how to correct turbulent variables in a solver |
chen wang
Rep Power: 7 ![]() |
Hello Everyone,
I want to know whether it is possible to correct the turbulence variables in a solver. For example, in simpleFoam, the turbulence equation is solved by the function 'turbulence->correct();' We can obtain the value of turbulent kinetic energy k by the function 'turbulence'->k();but ,as far as I know, the value of k cannot be corrected directly in the solver. In my algorithm, I need to correct the value of all transport variables based on their values from several previous iterations in the solver. I can correct the value of the velocity by the function 'TEqn.setValues(tCells, tVal);' suggested in the link:Fixed Temperature Cell in Solution But I don't know how to correct turbulent variables in the solver. Can you give me a clue? Thanks in advance. Chen |
Michael Alletto
Rep Power: 16 ![]() |
It is not possible from outside since all functions inside the turbulence model gives you constant access on the variables, e.g. k,epsilon and nut for the kEpsilon model (see https://www.openfoam.com/documentati...8H_source.html). If you want to manipulate the variables you have to do it directly in the source code of the model itself. This means you have to write your own model
chen wang
Dear Michael,
Thank you very much for the reply. |
How to freeze additional variables fields for a number of solver iterations? | Antanas | CFX | 18 | April 26, 2023 11:29 |
PEMFC model with FLUENT | brahimchoice | FLUENT | 22 | April 19, 2020 15:44 |
Solver for an incompressible, turbulent flow with heat transfer | tH3f0rC3 | OpenFOAM Running, Solving & CFD | 9 | June 17, 2019 06:12 |
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 06:00 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 02:13 |
