesper Qwist
Jesper_Roland is offline   Reply With Quote
Old   December 4, 2019, 12:43
Hosein
einstein_zee is on a distinguished road
Hii there,
I just looked at it out of curiosity and it seems this function only exists in ESI version of OF and not the foundation one. But you may look in https://www.openfoam.com/documentati...8H_source.html to see what it does. But the description says it all "Given point flip all faces such that normals point in same direction."
You may look at member functions section to see what and how it does.
static bool orient(triSurface&, const point&, const bool orientOutside);
static bool orient
             triSurface& s,
             const triSurfaceSearch& querySurf,
             const point& samplePoint,
einstein_zee is offline   Reply With Quote
Old   December 5, 2019, 04:24
Jesper R. K. Qwist
Thank you for your reply.
It did however clarify the question for me. The suggested code relates to triSurfaces. I do not think this is where we need to look for this case.
I think the setOriented() function used here is the one defined in the class orientedType, which has the Detailed description: "Class to determine the 'oriented' status of surface fields."
Link to the class:
https://www.openfoam.com/documentati...e.html#details
To me it seems that it controls shift in direction caused by one of the mathematical operations defined in the class orientedType.
Still I do not understand when I would need this to be true or false.
Best Regards,
Jesper Qwist
Old   December 5, 2019, 06:45
Hosein
yeah I knew the link you sent me and you are right partially, cause the final function which is called is the setOriented in orientedType (the link you provided). but the problem is looking into it, would not help you at all cause orientedType is only the tool to achieve sth. And that sth should be sought in regions where this type is used . It is used in dimensionedFields and if you trace it further you would end up with the link I provided.
Old   June 28, 2020, 05:54
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Originally Posted by Jesper_Roland View Post
Hi everyone,
When constructing a field like surface field of Type like the following:...I see the following line of code right after the construct of the field:
This has nothing to do with triSurface mesh orientation. Here is some information that I found (private communication):
We introduced the oriented flag for surface fields to discriminate between flux fields that are oriented, i.e. where the sign depends on owner->nbr connectivity, and plain interpolated fields, e.g. pressure on faces.
If you apply a field operation that includes the area vector field Sf() the resultant field becomes oriented; similarly, taking, e.g. the mag() of an oriented field makes it 'unoriented'. The rules applied when dealing with [un]oriented fields also gives us an extra layer of protection/verification that the mathematics is consistent.
If the field is constructed without using field operations and it is a flux field, you should set the oriented type to true.
bharat_aero, missios and saladbowl like this.
olesen is offline   Reply With Quote
geometricfield, orientation, setoriented, setoriented()
